[Solved] Saeco Incanto DeLuxe - BLEED Display Issue, 2500 Coffees, 3-Year Usage, Troubleshooting Steps
dog34 5520 4
  • #1 16173919
    dog34
    Please help like subject.
    After switching on the coffee machine, the word BLEED is immediately displayed
    1. filtered water in the zepter machine.
    Ground coffee for 4
    3. stone tablet express,
    4. springs in the pump and the valve under the pump,
    5. number of coffees around 2500 (3 years)
    6.sitka clean (up, down)
    7.pump feeds hot water
    What could be the fault?
    After resetting the settings, coffee begins to pour out for about 5 seconds and venting again.
    Save, because I fall asleep with instant coffee (beeee)
    •  Saeco Incanto DeLuxe - BLEED Display Issue, 2500 Coffees, 3-Year Usage, Troubleshooting Steps express.jpg (147.74 KB) You must be logged in to download this attachment.
  • #2 16175187
    ssss
    Help: 469
    Rate: 1787
    Please check the Flowmeter water flow sensor
  • #3 16175232
    dog34
    How should I check? (This may be a silly question, but I am dismantling rozbexpress for the first time.
    Is the flow going to blow?
    I took the steam valve today and it looks like everything is ok.
    Tomorrow I will disassemble the flow.
    Thank you
  • #4 17230302
    trawnikedytaaran
    Rate: 34
    So what worked with this express?
  • #5 17264565
    dog34
    Hello, replacing the valve helped.
