Siemens EQ.5 Macchiato Plus (TE515209RW/05) - Coffee Output Reduced, Clear Water in Collector
KaffeHarry 1356 0
  • Likely pump or flow restriction causing weak brew output
    #1 20358958
    KaffeHarry
    Hello Friends! I have a first gen. Siemens EQ.5 Macchiato Plus, 2017. TE515209RW/05. It has served us well, and I can understand that she (the machine) is tired, and a bit degenerated. Anyhow, I want to help her up again, to do what she loves: to make coffee. Description of problem; a few weeks ago, the amount of coffee coming out started to be smaller - roughly 50% of normal volume. One week later, nothing comes out. The machine is still brewing, but the water goes down in the collector. And the water is clear, meaning that it is not pressed through the grinded coffee beans. I have cleaned the machine, also the brewing unit. There is no stenosis on the tubes as long as I can find. I have talked with a technician, he sent me a new brewing unit. I just tested it: coffee comes out, yes (smile), but it's small amounts, I would say less than 50% of what should come out. So anyone: have you experienced something similar? I would be very thankful for tips and tricks! I wish you all a happy new year! Sincerely, Harald - Norway
    Update: UPDATE: And now, after 3-4 half filled cups, it's had again stopped. Nothing comes out, (with the new brewing unit..)..
