Control of six LED lamps by ASW-210 with one power supply: limitations, costs
chudy_b 993 11
Can I switch six LED lamp power supplies with one ASW-210 relay, and what does the "one power supply per relay" limitation actually mean?
Yes—this limitation is mainly about protecting the relay contacts from the high inrush and capacitive behavior of LED power supplies, not because the ASW-210 cannot switch LED loads at all [#19447906][#19447974] The module is rated at 1250 VA in AC1, and six lamps at about 10 W each (about 60 W total) are far below that limit, so direct connection should be fine in this case [#19448198][#19448759] If you still want to reduce stress on the ASW-210 contacts, you can use an intermediate relay with a 230 V coil [#19447906][#19447974] With your lamp-to-lamp wiring, the first lamp can feed the rest of the installation [#19447997]
  • One power supply per relay limitation explained
    #1 19447885
    chudy_b
    Help: 37
    Rate: 48
    Hi
    I have an alley in front of my house which I want to light with six LED lamps with twilight control. As I already have an INTEGRA, ABAX2 and a twilight detector, the natural choice was to control the lamps using the ASW-210 controller. The problem is that the manual says that only one LED power supply should be connected to one relay. This complicates, and actually makes the installation more expensive, as these drivers are not cheap. One and six is almost PLN1,000 difference. What does the restriction to one power supply per circuit entail? Is there any way around this? I keep my lamp wiring as simple as possible. From lamp to lamp, a single 3x2.5 cable. I have planned the driver on the first lamp and the rest in parallel.
  • #2 19447894
    sosarek
    Help: 9320
    Rate: 15541
    Do you have the power cable from the lamps near the control panel?
    Z
    Pka, Poznań, 60-850
  • #3 19447902
    chudy_b
    Help: 37
    Rate: 48
    sosarek wrote:
    Power cable from lamps do you have near the control panel?
    No. I don't know which direction you are going, but only wireless control is an option.
  • #4 19447906
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    Probably with concern for the module relay contacts, as led power supplies are capacitive or inductive loads. You can get around this by using a relay with a 230V coil.
  • #5 19447915
    sosarek
    Help: 9320
    Rate: 15541
    This is how you would derive the control from OUT via a 12/230V relay....
    Z
    Pka, Poznań, 60-850
  • Relay with 230V coil avoids capacitive load switching
    #6 19447953
    chudy_b
    Help: 37
    Rate: 48
    And that's the idea. I will buy the relay from a few zlotys. Just isn't the coil of the relay an inductive load? From what I have read, however, an inductive load is less dangerous for the relay. In a capacitive one, the circuit is practically short-circuited at the beginning and the contacts get their asses handed to them. In inductive, the current persists in the circuit for a while after the power is removed, but the contacts are still open. There is just some risk of sparking. 100nF/600V capacitor in parallel?
  • #7 19447974
    kood
    Help: 259
    Rate: 443
    chudy_b wrote:
    Only isn't the relay coil an inductive load?
    It's not that you can't connect inductive or capacitive loads to the ASW, because if you did, this module would be useless. It simply has to be taken into account that the maximum relay contact load is specified by the manufacturer for resistive loads.
    The coil of a 230V relay consumes a few or several mA, so there is no problem.
  • Relay does not solve single-cable power wiring
    #8 19447988
    chudy_b
    Help: 37
    Rate: 48
    However, on reflection, it occurs to me that a relay will not solve my problem with a single power cable. Well, because how do I connect it? Relay coils in parallel and to the controller. And the power supply for the LEDs? Well, the same as the coils, because it's not possible otherwise. The only thing I will get is that instead of one relay contact in the circuit (ASW) there will be two in series.
    Two power wires would be useful. Then one would handle the relays, the other the power supplies. But the impulse will still go to the ASW contacts
  • #9 19447997
    kood
    Help: 259
    Rate: 443
    The asw and relay in the first lamp power the rest of the lamps because, as I understood it correctly, the installation is from lamp to lamp.
  • #10 19448198
    starob
    Help: 128
    Rate: 137
    What is there to sage over?
    From the catalogue data:
    " Maximum switching power in AC1 category - 1250 VA "
    What is the wattage of the power supply or the sum of their wattage ?
  • #11 19448723
    chudy_b
    Help: 37
    Rate: 48
    starob wrote:
    What is there to be wise about?
    The power supply is I don't know, the manufacturer doesn't specify. The light source draws about 10W, or 60W because there are to be six lamps.
  • #12 19448759
    starob
    Help: 128
    Rate: 137
    chudy_b wrote:
    that is 60W because there are to be six lamps
    That is, 20x less than the strength of the switch. Even taking into account the instantaneous "inrush" current of the power supply this should not hurt - connect directly.
The discussion revolves around the control of six LED lamps using the ASW-210 controller, with concerns about the limitation of connecting only one LED power supply per relay, which significantly increases installation costs. Users explore the implications of this restriction, particularly regarding the nature of inductive and capacitive loads on relay contacts. Suggestions include using a 230V relay to manage the load, but challenges remain in wiring and connecting multiple power supplies. The power requirements for the LED lamps are discussed, indicating that the total wattage is well below the relay's maximum switching capacity, suggesting that direct connection may be feasible despite the initial concerns.
