Creating a Single WiFi Network with LTE Huawei CPE B593 and Asus RT AC51U Routers
sadok90 7881 10
How can I make my LTE Huawei B593 and Asus RT-AC51U work as one Wi‑Fi network instead of two separate networks?
Yes—make the Asus act as an access point, not as a second router: connect it to the Huawei with a LAN port instead of the WAN port, disable DHCP on the Asus, and give it a LAN address in the same subnet as the B593, for example 192.168.1.2 if the B593 is 192.168.1.1 [#16208893][#16208896] Set the same SSID, password, and encryption on both APs if you want clients to see one Wi‑Fi name, but use different Wi‑Fi channels [#16208653][#16208896] In this setup the B593 stays the only router and DHCP server, so all devices are in one network and can see each other [#16208896] Seamless roaming is still not guaranteed with this equipment, so brief packet loss can happen when devices switch between access points [#16208653]
  • #1 16208444
    sadok90
    Rate: 15
    I have a lte huawei CPE B593 router located on the floor which means that I have poor coverage on the ground floor. I connected a second asus rt ac51u router with the cable at the bottom but now I have two wifi networks. and here is the question, can there be only one network? if so, please give me a very "pathological" step-by-step explanation of what to do. best regards.
  • Same SSID is unreliable; use two WiFi networks instead
    #2 16208518
    A.Gieronimo
    Help: 268
    Rate: 309
    It can't be done like that, you can give them the same name and password, windows will choose the one with the stronger signal, but to say the least it works. (although it depends how it goes)
    With this equipment you only have one option - two WiFi networks.
    Not a book option, lightly hide this router at the top so as to weaken its signal at the bottom (because there is probably no WiFi power change option), windows should switch to the lower network faster.
    Use identical SSID and security on different channels
    #3 16208653
    Reduce overlapping Wi-Fi signals to prevent roaming disconnects
    #4 16208696
    A.Gieronimo
    Help: 268
    Rate: 309
    Exactly.
    And as I wrote above, you can help windows to "choose" the network, weakening the one on the floor, put the router in the corner wall / wall or lightly hide it behind the cans after the hop drink / aluminum foil / ESD foil, should effectively suppress the signal so that windows on the ground floor did not have a "dilemma" with which network to connect - because it will be the most annoying at such distances, the signals may overlap 50/50 and it will wander from network to network every now and then losing connection.
    The lower router should be placed as centrally as possible so that the signal does not change too much when moving the computer on the ground floor.
  • #5 16208815
    sadok90
    Rate: 15
    there is a problem because ip camera is connected and it works over that wifi network. the computer in which I would like to amplify the signal is downstairs and it is recording but the internet is slow so I have to have the same network. I have 30mb internet connection and the bottom speed is 1mb max.
    Separate SSIDs avoid roaming and camera access issues
    #6 16208842
    A.Gieronimo
    Help: 268
    Rate: 309
    Routers are connected by a cable, so I don't understand why speed degradation?
    In that case it would be better to give 2 network names and use the lower one and the upper one at all to throw them out of the default ones in Windows.
    Upper AP for camera - 1 name
    Lower AP for computer - 2 name
    In windows, remove the upper one from remembered networks.
    The network will still be the same, provided that the routers are connected via LAN ports, you may have trouble getting into the camera via WAN.
  • #7 16208855
    sadok90
    Rate: 15
    yes, only if I have a second network, I don't have a camera image on my computer because it uses wifi on top. unless you can work around it somehow
    and I can't switch cameras because again it doesn't catch the router's range below and the camera is on the second building on the roof.
    A.Gieronimo
    Help: 268
    Rate: 309
    Connect the bottom router with a LAN instead of WAN port and disable DHCP on the bottom one (first).
    You will have a picture.
    Configure Asus as a LAN access point behind B593
    #9 16208896
    matek451
    Help: 4352
    Rate: 5808
    Your problem is that you have an Asus connected to the WAN and acting as a router. Connect to LAN, give it LAN address 192.168.1.2 (if B593 has 192.168.1.1). Disable on Asus DHCP. The network name on Asus can be the same or different, the password and encryption the same. WiFi channel different. You will have one network in your home created by B593, all devices in it will see each other, addresses will be allocated by B593.
  • #11 16210784
    sadok90
    Rate: 15
    I just did everything as you wrote and I will tell you that it works :) thank you very much!!
The discussion revolves around creating a single WiFi network using a Huawei CPE B593 LTE router and an Asus RT AC51U router. The user initially faced poor coverage on the ground floor due to the placement of the Huawei router. Responses suggest configuring both routers with the same SSID and password but on different channels to minimize connection issues. A key solution involves connecting the Asus router via LAN instead of WAN, disabling DHCP on the Asus, and assigning it a static IP address within the same subnet as the Huawei router. This setup allows devices to communicate seamlessly on one network, improving connectivity for devices like IP cameras and computers.
