Installing Kali Linux on 750GB USB Drive: Creating Bootable Disk & Setup Guide
DJ Tek-Tronic 5265 4
  • #1 16208069
    DJ Tek-Tronic
    Rate: 19
    Hello everyone. I have a free 750GB USB drive and would like to install Kali Linux on it. I have a problem with this, because I wanted to make Linux boot from this disk, which is a botable disk, and install it.
  • #2 16228352
    reg_edit
    Help: 6
    Rate: 20
    You are making a bootable installation flash drive with kali with this program:
    https://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
    You connect the USB drive on which you want to install linux and a bootable USB flash drive. You run the motherboard's boot menu, select the flash drive and install linux on the previously connected disk. If you want your computer to boot from a USB drive when it is connected, you need to change the boot order in the BIOS (first USB, second HDD). If you have a USB 2.0 drive, don't expect it to work as smoothly as a SATA connected drive.
  • #3 16232376
    DJ Tek-Tronic
    Rate: 19
    Hello Dude, reg_edit only in this link what you gave is not on the linux kali list so I did boot using the console and it does not start me.
  • #4 16233126
    reg_edit
    Help: 6
    Rate: 20
    It is in the "security and penetration testing" tab
  • #5 16233455
    yogi009
    Help: 848
    Rate: 2655
    If you have an image of this Linux, you can upload it with any software for the production of boot pendrives.
