Ferguson Ariva T750i - You can't watch anything through Wi-fi
janomo 11214 4
  • #1 16220953
    janomo
    Help: 45
    Rate: 247
    The decoder is working properly, there is only a problem with the internet.
    This STB has the ability to watch content from the Internet, e.g. Youtube using the attached Wi-fi adapter. Unfortunately, this adapter probably doesn't work. The USB stick connected is working properly. The adapter connected to the computer is detected. Unfortunately, after connecting to the decoder and when running anything related to the Internet the decoder signals that you need to connect it to the adapter that is connected after all! I updated the software - it didn't help. Maybe someone knows why it doesn't work?
  • #2 16220971
    kindlar
    Help: 919
    Rate: 1624
    Page 23 of the manual http://www.ferguson-digital.eu/?wpfb_dl=802. What steps did you take at home? Is your network addressing automatic or fixed addresses fixed? Enter ipconfig / all on the computer in cmd and show the result.
  • #3 16221362
    janomo
    Help: 45
    Rate: 247
    Automatic network addressing - not working. I haven't tried rigidly yet, I will check in my free time.
    Thank you.
  • #4 17077421
    pioteer66
    Rate: 17
    Wifi in the T750i works with the Ferguson W03 wifi antenna without any problems (or others on RT5370). I tried on the tp link did not move on W03 without a problem. The tuner has 1 usb socket. It works on my hub without additional power supply. At the same time the wifi antenna, tough USB 1 tera and 64Gb usb3 pendrive.
  • #5 17079274
    LeDy
    Help: 1995
    Rate: 2946
    W03 External wireless network card working in IEEE 802.11b / g / n standard. Security: WEP, WPA, WPA2 and IEEE 802.1x. Full compatibility with Ferguson devices from Ariva (102 cable, 102mini, 102E, 150 combo, 202E, 250 combo, 52E) The decoder must detect it, if you have a WiFi router you must still enter the router data (password, login).
