VW Golf V 1.9 TDI: Examining Fluctuating Battery Charging Voltage (13.9-14.8V) & Possible Causes
patryk44gks 8457 12
Why does the charging voltage in my VW Golf V 1.9 TDI fluctuate between about 13.9 and 14.8 V at idle, and how should I check whether the alternator regulator or rectifier is faulty?
The most likely cause is the alternator voltage regulator, possibly together with worn or unevenly working brushes; if the voltage still ripples after that, the rectifier/diode bridge may need to be replaced as a complete unit [#16218648] [#16219151] [#16218903] Measure the voltage both at the battery and directly on the alternator, and compare the values with the engine off and running, because a bad meter or measurement point can mislead you [#16218053] [#16218903] If the lights do not flicker but the voltage still oscillates, that points more toward the regulator/brushes or the bridge than toward the battery itself [#16218648] [#16218903] The thread also notes that this Golf V uses a Bosch 140A alternator, so a 20A meter is not suitable for measuring alternator current [#16216542] [#16218712] [#16218903] If the brushes are worn or do not slide smoothly, replace the regulator/brush assembly first; if the fluctuation remains, inspect or replace the rectifier bridge, and regeneration or a full alternator replacement may be needed [#16219151] [#16218903]
  • #1 16211202
    patryk44gks
    Help: 11
    Rate: 74
    I noticed such a problem in the car, namely the battery charging voltage of 13.9-14.8v is waving at idle speed. with no receivers turned on, it is similar with turned on, but the upper limit is up to 14.7v
    Previously, it was perfect 14.5v with the lights off and 14.4v on.
    What could it be?
    Regulator or rectifier, or how to check it.
  • #2 16211258
    andrzej20001
    Help: 1578
    Rate: 6678
    The regulator fell valeo or bosch?
  • #3 16216542
    patryk44gks
    Help: 11
    Rate: 74
    now I measured and the voltage at idle without receivers fluctuates in the range of 14.1-14.35v
    Altek is a bosch 140A
  • Requests comparative charging-voltage measurements under varying conditions
    #4 16218053
  • #5 16218506
    patryk44gks
    Help: 11
    Rate: 74
    He just checks the condition of the car every now and then so that it is always operational.
    Voltage measured on the battery.
    And the battery is new, it is only two weeks old, and the old one was the same. At -25 tdi he fired without any problem, the battery also falls off.
    It makes no difference whether it's cold or warm.
  • #6 16218611
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6439
    patryk44gks wrote:
    voltage at idle speed without receivers varies in the range of 14.1-14.35v
    Then measure the current drawn from the alternator. This is the basis of anything.
  • #7 16218648
    kjancz
    Rate: 20
    Probably the problem lies with the voltage regulator, or in addition to irregular voltage, you do not have a kind of flashing lights at low speed, such as diodes, but replace the entire bridge, do not replace a single diode, because the weaker ones will sit down soon
  • #8 16218710
    patryk44gks
    Help: 11
    Rate: 74
    Candle lights do not flicker well.
    And will I say a 20A meter is enough to measure the alternator current?
    I also have a module for heating candles for PLN 140 for replacement. I will replace the refularor immediately, but it's for the next month.
  • #9 16218712
    Help: 1405
    Rate: 6439
    No, expect a consumption of 20A, 50A and 114A. It depends.
  • Check alternator ripple, grounds, brushes, and diode bridge
    #10 16218903
    kjancz
    Rate: 20
    when it comes to GOLFA 5 WITH THIS engine you have an alternator that he gives you
    14 V 140 A with a meter up to 20 A you will not succeed, the wires in the meter will heat up after a while as if they were to melt if it is a meter from a supermarket, they are not accurate if you do not have pulsating lights at idle speed, the meter indicates you wrong. Do the following on the turned off engine, see the battery if the voltage is flashing, if not, it means that the meter is ok then start the engine, see what voltage you have on the alternator and what is the difference on the battery, how is the difference, is the weight on the engine as there is no difference, and the alternator is still pulsating with voltage diodes replace the entire bridge see what condition the brushes are probably working unevenly clean the commutator and possibly replace the voltage regulator it is together with the brushes if there is still voltage fluctuation after this treatment, you will probably have to replace the alternator sometimes regeneration will do nothing but new
  • #11 16218945
    patryk44gks
    Help: 11
    Rate: 74
    I have a meter in working order for PLN 70, and I also have a second car and the tension is not waving there.
    Just measure the tension directly on the alternator. And tomorrow I will disassemble and cause something to help, and how not to replace the regulator or the rectifier system first?
  • #12 16219151
    kjancz
    Rate: 20
    If you unscrew the regulator and find that the brushes are worn and the brushes work unevenly, press them and check whether they slide out smoothly or are even, because maybe the spring was pressing unevenly, then after finding out the wear of the brushes, the first regulator and at higher revolutions there is also voltage ripple
  • Alternator output fluctuates independently of electrical load
    #13 16219627
    patryk44gks
    Help: 11
    Rate: 74
    I just measured the voltage coming directly from the alternator and it is the same.
    And the voltage fluctuates in the range of 14.2-14-45v regardless of whether it turns on all the lights. For now, I guess I'll see what happens. But it seems to me just like you wrote that it is brushes, i.e. together with the regulator, and it should be calm.
    Tomorrow I am replacing the glow plug heating module, and this regulator will control the voltage every now and then, but it will also be replaced soon.
The discussion revolves around the fluctuating battery charging voltage (13.9-14.8V) in a VW Golf V 1.9 TDI, particularly at idle speed. The user notes that the voltage previously stabilized around 14.5V without load and 14.4V with load. Responses suggest potential issues with the voltage regulator or rectifier, with recommendations to measure the current drawn from the alternator and check the condition of the brushes and regulator. The user confirms the battery is new and has been tested under various conditions, indicating no significant difference in performance. The consensus leans towards replacing the voltage regulator and possibly the entire rectifier bridge if the problem persists.
