VW T4 2.5TDI - Battery Light On, Charging Correctly: Voltage Regulator, Second Battery & Checks
darko b 9933 4
  • #1 16536504
    darko b
    Rate: 103
    Hello. Sometimes the battery light comes on, but I checked with the meter several times that when the light came on, the charging is correct around 2.30 pm. I replaced the voltage regulator half a year ago (replacement instead of Bosch) ... maybe the regulator's fault ... I installed the second battery. What else to check?
  • #2 16536509
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    The year of the car is?
    Meter version with green or blue backlight?
  • #3 16536514
    bizon_126
    Help: 108
    Rate: 566
    Does the excitation cable not short-circuit to ground, if not, the alternator itself burns
    How were the slip rings?
  • #4 16536578
    darko b
    Rate: 103
    Blue counter 2000r .. Half a year ago, when I replaced the regulator, I had doubts because the brushes in the old regulator were still quite long. The ring was worn but probably still normal. I already have a second alternator, but it is still holding back.
  • #5 16536587
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    darko b wrote:
    What else to check?
    Blue thin cable from the alternator to the meter. Likes to rot near the starter. The end is behind the fuse box. There it also connects to the auxiliary heater beam. A damaged additional heater controller can also mess up :)
