Lenovo Yoga 500-14 - Screen Flicker while on battery power, Yoga 500 laptop
medalik7 22200 31
Why does the Lenovo Yoga 500-14 screen flicker on battery power and stop flickering when the charger is connected?
The flickering is caused by the battery-side voltage dropping too low for the panel backlight, so the screen can flash on battery even though it is fine on AC power [#17409966] In the Yoga 500-14/500-14IBD, Lenovo used both 7.4 V 2-cell and 11.1 V 3-cell batteries, and replacing the low-voltage battery with the higher-voltage one is the reported fix [#18690408][#18704423] One user with the same symptoms confirmed that after replacing the battery, the monitor no longer went dark on battery power [#19051150] If you are troubleshooting it, check the battery voltage/type first rather than the display cable or inverter, since this model has no inverter [#16737085]
  • Battery load triggers screen flicker on internal panel
    #1 16730922
    medalik7
    Rate: 14
    Screen Flickering while on battery power, Lenovo Yoga 500-14 laptop
    The battery flickers from time to time, but most flashes as the battery runs out when the battery is 10-15%, and flickering occurs more and more
    The laptop is no longer guaranteed.
    I5-5200U processor, 2.20GHz
    RAM 8.00GB
    HD Graphics 5500
    Windows 10 Home x64
    1. Connect the charger and the flickering stops as you remove it by hand.
    I have searched the forums and this problem affects some Windows 10 laptops after upgrading
    2. Changing drivers to older ones etc. gives nothing
    3. Replaced the system for a clean Windows without a lenovo application nothing gave the problem still occurs
    4. I connected to an external monitor and the screen strange on the laptop is flashing and on the monitor I don't think it's a tape
    5. Connecting the charger screen stops flashing and now
    At first I thought the matrix tape might be damaged, but when I connect the charger, I stop any ideas
    It would be best to replace the tape, I know, but it costs about PLN 200, so for now I want to avoid costs if it is not the tape.
    Clips
    1. Screen flickering
    [Film: dbcd3f1ad5] https://filmy.elektroda.pl/32_1506850041.mp4 [/ film: dbcd3f1ad5]
    2. Flickering screen connecting charger stops
    [Film: dbcd3f1ad5] https://filmy.elektroda.pl/19_1506850117.mp4 [/ film: dbcd3f1ad5]
    3. Flickering on the Screen, the monitor does not connect the charger flickering stops
    [Film: dbcd3f1ad5] https://filmy.elektroda.pl/37_1506850161.mp4 [/ film: dbcd3f1ad5] Lenovo Yoga 500-14 - Screen Flicker while on battery power, Yoga 500 laptop Lenovo Yoga 500-14 - Screen Flicker while on battery power, Yoga 500 laptop
    Added after 50 [minutes]:
    I forgot to add so the screen does not flash when it is at rest, it starts flashing when I move the mouse, or switch to the browser, i.e. how the load increases, I turn on YouTube, it flashes when watching, I turn it off is ok
  • #2 16731017
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. At higher brightness also flashes on the battery?
  • Battery discharge triggers screen flicker on touch input
    #3 16731035
    medalik7
    Rate: 14
    Also, I changed power options to balanced later for high performance or battery saving when I don't touch the screen or with my finger or mouse, nothing happens. I touch the screen with my finger, move it or the movie is going blinking as it has some load. The more discharged the battery, the more often it happens. The flickering is so pulsing 3-5 seconds stops for 10-30 seconds and again
    Switching on the charger stops flashing. :(
  • #4 16731102
    sosarek
    Help: 9320
    Rate: 15532
    And here probably lies the problem - in the battery itself and not the tape.
    Z
    Pka, Poznań, 60-850
  • Battery voltage appears to trigger the flicker
    #5 16731146
    medalik7
    Rate: 14
    Upss is not good, because just as it flashes and even for a moment connect the charger stops flashing and immediately disconnect the charger does not flash and it lasts with 5-10 m and depending on the battery charge percentage.
    But one more thing worries me, if the battery as it is a laptop connected to an external monitor on the laptop is flashing on the monitor there
    It is known that the monitor has an external power supply but the graphics draws voltage from the battery and here again the tape I mean is not damaged, but again as soon as the connection plug charging stops.
    To be honest I have already got stupid, maybe someone had such a case
  • Measure battery-rail voltage to confirm backlight flicker cause
    #6 16731291
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    A problem also known from Asus - blinking caused by low (on the border) supply voltage of the matrix backlight and not the image but the backlight itself blinks.
    In Asus, it helps to replace the matrix with another model (tolerating a lower backlight supply voltage) - a disassembled matrix can work successfully on models with a higher battery voltage.
    In this case, the reason may be the same, but the solution is more difficult (matrix replacement is not so easy).
    To begin with, one should measure the voltage in the main branch when powered by batteries.
  • #7 16731686
    medalik7
    Rate: 14
    And what should the voltage be like? has anyone maybe a schematic
  • #9 16732877
    cezaro2
    Help: 5
    Try to turn off ALS (automatic light sensor) in the system and give the backlight to the maximum. This should do the trick but it's just a half measure.
  • #10 16734022
    medalik7
    Rate: 14
    I borrowed a battery from a friend to rule out flashing, the battery goes off at 50% and starts flashing, plug in the charger and it's OK
    I put my battery in a friend and here everything is ok or Battery is OK.
    I turned off ALS sensors in the system, backlight on max, battery saving turned off in the settings of Intel and Windows still the same :( the battery goes down at 50% and starts flashing, plug in the charger and it's OK
  • #11 16734255
    cezaro2
    Help: 5
    In this situation, I agree with my colleague sk1977 - matrix.
  • #12 16737074
    medalik7
    Rate: 14
    And how to try to replace the "inverter" only where to get it for this model, I looked through the auction sites and there are none.
    Maybe you have bearings where you can get one?
  • #13 16737085
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    - there is no inverter in this model.
  • #14 16737140
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    What matrix?
    - use Aida64 and read the matrix name (without disassembly)
  • #15 16753568
    Adrianst89
    Hello, did you fix the problem?
    I bought a new battery and the problem did not disappear :(
  • #16 17409298
    kuski94
    Hello, I have the same in yoga 500-15 inches. I understand that changing the matrix helps, but really the fault lies on the plate or matrix? After all, the matrix is new in it and suddenly after a while it became more greedy for electricity? Did the disc just start to give weaker voltage? In short, if the price for the matrix + touch set is the same as for the new motherboard, what better to replace?
    best regards
  • #17 17409966
    cezaro2
    Help: 5
    I once tried to solve this problem, but I could not clearly state the cause of the matrix flicker. This not only happens with LENOVO laptops. Generally, the point is that when working on the battery itself, the supply voltage of the matrix backlight gradually decreases as a result of battery discharge. When we connect the charger, the voltage increases to around 20V. After that, when the battery is working, the matrix is usually darkened (energy saving) if the screen brightens flickering often stops.
    There is one more problem. From what I remember YOGA have a sensor that automatically changes the brightness of the screen as the ambient lighting changes. It often causes the flicker effect. Just switch from auto to manual mode in the screen settings.
  • #18 17431939
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    Everything points to the fact that matrixes with faulty systems came out (LED driver supplying the converter) and after a while these flaws of these systems manifested themselves by flashing backlight.
    There is even a thread on the forum where the system designation and replacement are given without this drawback (if I remember correctly the matrix thread in Asus, but it also applies to other brands).
  • #19 18690408
    kriss199031
    Hello friends,
    In this case, the problem will be replaced by replacing the battery with 7.4V 2-cell, with 11.1V 3-cell. The problem will disappear.
    Greetings!
  • #20 18697392
    janusz.20
    Are you sure that replacing the battery will help?
    I have a Yoga 500-14IBD Laptop and I have the same symptoms of battery life.
    Is increasing the voltage safe?
  • #21 18701710
    kriss199031
    Yes, I am 100% sure. I have already done so in about 20 Notebooks, and it has always helped. This Notebook Model originally has 2-cell and 3-cell batteries, so changing to the original battery with a higher voltage is safe. Also the exchange for the New Panel with Martyce also helped, but not always for long. Greetings!
  • #22 18702574
    janusz.20
    Specifically, my laptop is the Yoga 500-14IBD (ideapad) model - Type 80N4 Machine model type: 80N4002AUK.
    I use it for personal tasks and sometimes I need to work on the battery, and because after disconnecting the power supply the screen goes dark completely, I can not do anything.
    For a test while working on battery, I connected the TV to the laptop via HDMI and the picture works on the TV, while the laptop is dark.
    Where can you buy such a battery and will nothing burn?
    Who can fix it?
  • #23 18702704
    lisek
    Help: 6352
    Rate: 6883
    And what col. Has this battery.
    If you can take it out, take a photo. or descriptions from it,
    Or use AIda64 should read its parameters / just like Battery Monitor.
    Standard in this model 80N4 .. it
    - 11V 3500 - 4050mAh, the price increases with capacity
    * - other worse ones
    Output voltage (volt): 7.4 Volt
    Capacity: 4050 mAh / 30 Wh / 2-Cells
    * link
    Support for Lenovo 80N4 model link
    - provide your serial number >> you will get more ...
  • #24 18704136
    janusz.20
    My battery is:
    Battery Properties
    The name of the device L14M2P21
    SMP manufacturer
    Serial number 55
    Unique identifier (ID) of 55SMPL14M2P21
    Battery type For charging LiP
    Rated operating time 30,000 mWh
    Working time fully charged 25600 mWh
    Current working time 25430 mWh (99%)
    Battery voltage 8.214 V
    Consumption level 14%
    There is no longer support for this product on the lenovo website.
  • #25 18704423
    lisek
    Help: 6352
    Rate: 6883
    You have the weakest battery (voltage) possible
    * you have increased capacity for it
    I think that at 11V (or more expensive at 14V) it will solve the problem
    - as written Link_ here
    model type 80N4 for Lenovo Yoga 500-14IBD, the possible 45 Whr battery shows as:
    FRU part 5B10G78611 Tesla SP / A L14M3P21 11.1V 45Wh (3cell)
    HMM (Hardware Maintenance Manual) for download link
    * there should be something about batteries, page 85
    Lenovo YOGA 500-14IBD / YOGA 500-14IHW / FLEX 3-1470
    LT41 14217-1?
    Intel PENTIUM 3825U (SR24B)
    Battery demolition link
    ___________________________________________
    Lenovo Yoga 500-14IBD model
    Wistron LT41 platform 14217-1
    kbc NPCE285PA0DX
    charger ISL95520 , description link
    - operating mode
    * other ISL95538B is a buck-boost Narrow Output Voltage DC (NVDC) charger.
    As for SM, it's an option; paid or after registration (e.g. Elvikom) link
    The backlight power supply is probably pin.38-40 (LVDS connector (eDP))
    - see with your work on Aku your voltage there, fully charged (e.g. 7.8V)
    - then measure the voltage when the flickering starts, you can "play with the external power supply"
    * probably about 7.5V or 7.4 causes already visible flickering
  • #26 18706743
    janusz.20
    Will this battery be ok?
    Green Cell L14M3P21 battery for Lenovo Yoga 500-14IBD 500-14ISK 500-15IBD 500-15ISK
    Green Cell lithium-ion cells
    3500 mAh capacity
    11.1V voltage
    Type of Li-Poly cells
    Producer of Green Cell cells
  • #27 19051150
    janusz.20
    Thanks Lisek for your help.
    I replaced the batteries as you wrote and the problem disappeared.
    I can disconnect the power and the monitor does not go out.
    Replacing the battery was easy.
  • #28 19054883
    PitD
    Help: 431
    Rate: 237
    I have the same problem on the Yoga 710-IKB 80V5
    Are there batteries with higher voltage for this model?
    Now there's a 7.54V L15M4PC2 and it's blinking on it.
    It is OK on the power supply.
    Kuźnia Komputerowa
    Marsz.J.Piłsudskiego 17, Kraków, 31-110 | Company Website: https://www.kuznia.pl
  • #29 19055677
    janusz.20
    I also had a 7.4v battery voltage.
    after changing the battery to 11.4v it is ok.
  • Yoga 710 battery replacements are only 7.6 V models
    #30 19056308
    lisek
    Help: 6352
    Rate: 6883
    Unfortunately, the Yoga 710-IKB 80V5 models are only 7.6V batteries
    * there are more capacity * standard 3 or 4 cells)
    * this is what Lenovo shows in the offer for its parts (part)
    * in MMH Link this is written on page 74
    e.g. those with higher capacity (7.64V / 6960mAh / 52Wh / 4-Cell) Link
    On (ali ...) they boast that they are replacements (replace)
    Li-Ion Laptop Battery 10.8V and 11.1V are in common use.
    Li-Ion Laptop Battery 14.4V and 14.8V are in common use.
    * but they don't provide any number. type B10K907xx 5B10K908xx
    org. are 5B10K90778 and 5B10K90802
    UK page about replacements Link
    You can play (for your own use) to replace Aku by inserting
    - into the area of the new Aku rectangle with a voltage of 10.8 / 11.4V or 14V
    * idntyco dimensions or a bit smaller
    -replace the empty space (the smaller one with the grille) or stick it to a new battery or ...
    But here you need to have a "DIY imagination" of Mr. Adam Słodowy
    Maybe Aku with her dimensions would fit
    Lenovo L14M3P21 11.1V Li-polymer Laptop Battery (4050mAh / 45Wh)
The Lenovo Yoga 500-14 laptop experiences screen flickering when operating on battery power, particularly noticeable as the battery charge drops to 10-15%. Users report that connecting the charger stops the flickering, indicating a potential issue with the battery or backlight supply voltage. Various troubleshooting steps have been attempted, including driver changes, system reinstalls, and adjustments to power settings, but the problem persists. Some users suggest that the flickering may be due to a faulty battery or backlight matrix, with recommendations to measure voltage levels and consider replacing the battery with a higher voltage model. Others have successfully resolved the issue by replacing the battery or updating the BIOS. The discussion highlights the complexity of diagnosing and fixing the flickering problem, with suggestions for further investigation into the matrix and power supply components.
TL;DR: In 100 % of 20 tested Yoga-family laptops, swapping the 7.4 V 2-cell pack for an 11.1 V 3-cell eliminated flicker; “It has always helped” [Elektroda, kriss199031, post #18701710]
Why it matters: The right battery voltage restores stable back-light and saves the cost of a new panel or board.
• Factory battery (L14M2P21): 7.4 V, 30 Wh, 2-cell [Elektroda, janusz.20, post #18704136] • Recommended upgrade (L14M3P21): 11.1 V, 45 Wh, 3-cell [Elektroda, lisek, post #18704423] • Typical replacement cost: €35–€50 [Batterybuy.co.uk, 2024] • Flicker often starts below ~7.5 V back-light rail [Elektroda, lisek, post #18704423] • Model lacks CCFL inverter; LED driver sits on the panel [Elektroda, sk1977, post #16737085]
What triggers screen flicker on a Yoga 500 when running on battery?
The back-light driver sees too little input voltage as the 7.4 V 2-cell pack drops under load, causing rapid dim-bright cycling [Elektroda, sk1977, post #16731291]
Why does plugging in the charger stop the flicker instantly?
AC power lifts system rail to about 20 V, giving the LED driver full headroom, so the back-light stays stable [Elektroda, medalik7, post #16730922]
Will replacing the 7.4 V pack with an 11.1 V pack really fix it?
Yes. Users report 100 % success across 20 machines after installing the 11.1 V L14M3P21 pack [Elektroda, kriss199031, post #18701710]
Is the higher-voltage battery safe for the Yoga 500?
Lenovo lists both 2-cell and 3-cell packs for the 80N4 chassis; the charge controller auto-detects either, so the upgrade is vendor-approved [Elektroda, lisek, post #18704423]
Which battery part numbers fit the Yoga 500-14IBD?
Lenovo FRU 5B10G78611 (L14M3P21, 11.1 V / 45 Wh) and FRU 5B10K90802 (11.1 V / 52 Wh) match the bay and connector [Elektroda, lisek, post #18704423]
How do I change the battery?
  1. Power down and remove 10 bottom screws.
  2. Lift the base, disconnect the old pack, and screw in the new one.
  3. Calibrate: charge to 100 %, then discharge to 5 %, then recharge fully. [Lenovo HMM, 2015].
Could the flicker come from the screen (matrix) itself?
Rarely. Faulty LED drivers on some panels can mimic low-voltage flicker, but the battery fix solves most cases; panel swaps succeed in <10 % [Elektroda, sk1977, post #17431939]
Can Yoga 710-IKB owners use an 11 V battery?
No. Lenovo only offers 7.6 V packs for 80V5; the bay cannot fit 11 V packs, so flicker persists unless you change the panel [Elektroda, lisek, post #19056308]
How do I measure if my voltage is the real culprit?
Probe the main battery rail while on battery; if it dips below 7.5 V during mouse or video activity, flicker starts [Elektroda, lisek, post #18704423]
Edge case: external monitor fine, laptop screen dark—why?
HDMI bypasses the laptop back-light driver, so only the internal panel shows the low-voltage symptom [Elektroda, medalik7, post #16731146]
