Bosch Screwdriver Bits and Sockets Set: Seeking 13mm+ Options Under PLN 100 for Bosch 2607017164
Sebikxx 4977 6
  • 13 mm socket set needed under PLN 100
    #1 16548465
    Sebikxx
    I recently bought a Bosch screwdriver to have a household tool. I am now looking for a set of bits and sockets for this drill. I have found as interesting zestawik TERMINALS-screwdriver bit / Bosch-2607017164-43-czesci.bhtml? Gclid = CjwKEAjwm7jKBRDE2_H_t8DVxzISJACwS9WbunOnZJwahZGWDubMgpDb-QvtcZiuxqXW32Z_zLXAChoChC3w_wcB & gclsrc aw.ds = & = DCLID CI6Qw-rh1tQCFUSHsgodpBUA7w unfortunately cap is 10mm max and I am looking for a minimum of 13mm. The price is up to PLN 100.
  • #2 16548478
    kokapetyl
    Help: 1787
    Rate: 2101
    Sebikxx wrote:
    the cap is max 10mm and I'm looking for a minimum of 13mm
    Are you sure what you are writing?
    This screwdriver of yours, what is the maximum distance between the handles?
  • Clarifying magnetic socket attachment type
    #3 16548645
    Sebikxx
    I mean attachments of this type https://toya24.pl/product-pol-10004441-Nasadka-magnetyczna-do-wkretarki-1-4-8x48-mm.html. Earlier badly pasted bad link from a set that interests me because I throw again https://m.euro.com.pl/wiertla-i-koncowki-wkre...bNnV1dZSZUOLjc3O7efZsNV3RoC46Pw_wcB&gclsrc=aw .ds & dclid = CLWJ98n21tQCFQqZsgodWgYGyA
  • #4 16548727
    marek49ae
    Help: 57
    Rate: 254
    Buy an adapter for socket wrenches, and you will fasten the sockets you have.
  • #5 16548780
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Probably the best adapter of this type and you put on the socket you want (even from the sockets you have) and let the screwdriver pull.
  • #6 16548852
    Sebikxx
    And what set of bits up to PLN 100 do you recommend?
  • #7 16549024
    marek49ae
    Help: 57
    Rate: 254
    Buy such a handle Bosch Screwdriver Bits and Sockets Set: Seeking 13mm+ Options Under PLN 100 for Bosch 2607017164 and also bits for pieces as needed. I buy Stanley or Milwaukee for the screws, I work with them a lot, they are PLN 2-3 each. The rest are some, I rarely use them, so I don't need quality. All I can see is that Dewalt's are at a decent price.
The discussion revolves around finding a suitable set of screwdriver bits and sockets for a Bosch screwdriver, specifically seeking options that include a minimum 13mm socket and are priced under PLN 100. The user initially considered a Bosch set (2607017164) but found its maximum socket size to be 10mm. Suggestions include purchasing an adapter for socket wrenches to utilize existing sockets, and recommendations for individual bits from brands like Stanley, Milwaukee, and Dewalt, which are noted for their affordability and quality.
