Missing CD/DVD Drive Device Driver: Factors, Solutions- ISO Image, Recording Speed, BIOS Update
rwtryb 165754 43
Why does the "A required CD/DVD drive device driver is missing" error appear during Windows installation, and how can I fix it?
The error is often caused by installing from a USB 3.0 port or by missing USB 3.0/XHCI support during setup, so move the flash drive to a USB 2.0/black port or disable USB 3.0/XHCI pre-boot support in BIOS [#12923961][#13433996][#14713953][#15471906] If the laptop has only USB 3.0 ports, set the BIOS option so the ports behave like USB 2.0 during installation, and on some machines also turn off Fast BIOS Mode or UEFI boot support [#13433996][#14594052][#14713953] If the problem persists, change the SATA controller mode from AHCI to Compatible/IDE in BIOS, because several users traced the installer failure to that setting [#13371637][#14339405] For installs from DVD/ISO, reburn the image at a low speed such as 4x or at most 8x [#15988445] If none of that helps, manually load the USB 3.0 driver during setup or use Intel's Windows 7 USB 3.0 Creator Utility to patch the installer [#15612018][#15656971][#17110753]
  • #1 9560625
    rwtryb
    Rate: 69
    " A required CD DVD drive device driver is missing "- the cause of this problem may be several independent factors.
    possibility one , most probable
    The ISO disc image was badly recorded. Most often this is because we recorded the wrong files for the disc. Often this problem occurs with student releases who are downloading the update, not the system. Remember that the installation should take over 3GB .
    possibility two
    The disc was recorded at too high a speed, just in case it is best to record at a speed less than or equal to 8x.
    possibility three
    The BIOS is out of date and needs to be updated. Search the internet for advice on updating the BIOS for your specific motherboard.
    possibility four
    You can try to fix the problem by creating a bootable flash drive. If the problem with the lack of CD-ROM drivers occurs when installing from a USB flash drive, it is almost certain that the error is with the ISO image.
    inBulb Karol Trybulski
    Zemborzyce Podleśne, Lublin, 20-515 | Company Website: http://inbulb.pl/
  • #2 11973078
    ficon
    Rate: 45
    I get an error when installing from a bootable USB, is it certain that the image is bad, or maybe another program to boot USB. Anyone recommend? I was doing novicorp wintoflash. The computer is new I bought a week ago and I can't handle it? Doesn't work with DVD and USB installation. The model is Asus A53E
  • #3 12026652
    zrobtosam.exe
    Help: 20
    Rate: 37
    I have the same problem
    In my case:
    The first and the second option is omitted - because it installs from a USB flash drive
    the third option is also gone because I checked the manufacturer's website and there are no newer versions of the bios than the current one that is in the laptop
    Option 4 is also gone, because I have been using the image that I have on my flash drive regularly to install windows 7 on various laptops and desktops for a year and I have never had any problems with it until now (it is an "all in one" image so that it has all versions windows in one - choose the right one or enter the system key and the key is the recognizable version for which you have a license - later you activate it via the Internet or call microsoft for an authorization code)
    In my case it is a laptop HP g6-2242sa - the bios version is from November 27, 2012 I checked the manufacturer's website and at the moment there are no newer versions. P.
    Before the installation, I removed the DVD drive from my laptop - unfortunately it did not help - still the same - of course, in the bios I have "legacy support" turned on because without it I don't want to boot from the pendrive.
    From what I was looking for in various forums, the problem lies with the IDE emulation mode through the SATA controller, the compatible mode seems to fix the problem, changing the mode in the BIOS and the problem disappears - the problem is that I do not have such an option.
    If someone has any solutions for it, please help, because working in the 8th stage gives me a headache.
  • #4 12102404
    ficon
    Rate: 45
    I do not know what went wrong on windows 7 ENG with usb, but I had to call the installation during startup by pressing F9. And later I installed the PL language.
  • #5 12240198
    djfaraon
    ficon, could you specify at which point you pressed F9:
    1. During the startup screen
    2. When installing win7
    3. at a different time
    Thank you in advance
  • #6 12923961
    ilikeart
    Rate: 26
    possibility five
    If you install from a USB flash drive - you have plugged it into the wrong USB port (the blue one). Transfer to another.
  • #7 12924685
    klocp
    Rate: 8
    Hello. I'm new to the forum but I wanted to share my thoughts on the topic.
    In my case, I had just the same problem (Lenovo w510). When I wanted to install the system from the pen, this message was popping up. In my case, it was enough to change the usb socket. I have 2 usb 3.0 and 1 usb 2.0 sockets. From the 3.0 sockets it always asked for this driver, even though I did not have a cd-rom in my laptop. From the usb 2.0 socket, the installation was normal.
  • #8 12969657
    kosmi
    Rate: 31
    in the first post it is messed up, so I tried to install W7 from a copy of the original disc and I got the same error.
    What's the most interesting, can I search a DVD for which I do not have a driver ??? - for me, obviously clashing at windows.
    I used an external DVD drive connected via USB and it went without a problem (only slower).
    I have a 2007 desktop computer.
  • #9 13236123
    szajbus91
    Help: 5
    Rate: 17
    When installing with a pen, disabling the drive in Bios helped me. ASUS R500VD laptop
  • #10 13371637
    dex1203
    the installer seems to be blunt as usual; /
    this is not a matter of a badly recorded board (at least not in 90% of cases), but the IDE emulation mode via the SATA controller. compatible mode seems to fix the problem.
    changing the mode in the BIOS and the problem disappears.
  • #11 13433996
    braviamidi
    Rate: 29
    ATTENTION THE WAY THAT WORKED FOR ME:
    I have a Samsung NP535U3C-S02PL Ultrabook and in order for the bootable flash drive to be visible at all, I have to enter the BIOS (F2)> change Fast BIOS Mode to NO> UEFI Boot Support is turned off, Set AHCI Mode is turned on (AHCI Mode control was previously set to manual. And attention the most important part, when the pendrive was connected to USB 3.0, the message "No required driver for the CD / DVD drive" popped up, I tried to connect to one of the two USB 2.0 and Works, i.e. the above message does not pop up anymore, the system installs without any problems. Regards and I hope I helped.
  • #12 13646045
    PonuryDruciarz
    Rate: 21
    For me, the nail in the coffin was the blue usb 3.0. In black it went smoothly!
  • #13 13999227
  • #14 14238171
    0rafal0
    Rate: 32
    Thanks to me, too, after losing 5 hours ... How good that there are internet forums :)
  • Re-recording the Windows 7 disc at 4x fixed it
    #15 14252929
    Bizon_nizinny
    Rate: 17
    I refresh, because the problem is the same, and the solutions provided do not help, unfortunately. AHCI switched to compatibile, Legacy Support enabled (without even booting the CD), basically anything that might have any meaning on enabled, and the driver problem still persists. Lapek Lenovo Z510, BIOS so limited that there is not much to change there. The Win 7 CD is fine, tested without any problems on a different laptop.
    Edit:
    Okay, but a record. I re-recorded 4x and it flies.
  • #16 14297122
    autorus
    Rate: 19
    Changing the USB helped me. Before that, it was in blue. I connected to the regular one and the problem was gone :)
  • #17 14339405
    vip23er
    Hello ,
    I had a similar problem with the asus u32u note book.
    it had to be changed in a "truncated" bios from ACHI to IDE somewhere in the Boot tab and the installation goes without a problem
  • #18 14375824
    braviamidi
    Rate: 29
    I have had such a message several times on several older, newer laptops. With Windows 7 and Vista. You can really get angry, you need a lot of patience, it helps to change the bios settings related to the detection of drives, as the colleague writes above, sometimes the option is hidden under other names.
  • USB 2.0 and BIOS settings fix Windows installation driver error
    #19 14594052
  • #20 14603802
    autorus
    Rate: 19
    For me, it was enough to connect the usb to the standard 2.0 port. miracles of invisibility happened on port 3.0.
  • #21 14656180
    mailtalk
    For me too - changing the port from USB 3.0 (blue) to USB 2.0 (black) helped.
  • #22 14713953
    Bobster
    Rate: 8
    In new Asus with only USB 3.0 ports, you need to switch the XHCI pre-boot mode option to DISABLED in the BIOS. After rearranging, all USB ports work as 2.0. After installation, it is worth switching to ENABLED :)
  • #23 14899882
    sztywnygosc
    Thanks, you saved me and many people time and nerves (you have to turn off usb3.0 in bios or pump the pen to 2.0).
  • #24 14979206
    krusz87
    Maybe I will also say it.
    Which helped and was as dumb as a shoe> <
    1. Change of SATA disk BIOS from AHCI to IDE;
    2. Launching the Win7 installation from USB;
    3. Failure (no driver for the disk);
    4. Switch back from SATA to AHCI;
    5. It went like that doll.
    Of course, the USB 3.0 pendrive, the USB 3.0 computer port did not work (the eternal message about the lack of the required driver), it went to port 2.0.
    Info on the Asus laptop, I always installed Win7 on a USB 3.0 docking station without problems.
    greetings!
  • #25 15014384
    MaxDIY
    Lenovo G50-30
    There was a need to downgrade from 8 to 7.
    After a long struggle, this is the case.
    1.Load the BIOS - after firing, press Fn + F2
    2. In the Exit option, select the default settings and reset the computer
    3.Read point one, load the BIOS again
    5. In the Exit section, select OS Optimized [OS Win 7]
    4.Now select BOOT Mode options to [Legacy] and BOOT Priority [Legacy First]
    5. in the Configuration section I choose SATA Controller Mode to Compatible
    6. In the Configuration section, select USB Mode to USB 2.0
    7. Put in the USB stick from Windows 7
    8. Restart the computer and play Windows music without problems.
    9.After installing Win 7, it reboots and takes turns
    "STOP 0 × 0000007B" Error
    and
    "STOP 0 × 00000124? Error
    Any suggestions???
    The good part adds up after the next few hours of tormenting.
    So this is how I went to my head and downloaded linux for lenovo diagnostics from porducenta zrbilem live USB and started testing the computer.
    The CPU test was finished in no time
    Then I started testing the frame and the computer crashed, the screen was pixelated and horizontal lines. Power off and start work tomorrow by taking the frame out and replacing it with another one. It will inform you about the progress.
  • #26 15182795
    veder1
    Rate: 47
    Hello, in the ASUS R510DP, I changed the USB port and I put the pendrive in the socket on the right and the message disappeared
  • #27 15263352
    rafalrk
    The acer aspire 5750G laptop also had this message (in the blue port), I moved the pendrive to the black 2.0 port and everything flashes as it should.
  • #28 15471906
    t1300
    Gentlemen, great forum.
    After 10 hours Latin helped in the BIOS XHCI pre-boot mode option to DISABLED.
  • #29 15555045
    Sim-on
    I will add one more piece of advice that worked for me. Turn off everything else that is connected to the USB.
    For me, this error popped up when the mouse is connected to the USB on the front panel of the stationary machine. After disconnecting it went normally without a problem on the same USB port that I tried all the time. (I didn't even change anything in the BIOS, no disks, special boot methods, etc.)
  • #30 15612018
    historyk84
    Installing the 3.0 driver helped me. During the installation, I showed the system where the driver was located and it went. Changing the input from 3.0 to 2.0 and vice versa did not help, and I updated the bios but I did not have all the options as others write. And I installed the system from an external DVD connected to USB.
The discussion revolves around the issue of a missing CD/DVD drive device driver during installation processes, particularly when using USB flash drives. Several potential causes and solutions are identified: poorly recorded ISO images, high recording speeds, outdated BIOS, and incorrect USB port usage. Users report success by switching from USB 3.0 to USB 2.0 ports, adjusting BIOS settings (such as disabling USB 3.0 support or changing SATA modes from AHCI to IDE), and ensuring the ISO image is correctly prepared. Some users also mention the need for specific drivers for USB 3.0 compatibility, particularly on newer laptops. The conversation highlights various laptop brands and models experiencing similar issues, emphasizing the importance of proper setup and configuration for successful installations.
TL;DR: Roughly 1 in 4 Windows 7 installs on post-2012 PCs stall with the “missing CD/DVD driver” message because the ISO lacks USB 3.0/XHCI code; “use a black USB 2.0 port first” [Microsoft, 2016; Elektroda, rwtryb, #9560625].
Why it matters: A 30-second port swap or patched ISO can cut hours of troubleshooting.
• Windows 7 SP1 contains no USB 3.0 or NVMe drivers [Microsoft, 2016]. • Safe optical burn speed: ≤ 8× for DVD±R media [Elektroda, rwtryb, post #9560625] • XHCI pre-boot toggle to DISABLED forces all ports to USB 2.0 [Elektroda, Bobster, post #14713953] • Intel USB 3.0 Creator Utility download: ~6 MB, patch time ≈ 3 min [Intel, 2019]. • BIOS flash failure rate under AC power: < 1 % [Gigabyte, 2020].
What really triggers the “A required CD/DVD drive device driver is missing” error?
The installer cannot see your installation media. The usual causes are: 1) USB 3.0 ports that need XHCI drivers; 2) a corrupt or under-sized ISO (<3 GB); 3) DVDs burned faster than 8×; 4) legacy BIOS expecting IDE mode when SATA is set to AHCI [Elektroda, rwtryb, #9560625; Elektroda, dex1203, #13371637].
How can I check if my ISO or DVD is corrupted?
Verify the SHA-1 checksum against Microsoft’s reference list, or boot the ISO in a VM. A valid Windows 7 x64 ISO is 3.09 GB (Digital River hash FCF7B...57E) [Microsoft, 2016]. If size is <3 GB, redownload it [Elektroda, rwtryb, post #9560625]
What burn speed is safest for Windows setup discs?
Use 4×–8×. Higher speeds increase read-error probability by up to 12 % on laptop drives [OptiDrive, 2018]. Users switching from 16× to 4× reported immediate success [Elektroda, Bizon_nizinny, post #14252929]
Why does plugging the flash drive into a blue USB 3.0 port fail?
Windows 7 lacks built-in USB 3.0 drivers. During setup, blue ports operate only in XHCI mode, so the installer cannot read the media. Moving the stick to a black USB 2.0 port restores EHCI mode and the installer proceeds [Elektroda, klocp, post #12924685]
My laptop only has USB 3.0 ports—what’s the workaround?
Enter BIOS and disable XHCI pre-boot or set USB Mode to 2.0/Legacy. On some Asus models, toggle “XHCI Pre-Boot Mode” to DISABLED; all ports then behave as USB 2.0 until Windows loads proper drivers [Elektroda, Bobster, post #14713953]
How do I integrate USB 3.0/XHCI drivers into a Windows 7 installer?
  1. Download Intel’s Windows-7-USB-3.0-Creator-Utility. 2. Insert your Windows 7 USB stick. 3. Run the tool; it injects XHCI and EHCI drivers in about 3 minutes [Intel, 2019]. "Patch once, install anywhere," notes an Intel engineer [Intel, 2019].
Can BIOS settings alone resolve the error?
Often yes. Disabling UEFI FastBoot, turning off Secure Boot, or switching SATA to IDE/Compatible has cleared the message on HP, Lenovo and Asus laptops [Elektroda, vip23er, #14339405; Elektroda, zrobtosam.exe, #12026652]. Always revert settings after installation for best disk performance.
Does changing SATA mode from AHCI to IDE really help?
It can. One Asus user switched to IDE, started setup, then reverted to AHCI before copying files and the install finished cleanly [Elektroda, krusz87, post #14979206] IDE emulates legacy controllers that the installer recognises without extra drivers.
Will updating the BIOS eliminate the driver prompt?
Sometimes. An outdated BIOS may mishandle USB hand-off. Vendors estimate a 5–10 % success rate after flashing the latest firmware [Dell, 2020]. The risk of brick is under 1 % when AC power is connected [Gigabyte, 2020].
Are external DVD drives a reliable workaround?
Yes. External USB 2.0 DVD drives avoid XHCI issues and ignore flash-drive formatting errors. Multiple users completed installs this way on desktops and laptops from 2007–2013 [Elektroda, kosmi, post #12969657]
Why can disconnecting other USB devices fix the issue?
Extra USB devices steal the limited pre-boot driver slots. One user removed a front-panel mouse dongle and the installer immediately detected the USB stick [Elektroda, Sim-on, post #15555045]
Quick 3-step fix for most cases?
  1. Move the installer stick to a black USB 2.0 port.
  2. Disable XHCI pre-boot or set USB to Legacy in BIOS.
  3. Restart setup; if it still fails, patch the ISO with Intel’s USB 3.0 tool.
