Siemens EQ5 Macchiato: Coffee Dispensing from One Nozzle After Grinder & Seal Changes
morphinestar 14547 10
How can I fix a Siemens EQ5 Macchiato that dispenses coffee only through one nozzle and leaves wet grounds?
The most likely fix is to clean the coffee spout/dispenser first, and replace it if the internal screen/screed is warped or packed with sludge. The thread says the spout can be cleaned, but if it has overheated and deformed inside, a new one is recommended because the part is cheap [#16225671] One user reports that after dismantling the spout, it was full of smelly sludge; replacing it solved the one-nozzle flow problem [#18483394] Cleaning is best done after disassembly: open both halves carefully with a knife, separate the latches, and clean mechanically rather than relying only on chemical cleaning [#16816805] Another reply mentions hot water, cleaning chemistry, and a pressurized nozzle, plus keeping up with regular cleaning cycles and rinsing after use [#16225671]
  • #1 16214811
    morphinestar
    I have a Siemens EQ5 Macchiato coffee machine in which I recently exchanged min. grinder, orings and seals. However, for several weeks the problem is that during brewing coffee flies through only one nozzle.
    I do not know if this is a matter of the brewer, which, as you told me on the site in the near future is to be replaced or the problem lies in something else. I spent PLN 900 for the last repair.
    If this is a brewing issue, I am able to spend another PLN 300. The only question is whether the next thing will not break again ... I will mention that the problem (smaller) are also poorly compacted and wet grounds. Repair or buy a new one?
    What espres do you recommend? EQ5 Macchiato, EQ6 or maybe another one?
    I am asking for help as soon as possible.
  • #2 16214914
    BRum
    Help: 42
    Rate: 388
    Like the new espresso machine, it's just a Jura. In EQ5 cleaning the screed is possible, it requires some patience.
  • #3 16215190
    morphinestar
    Anyone know how to clean such a screed? Any tips on removing screeds? I saw on the internet that there are special cleaning wipers, anyone used?
  • Clean or replace distorted brew screed and maintain rinsing cycles
    #4 16225671
    axdm56
    Rate: 35
    Cleaning the screed is possible - if, of course, the screed has not warmed up and distorted inside - then we recommend a new one - a small cost.
    We have never used cleaning rods, rather chemistry, hot water and a pressurized nozzle - and above all, it is necessary to observe a cyclic cleaning cycle, and remember to give the coffee machine a chance to rinse after making coffee and putting it away for longer.
  • #5 16816805
    dzieju_2004
    Rate: 19
    Spout after dismantling looks like this:
    https://north.pl/karta/zestaw-naprawczy-do-ek...wy-siemens-te506509de-05,CB9-DR-CMM0-DPP.html
    You have to open both parts with a knife and separate the latches. Without undressing it is difficult to find out the reason. I have snakes dropped. Chemical cleaning is a defeat, the ramrod will definitely blow the tubing off the tips. Cleaning is better after demolition. Siemens EQ5 Macchiato: Coffee Dispensing from One Nozzle After Grinder & Seal Changes Siemens EQ5 Macchiato: Coffee Dispensing from One Nozzle After Grinder & Seal Changes Siemens EQ5 Macchiato: Coffee Dispensing from One Nozzle After Grinder & Seal Changes
  • #6 17146227
    doubleube
    Help: 5
    Rate: 27
    I warmly welcome,
    How do you remove the spout from the machine?
    a latch downstairs, but he fell inside :(
    on the back I removed a frame and the door, and what next?
    model TE506209
  • #7 17149008
    dzieju_2004
    Rate: 19
    From what I remember, the front (after opening the door) is simply pressed into place, it must be gently prized. Regards,. Andrew.
  • #8 17149017
    doubleube
    Help: 5
    Rate: 27
    I just don't go, the door is removed, tugs, I undermine something and nothing
    It's on your back with six clamps,
    but they don't let go
  • #9 17151098
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3337
    Nzie has nothing to worry about. The demolition espresso machine is constructed in such a way that it is practically unrealistic at the debut that the casing does not break somewhere ..
    With a feeling that damage is as small as possible ;)
    Kawa i Naprawa - Serwis AGD
  • #10 17151185
    doubleube
    Help: 5
    Rate: 27
    The repaired machine, I replaced the coupling, i.e. the plastic funnel to which the boiling water comes :)
    And the spout by the way was needed to open, because I squeezed in that led what is at the bottom, by the way cleaned.
    These clamps held as if stuck, something broke down, but after folding it holds
  • #11 18483394
    tgamalski
    Rate: 17
    I also didn't fly through one nozzle. I bought a new spout. I decided to dismantle the old one to see what happened. It was full of smelly sludge. For some time I did not like coffee from the espresso machine and I did not drink it, blaming the quality of the coffee itself. Now I know what it was. I will replace this spout once a year. Reaming nozzles can help, because they are in the form of a strainer and not everything will pass through it. And that was how it looked inside.
The discussion revolves around issues faced with the Siemens EQ5 Macchiato coffee machine after recent repairs, including grinder and seal replacements. The user reports that coffee is only dispensed from one nozzle, raising concerns about whether the problem lies with the brewer or other components. Suggestions include cleaning the screed, which can be done with chemical solutions or by disassembling the machine for thorough cleaning. Users share experiences of replacing parts like the spout and recommend regular maintenance to prevent sludge buildup. The conversation also touches on the difficulty of disassembling the machine and the potential need for further repairs or a new machine, with inquiries about other models like EQ6.
