Airy CnMemory 2.5 "500GB - Airy external disk does not work :(!
gqx 6960 4
  • #1 16213311
    gqx
    Hello, I have connected to win7 win10 and no computers have detected it. On the win10 the icon appeared for a while, but then it disappeared quickly and nothing on the computer could be seen connecting although the external disk was shining and you could hear the work. Please help. greetings
  • #2 16213467
    RADU23
    Help: 2428
    Rate: 1732
    Too little information.
    Plug in the disk and tell if it can be seen correctly in the BIOS?
    Have you tried to connect a disk on another cable?
    Did you remove the disk from the case and connect it directly to the board?
  • #3 16213470
    mbo
    Help: 2333
    Rate: 845
    It will not hurt to check if you can read SMART, eg using CrystalDiskInfo.
  • #4 16214038
    pidar
    Help: 1569
    Rate: 3590
    This should be noted -> in USBDeview find this device and give it its "Properties". :idea:
    https://www.elektroda.pl/rtvforum/topic3266491.html#16189985
    It is a disk with USB3.0 interface.
  • #5 16214313
    gqx
    Maybe this program will give something, I also connected with another cable
    Added after 11 [minutes]:
    I turned on this usbdview but still the drive is not turned on, the computer does not read :(
