Lenovo YOGA 500-15isk - without charger the Display backlight turns off
ldme106 1476 3
  • Suspected resistor fault causing battery-mode backlight loss
    #1 19790327
    ldme106
    Hello, my Lenovo YOGA 500-15isk works perfectly but if I unplug the charger the display backlight turns off!
    I tried to change the battery thinking it was damaged but nothing changed, so doing a search I found that it could be a resistor that needs to be replaced.
    After several tests I have not been able to identify it, nor to find a reference that can indicate where I should look for the problem
    Lenovo YOGA 500-15isk - without charger the Display backlight turns off Lenovo YOGA 500-15isk - without charger the Display backlight turns off Lenovo YOGA 500-15isk - without charger the Display backlight turns off Lenovo YOGA 500-15isk - without charger the Display backlight turns off
  • #2 19796314
    ldme106
    Nobody knows how to proceed?
  • #3 19796560
    safbot1st
    Help: 2719
    Rate: 1585
    Have You checked the power settings on AC on - brightness?
    Try bootable linux. If the problem persists on bootable linux, than in my opinion the charger module on the motherboard is faulty.
  • #4 19797043
    ldme106
    Yes, I have already tried the settings, is it possible to repair the charging module?
