Replacing Fuel Pump Motor in 1999 Golf 4 1.6 SR 8V: 1J0 919 051H/Pierburg 7.00468.84, Diagnosis
zbigniew9 7338 4
  • #1 16223968
    zbigniew9
    Rate: 20
    I plan to replace the fuel pump (motor) in Golf 4 1999 1.6 SR 8V. I can technically handle the spacer. On the Internet I found the designation of the pump set
    1J0 919 051H / Pierburg 7.00468.840.
    I am only interested in replacing the pump motor (does not require), it does not smoke on the first shot. Mechanic diagnosis, ignition coil. Another mechanic's opinion is the fuel pump, namely the engine. Does not "hold fuel", gasoline flows back into the tank. Who to listen to? Is the motor itself marked?
  • #2 16223982
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6433
    Then buy a pompe, you probably can if you have the numbers.
  • #3 16224016
    zbigniew9
    Rate: 20
    I am interested in the new pump motor, its designation.
  • #4 16224028
    Help: 1405
    Rate: 6433
    And what he looks like, nobody has ever seen him.
    Why do you go to the store and buy.
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    The original pump - the first installation is from VDO (and I recommend it), the rest are substitutes ...
