Installation of LED lights / relay - relays and LED work lights CRV1 WESEM
domi42097 17331 3
  • #1 16208937
    domi42097
    Hello, I am new to the electrode and I have a problem how to connect LED 12/24 V LEDs in an agricultural tractor, they are LEDs Wesem CRV1 35W. I am thinking about installing LEDs on 541 relays and I have a question: will 541 relays be suitable? 1 relay for 2 lamps to give? And how to connect them?
  • One relay can power two lamps; separate switch recommended
    #2 16208981
    Xantix
    Help: 686
    Rate: 1657
    Yes, they will be.
    Yes, one relay is enough.
    The diagram below:
    You can give the lights under a separate switch, or connect under the position light switch. However, the latter solution is less functional - as it is impossible to turn off work lamps and drive only on ordinary traffic lights.
  • #3 16209187
    domi42097
    Thanks for the answer, but I have a question whether LEDs are generally sensitive to voltage drops? are relays needed for this kind of lights? I know that with halogens their lack is noticeable but I do not know how it is in the case of LEDs.
  • #4 16209221
    Xantix
    Help: 686
    Rate: 1657
    It depends how the lamp is built. As in the middle of the lamp sits the LED power supply converter then there is usually a greater tolerance for voltage drops - even at lower LED voltage will remain full brightness.
    However, if there is a simple power supply system, such as a resistor or some poor current source, such a lamp can be equally sensitive to voltage drops as well as the bulb - and even more.
