Installation of radio relays to control two LED strips
DiElbe 1041 4
  • Proposes a relay pair to sync two LED strips
    #1 19055623
    DiElbe
    Can anyone suggest if there is such a relay that would work as in the attached clumsy drawing.
    Installation of radio relays to control two LED strips .
    In a nutshell, the idea is to switch on the lighting, in this case two LED strips using a light switch.
    The first strip would be connected to the existing lighting installation + 12V transformer, in front of which a relay would be connected, which would switch on the LEDs and give a radio signal to the second relay (radio?) connected at the 230V line socket de facto switching on and off the current in the socket (transformer and second LED strip connected to the socket). With the light switch we switch both strips on and off at the same time.
  • #2 19055840
    bigmuzzy
    Try searching for 2201d + wp07 on a far eastern portal.
  • #3 19056116
    DiElbe
    That wasn't quite the point, but it's also a solution of sorts.
  • #4 19056404
    adwlodar
    Help: 111
    Rate: 245
    If I understand correctly, you simply want to remotely switch on the led strips from the lighting switch.
    - Finder Yesly
    - F&F F&Wave
    - Zamel SUPLA or EXTA FREE
    - other inventions like SwitchBox etc.
  • #5 19058207
    DiElbe
    I would add that from an existing switch that also switches on a traditional light source.
