Choosing the Right RAM for MSI z370 Tomahawk and Intel Core i5 8600k: 8GB, 2666MHz vs 3000MHz
DizzY74 3030 9
What RAM should I choose for an MSI Z370 Tomahawk with an Intel Core i5-8600K, 8 GB in two sticks, and what is the difference between 2666 MHz and 3000 MHz?
Choose 3000 MHz CL16 RAM; at current prices that was the recommended option over 2666 MHz [#17293055] A specific example given was GoodRAM IRDM X Black 8 GB 3000 MHz CL16 [#17293270] If you buy two identical 4 GB modules separately, they should work together without a problem [#17293620] There is no guarantee each stick will reach the exact rated speed on its own, but with two sticks it should not be an issue [#17293620][#17295136]
  • #1 17292687
    DizzY74
    Hi, I wonder what framework to choose for MSI z370 Tomahawk and intel core and 5 8600k The budget is about PLN 350 and I'm only interested in 8 GB, rather in 2 bones, I don't know how much MHz to take, but I was thinking about 2666 and 3000 and if someone would write me what it changes, i'll be grateful.
  • #2 17293055
    Piterixos
    Help: 38
    Rate: 56
    At current prices, it's 3000MHz CL16.
  • #4 17293527
    DizzY74
    I have one more question because on the website you gave me there are only 1x4 1x8 and 2x8 to choose from and I want to buy 2x4 Gb and in the sense I mean, if I bought it, do 2 frames match each other? If there is no such an on the side, this framework as 8 Gb can only be in one bone.
    And would you recommend a ssd up to PLN 300, preferably 200Gb.
  • #5 17293620
    Piterixos
    Help: 38
    Rate: 56
    If you buy two of the same dice separately, they will work together, but there is no guarantee that they will reach the speed specified in the specification of each dice, but with two dice it should not be a problem.
  • #6 17293854
    DizzY74
    Ok, I already have a frame selected and a 200 Gb ssd drive because I know that now the system can be a bit muddled when the procka still tweaks the budget for the disk is 300 PLN.
  • #7 17293872
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    After the cheap: https://allegro.pl/dysk-ssd-micron-256gb-obudowa-icy-box-usb-3-0-i7365232642.html (and you will have a 2.5 "disk enclosure for free)
    A bit better, because the disk is equipped with MLC memory - https://www.sferis.pl/dysk-ssd-240-gb-goodram-irp-ssdpr-s25b-240-25-sata-iii-p571026
    You can use a discount code SUPPLY and courier shipping is then free. The same price on Allegro, but no free shipping: https://allegro.pl/dysk-ssd-goodram-irdm-pro-240gb-sata3-2-5-i7412367004.html
  • #8 17294976
    DizzY74
    So I understand that if I buy 2 times 4GB GoodRam IRDM 3000 MHz, they will work nicely with each other?
  • #9 17295136
    dt1
    Help: 7315
    Rate: 8292
    Yes, no problem.
  • #10 17295375
    DizzY74
    Ok, that's it, thanks for your time to close.
The discussion revolves around selecting the appropriate RAM for an MSI Z370 Tomahawk motherboard paired with an Intel Core i5 8600K processor. The user is considering 8GB RAM options at either 2666MHz or 3000MHz, with a budget of PLN 350. Responses suggest that 3000MHz CL16 RAM is preferable due to current pricing. Users confirm that purchasing two 4GB modules (GoodRam IRDM 3000MHz) will work well together, although there is no guarantee they will reach the specified speed. Recommendations for SSDs under PLN 300 are also provided, highlighting options with MLC memory and free shipping offers.
