Injection Pump AFN 110 kn: 1.9 TDi 110km vs. 90 HP Golf Version - Efficiency, Power & Compatibility
jacek.nowonskiacek49 8754 5
  • #1 17010592
    Hello!
    I am the owner of 1.9 TDi 110km. Recently, my injection pump has failed. Its numbers are 0 460 404 972/038 130 107B. I can't find such a pump anywhere. My friend has a pump from a 90 horse version of golf. injection angle adjustment is of course on the so-called beans. My question. Is this pump less efficient than the pump I currently have? Will the installation of this pump reduce the car's power?
    Thank you in advance for your answer.
  • #2 17011020
    żałosna udręka
    Help: 191
    Rate: 1019
    The piston diameters were different and therefore did not fit. Give the numbers of the latter. What fell there?
  • #3 17011210
    kakibara
    Help: 201
    Rate: 1275
    He has a 10 - and he has to look for one, the efficiency is slightly different, there are other springs - but it has not been said that you will feel the differences may even be a plus and may fire better compared to your pump.
    Combustion will remain at a similar level, power? Maybe you will feel a slight difference.
    Pump from 1z / ahu fits.
    From the Golf 4, there was probably a different mount and plug to check.
  • #4 17011430
    Generally, on a cold engine, it fires relatively. The problem starts when the engine is well warmed up and then it wants to start it. Sometimes it spins almost 15s. I was at the pump operator and he told me that the cost of regenerating the element could be high and he suggested that I look for another pump somewhere. Cheaper solution. I was already at a few points and I will say that it is hard to find a pump from the 110 HP version of the 1.9 TDi group. They are more common than the weaker versions (90 horse). And I am only concerned with whether the pump from these weaker engines, although it will work as needed, will weaken the drive unit in my car and whether the computer will not have any protests after connecting it to the ankles.
  • #5 17012237
    kakibara
    Help: 201
    Rate: 1275
    Enter the vw forum you will see hundreds of similar problems there.
    1 - there is a temperature sensor in your pump, did you check it on the computer? Maybe he can see high temperature all the time? It is under the positioner cover.
    2 - disconnect the liquid temperature sensor - what reaction?
    3 - changing the pump may not help in your case - the dose in your map may be a problem - i.e. someone who writes programs may modify it for you.
  • #6 17012257
    żałosna udręka
    Help: 191
    Rate: 1019
    Or it has deep scratches on the adjuster. Anyone been there? Or just misaligned.
