Lenovo Yoga 500 & HP Laptops: Charging Diode Active, No Power On - Electric Stove Impact?
n00n3 5139 7
  • #1 16213716
    n00n3
    Help: 9
    Hello, I have a problem with two Lenovo and HP laptops.
    Both do not respond to Power, and the only thing that works is the charging diode after connecting the charger.
    First, I lost Lenovo, so I bought a second HP laptop and after about 2-3 weeks of use it happened the same as with Lenovo, namely no reaction and only a charging diode. :(
    I suspect it's because of the electric stove in my kitchen, and I came up with it when HP fell, because I was using the oven and the laptop was connected to charging - when I switch the options in the oven, the light dims me ...
    Laptop charger plugged into an outlet on a different wall and normally I always charged there but didn't use the oven.
    Anyone tell me what's up? Can the stove actually damage my equipment? And what could she damage in laptops?
  • #2 16213827
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    when I switch the options in the oven, the light dims ...
    This indicates a problem with the electrical system!
    For the rest, please describe again
    - the exact names of both laptops
    - both power supplies checked under load and are: bad or good?
    - what do you have when you connect org. Good power supply
    * you do not have, go to a store with similar equipment and ask about the possibility of checking the equipment on their power supply for this laptop model / or service / or buying a new power supply and checking
  • #3 16213925
    n00n3
    Help: 9
    Both power supplies are 100% functional, tested on other laptops. So the option of a broken power supply is gone.
    The models are: Lenovo Yoga 500-14ISK and HP Pavilion x2 12-b101ng 2in1 Notebook 12 "FHD
    In both cases, after connecting the charger, only the charging diode lights up :(
  • #4 16214041
    lisek
    Help: 6352
    Rate: 6883
    Since, as you write, the power supplies of both laptops are good (checked), you have damage on the motherboards.
    Yoga500- .. is the 14 "Skylake platform Link_ description
    Bios U2502 Winbond 25Q12QF / W25Q128FV
    NV N16S-GT-S-A2
    kbc U2403 NPCE285pa00
    For now, I'm waiting for SM
    Lenovo Ideal 500-15isk model
    AIWZ2 / AIWZ3
    LA-C851P Rev: 1.0
    The latter model: Pavilion x2 12-b101ng on Intel Core M3-6Y30 or Dual-Core-SoC
    * Skylake platform
    Description Link
    I don't have MS (also Skylake platform) at this time
    __________________________
    In both cases, after connecting the charger, only the charging diode lights up, nothing else
    What do you have IC in system charger_switch. power?
    - whether OZ8685 ?
    I suspect the solutions as in MSI on Skylake
    e.g. MSI GE62 6QD / CLEVO N240JU (CLEVO N24xJU) _ i7-6500U / i5-6200U
  • #5 16214093
    n00n3
    Help: 9
    Unfortunately, it is not possible to repair it yourself due to the lack of equipment and experience :(
    Any information on the service that would undertake the repair and more or less what would it cost?
  • #6 16214113
    lisek
    Help: 6352
    Rate: 6883
    This is a new platform.
    - the layout itself charger OZ8685, depending on where 5-9. $ (only China, long wait) + something else on the disc damaged + labor =?
    Ask on the forum (Hardware laptops), they advertise themselves.
    The latter (HP Pavilion x2 12-b101ng Link ) is a complete novelty and as far as I know only Germany (HP service does it there), but the price is probably "cosmic" (I suspect it starts from 160.Euro)
    * as no warranty
    * new on Amazon is over 570 euros
  • #7 16214497
    n00n3
    Help: 9
    The guarantees should be because both are bought on amazon.de because I currently live in Germany and not too much with the German one with me to call the service, but I will find someone.
    For Lenovo I have everything but HP for this my wife got rid of the original cardboard, does anyone know if she needs the original packaging to send to the service?
  • #8 16214822
    lisek
    Help: 6352
    Rate: 6883
    I have all the data about the purchase of a laptop on the website's computer (sometimes it is enough to check the purchase / printing)
    that is, you put the equipment on the counter, the service technician reads the data from the sticker _ the reader on the housing ... in a moment he has everything (data) on the screen.
    After diagnosis, you get options:
    -or replacement with a new one / or the date to be picked up after repair
The discussion revolves around two laptops, a Lenovo Yoga 500-14ISK and an HP Pavilion x2 12-b101ng, both experiencing power issues where they do not turn on, with only the charging diode lighting up when connected to a charger. The user suspects that the problem may be related to an electric stove used while the laptops were charging, as the stove caused a dimming of lights. Responses indicate that the power supplies are functional, suggesting potential motherboard damage. Repair options are discussed, including the need for specialized service due to the complexity of the issue and the potential costs involved. The user is also inquiring about warranty service for the HP laptop, which may require original packaging.
