Saeco Incanto HD8918 Espresso Machine: Error Icon Displayed, Troubleshooting & Solution
qwerty012 52317 11
What does the unknown error icon on a Saeco Incanto HD8918 mean, and how do I clear it?
The icon means the coffee grounds container/drip tray is full or not being detected correctly, so empty the grounds container and the drip tray, then put them back in [#16208569] [#17159266] With the machine switched on, pull out the tray, wait until the tray/container indicator on the display disappears, and insert it again [#16208668] Another suggested reset is to switch the coffee machine off, remove the drawer, switch it on until the “no drawer” error appears, then reinsert the drawer [#18362344] One user reported that even after emptying everything the red icon stayed on, so if these steps do not help the issue may be deeper than the basic container reset [#17604889]
  • #1 16208439
    qwerty012
    Hello!
    When switching on the Saeco Incanto HD8918 coffee machine, an error occurs, which I have attached; the user manual does not mention this icon, which appears on the machine’s display – how should I deal with this?
    Saeco Incanto HD8918 Espresso Machine: Error Icon Displayed, Troubleshooting & SolutionDSC088..JPG (2.91 MB)You must be logged in to download this attachment.
  • #2 16208569
    scotch
    Help: 78
    Rate: 148
    Kolego qwerty012 p. 13 point "7.1.1 Cleaning the device according to your needs" in brief "The coffee grounds box is full"
  • #3 16208668
    cafedomino
    Help: 35
    Rate: 360
    Just like a friend, "scotch" wrote a full container for used coffee. With the coffee machine on, pull out the tray on which you put the cup, wait until the icons on the display begin to disappear "dots" that are inside the container disappear insert the tray and enjoy the taste of coffee. Good advice read the instruction manual. Greetings.
  • #4 16937503
    Kawiarka13
    Rate: 10
    This is not what you write a full ambulance on the dregs it is a container tilted and here is straight to me just jumped this error please and help what is it?
  • #5 16938640
    cafedomino
    Help: 35
    Rate: 360
    Hello. And I react to removing the tray from the dregs container? Is something changing on the display?
  • #6 17140229
    Renacisko1
    Rate: 16
    A displayed icon with a coffee container and an arrow
  • #7 17159266
    Margot85
    Rate: 8
    For several days, we are happy with her husband Saeco coffee machine. The error also appears in our store. For the first time, we had no idea why ... There is no description in the manual.
    This error disappears when you empty the overflowing tray with water.
    Greetings.
  • #8 17604889
    zolwiu1
    Rate: 39
    Hello:
    This error is signaling a full container for coffee grounds.
    It should be emptied and the water out of the tray be switched off, it should be after the problem.
    For me, the problem is that the above activities do not give anything, it glows further on in red.
    In addition, when the drip tray is ejected, the coffee maker turns itself off (the screen turns black), after inserting the empty tray and the coffee grounds container it does not turn on, and if you turn it on, the full container icon still lights up.
    Maybe someone has an idea what to do with it to drink coffee again !!!
    I thought about the reset but I do not know how to do it.
  • #9 17675666
    radeks1968
    Rate: 420
    I have a problem with a plunger for which a brewer enters, which can not be set as a treble. What could be the reason? The switches are checked wheels ideal.
  • #10 18012106
    sebaztorunia
    I have slightly different problem
    the machine does not communicate at all about overfilling the container, it only pours water.
    Had someone like that?
    Regards Seba!
  • #11 18362344
    dotuch
    Turn off the coffee machine, remove the drawer, turn on the coffee machine, wait for the lack of drawer error, insert the drawer.
  • #12 21547947
    primzimnoch
    Remove the tray, pull out the water tank and open the service door.
The Saeco Incanto HD8918 espresso machine displays an error icon on startup, which is not described in the manual. The icon typically indicates a full coffee grounds container or an issue with the drip tray. Troubleshooting steps include removing and emptying the coffee grounds container and drip tray, ensuring the tray is properly inserted, and checking for water overflow in the tray. Some users report that the error persists even after emptying and reinserting components, with the machine sometimes shutting off when the drip tray is removed. A suggested reset procedure involves turning off the machine, removing the drawer, turning it on to trigger a "lack of drawer" error, then reinserting the drawer. Additional advice includes opening the service door and removing the water tank to inspect internal components. The problem may relate to sensor misalignment or mechanical faults in the grounds container or drip tray detection system.
