Peugeot 607 2.2 HDI Fuel Pump Issue: Original vs Replacement, Non-stop Humming & Frequent Breaks
marcin-mkpeugot 11253 18
Should the fuel pump in a Peugeot 607 2.2 HDi run continuously after the engine starts, and what should I check if replacement pumps keep failing?
The tank fuel pump should run continuously while the engine is running; a short buzz at ignition is normal, but once started it is expected to keep humming [#16792047] If the pump is noisy, intermittent, or keeps dying, check the power supply first: the connector under the rear seat, burnt or broken wires/contacts, the double relay, and the fuses [#16792047] [#16793681] [#16793788] A direct test with long wires straight from the battery can separate a bad pump from a wiring/relay fault; if it runs properly that way, the problem is in the circuit, not the pump [#16793681] [#16793788] Also make sure the replacement is the correct pump type and connector orientation, because the thread warns about wrong/cheap replacements and vertical-plug versions causing trouble [#16792047] [#16793086] In this case, fitting the original pump restored quiet, normal operation [#16796764] [#16805360]
  • #1 16791199
    marcin-mkpeugot
    Hello, I have a Peugeot 607 2.2 HdI and I have a problem with the fuel pump, since the original got out, they installed a replacement for me, which after 3 days went out, and now some other one has come out. I am wondering whether the pump (under the rear seat) should work all the time (humming) or only moments after turning on the ignition. Personally, it seems to me that the original did not work all the time and these two replacements were running all the time. Help because I have no idea. They replaced the valve on the strip, the filter and the filter housing and it was a good week but the pump was humming under the rear seat non-stop.
  • #2 16791267
    spinacz
    Help: 1204
    Rate: 2654
    The pump also works without a key in the ignition switch?
  • #3 16791869
    marcin-mkpeugot
    no, if I turn the ignition on, it will buzz and go out for a few seconds, but when the car fires, it hums all the time much louder than the original, which was not heard while the engine was running
  • #4 16792047
  • #5 16792789
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    Or maybe the reason lies in the control of the pump? Are you sure that if you don't hear the pump, it gets the power?
    It is also worth seeing what you have in the tank, whether it is clean.
    And as a colleague wrote above, check if the connector is burnt.
  • #6 16792824
    andrzej20001
    Help: 1578
    Rate: 6669
    Pumps are installed in a proprietary manner, not just the reason.
  • #7 16792871
    kkknc
    Help: 1915
    Rate: 6709
    Probably too cheap pump or burned out contacts. A cheap pump for cars without DPF is PLN 200 and less, but the company is about PLN 600
  • #8 16793086
  • #9 16793439
    marcin-mkpeugot
    Colleagues, thank you for the ideas, I am grateful, but I would reject the plug defect because I do not see anything melted or black and it did not help when I moved the plug. I have just ordered the original BOSCH as it should be installed right away and we'll see. I am terribly surprised, however, that the pump still fails, despite the fact that it was a replacement, it would happen after less than a week, both replacement did not last longer ...
    Added after 9 [minutes]:
    So tomorrow there should be a new pump and I will keep you informed about what and how if it fails again after a week, I have no idea what's going on ... Regards and if you have any other ideas, I would like to read
  • #10 16793681
  • #11 16793688
    andrzej20001
    Help: 1578
    Rate: 6669
    The pump does not rain since the power failure
  • #12 16793788
  • #13 16793811
    andrzej20001
    Help: 1578
    Rate: 6669
    This does not explain to me after a quarter of a century of work. Pumps are not changed without checking power
  • #15 16793847
    marcin-mkpeugot
    Thanks colleagues, but the CPIP relay, each time after switching on the ignition, the fuses were checked, and when it stopped working, it was helped by tapping the pump with a fist twice, but after two such cases it started to work slower and loudly and the car went out while driving (I heard first that the pump "died") and this time no knocking and none of these things helped.
    kkknc
    Help: 1915
    Rate: 6709
    Driving on the reserve also cuts the pumps.
  • #17 16794078
    marcin-mkpeugot
    It happened to me max 3 times in reserve and after lighting up immediately I went to the cpnu and popki got off at 1/2 fuel tank
  • #18 16796764
    marcin-mkpeugot
    Hello, I picked up the original, so far it is quiet and ok, nothing buzzes, everything works quietly. Thanks for the hints
  • #19 16805360
    marcin-mkpeugot
    Good advice, if you have such a problem, let no one press you replacements, two replacements, there were still problems. I put the original on and the problem is gone.
The discussion revolves around a fuel pump issue in a Peugeot 607 2.2 HDI, where the original pump was replaced twice, both replacements failing shortly after installation. Users clarify that the fuel pump should operate continuously after the engine starts, unlike the original which was quieter. Suggestions include checking the power supply, connectors, and the pump's compatibility with the vehicle's specifications. The author ultimately decided to install an original BOSCH pump, which resolved the humming issue and restored normal operation. The importance of using the correct pump type and ensuring proper electrical connections was emphasized throughout the conversation.
TL;DR: On the 2.2 HDi, 1 in‑tank pump runs continuously once the engine starts; “The electric pump in the tank works non‑stop after starting the engine.” [Elektroda, Anonymous, post #16792047] Why it matters: This FAQ helps Peugeot 607 owners diagnose nonstop humming, repeat pump failures, and pick the right replacement.
Should the Peugeot 607 2.2 HDi lift pump hum all the time?
Yes. After priming at key‑on, the in‑tank electric pump runs continuously while the engine runs. If it stops, the engine cuts out due to fuel starvation. “He has to work all the time.” [Elektroda, Anonymous, post #16792047]
Why is my replacement pump louder than the original?
Some aftermarket pumps are noisier under load, and wiring stress from a vertically oriented lid can amplify noise. Continuous humming with the engine on is normal, but excessive loudness may hint at poor-quality parts or wiring strain under the seat. [Elektroda, Anonymous, post #16792047]
How do I quickly test if the pump or its power supply is at fault?
Do a direct battery test to bypass the double relay and fuses. 1) Run two long leads with insulated clamps from the battery. 2) Connect to the pump terminals briefly. 3) If the engine starts and runs smoothly, the pump is OK; investigate the relay/circuit. [Elektroda, Anonymous, post #16793681]
What is the “double relay” on this car?
It’s a combined relay module that feeds the pump and other engine circuits. Burned or tarnished contacts cause intermittent pump operation and stalls. A direct battery test helps confirm if the relay is the bottleneck. [Elektroda, Anonymous, post #16793788]
Can the connector under the rear seat cause repeat failures?
Yes. A vertical plug can be pressed by the seat cushion, bending wires until they break. This leads to power loss, arcing, and burned connectors. Reorienting or replacing the lid with a horizontal plug prevents recurrence. [Elektroda, Anonymous, post #16792047]
Is an OEM Bosch pump really better here?
In the reported case, two replacements failed in under a week, while an original Bosch restored quiet, stable operation. The owner’s final update: “I put the original on and the problem is gone.” [Elektroda, marcin-mkpeugot, post #16805360]
How long should the pump run at ignition before starting?
It should buzz for a few seconds at key‑on, then stop until the engine starts. Once running, it should hum continuously. A much louder tone than the original indicates quality or installation issues. [Elektroda, marcin-mkpeugot, post #16791869]
Could low fuel level contribute to pump damage?
Yes. Driving on reserve can overheat and “cut” pumps because the unit loses cooling and lubrication from fuel. Keep at least a quarter tank to protect the pump. [Elektroda, kkknc, post #16793894]
What if tapping the pump makes it work again?
Temporary recovery after knocking points to a failing pump or sticking internals. Once noise increases and stalls occur, replacement is due. Verify supply first, but expect imminent failure if knocking is needed. [Elektroda, marcin-mkpeugot, post #16793847]
How do I fix wiring stress from the seat on the pump lid?
Replace the lid/cover so the electrical plug sits horizontally. This removes seat pressure, preventing wire bending and future breaks. Users reported permanent resolution after this orientation change. [Elektroda, Anonymous, post #16793086]
What’s a realistic price signal for pump quality?
Expect around PLN 200 for budget units and about PLN 600 for reputable brands. The large price spread reflects durability and noise differences. “A cheap pump … PLN 200 … company about PLN 600.” [Elektroda, kkknc, post #16792871]
My pump keeps failing every week. What should I check first?
Confirm power supply integrity with a direct battery test, then inspect the seat‑side connector for burns and broken wires. If wiring is fine, install a quality pump and a horizontal‑plug lid to remove mechanical stress. [Elektroda, Anonymous, post #16793681]
Can I replace just the lid/cover instead of the whole pump?
Yes. One user retained the original pump and swapped only the lid with the plug and fuel connectors. Be careful with stiff internal lines; warming them helps removal and refit. [Elektroda, Anonymous, post #16793086]
What outcome did the thread author report after going OEM?
He installed the original pump and reported quiet, stable operation with the humming gone. He advised against pushy aftermarket replacements based on his repeated failures. [Elektroda, marcin-mkpeugot, post #16796764]
Statistic: how many failures were seen before the fix?
Two aftermarket pumps failed in less than a week each. Switching to the original Bosch resolved the issue long‑term. This indicates quality and compatibility matter more than price alone. [Elektroda, marcin-mkpeugot, post #16793439]
Edge case: the pump primes but the car still stalls—why?
Intermittent relay contacts or a clogged pre‑filter under the pump can mimic a dying pump. If the engine still hesitates with the pump hard‑wired, inspect the pre‑filter and relay next. [Elektroda, Anonymous, post #16793788]
