Allegro Caliper Review: Evaluating 0.02mm Accuracy & Comparison with Higher-priced Options
grzesio119 6192 13
Can I use a cheap 0.02 mm caliper for small measurements like checking a drill bit diameter, or should I buy a more expensive one?
Yes, a cheap 0.02 mm caliper should be enough for checking drill bit diameters and other basic home DIY measurements [#16244198][#16244290][#16309634] For normal use, an electronic caliper is a good choice, but if you need more accurate measurements, a micrometer is better [#16249923] Treat the caliper carefully because cheap models are fragile and can be damaged if thrown into a drawer with tools or used roughly [#16248272] Cheap electronic calipers also tend to drain batteries quickly, so it is worth removing the battery after use [#16248950] Do not use the jaws as a stylus [#16248950]
  • #1 16226742
    grzesio119
    Rate: 8
    Will the allegro caliper for PLN 17 with an accuracy of 0.02 mm be a good indication? Is it better to invest in something more expensive / better? The caliper will be used for small measurements, e.g. checking the size of a drill.
  • #2 16226811
    leonov
    Help: 1039
    Rate: 2248
    grzesio119 wrote:
    e.g. checking the size of the drill
    This is what it will do ;-)
  • #3 16236953
    Pomocyyyy
    I think it will be suitable for small housework
  • #4 16244198
    plm2052
    Rate: 38
    If you will use it to check the diameter of a drill, it will probably work. After all, drill bits have sizes such as 4, 4.5, 5, 5.5, etc., so even if your result is distorted, you will get closer.
  • #5 16244220
    płetwa
    Help: 165
    Rate: 551
    It's interesting what my colleague wrote above, because I have access to drills every 0.1mm?.
  • #6 16244290
    anders11
    Level 30  
    Help: 197
    Rate: 204
    In home DIY, it will work better than 0.1mm, and yes, no
    you will be able to get it without specialized machines and tools
    plm2052 wrote:
    After all, drills have sizes such as 4, 4.5, 5, 5.5, etc.
    Did your colleague hear about the diameters of the threading holes?
  • #7 16248272
    13Rycerz
    Rate: 9
    It should do.
    Such small measurements can be made with a simple caliper.
    You must remember that each caliper is "fragile" and prone to damage. Do not put such a caliper under a pile of drills / keys etc. because irreparable faults will occur.
    Don't throw a caliper
    Do not hammer any nails with it c: (little sister got a toy like this once)
    Please respect the caliper and it will serve you for several years.
  • #8 16248950
    tzok
    Help: 3176
    Rate: 6549
    It will be fine, but remember that most of these cheap electronic calipers discharge the batteries at an alarming rate - the switch only turns off the display. Also, after finishing work, it is worth removing the battery from the caliper. On the other hand, a mechanical caliper must be known to use ;)
    I would add one more thing to my reservations - do not use the caliper jaws as a stylus.
  • #9 16249923
    tomiok
    Help: 133
    Rate: 292
    grzesio119 wrote:
    Will the allegro caliper for PLN 17 with an accuracy of 0.02 mm be a good indication? .
    For normal use, take an electronic caliper.
    For more accurate measurements, look at the micrometer.
  • #10 16309634
    nadchloran
    Rate: 17
    I recently bought an electronic caliper on the Allegro for PLN 30 and it is irreplaceable for basic measurements.
  • #11 16311276
    nikson1970
    Buy yourself a wurth caliper cheap and it measures like a micrometer, I use it to measure the coil wire
  • #12 16311779
  • #13 16318048
    nikson1970
    As electronic as possible, you will even be able to measure winding wires
  • #14 16318661
The discussion evaluates the Allegro caliper priced at PLN 17, which offers an accuracy of 0.02 mm, primarily for small measurements like drill sizes. Participants generally agree that it is suitable for home DIY tasks, especially for measuring standard drill bit sizes. However, they caution about the fragility of electronic calipers and the need for careful handling to avoid damage. Some users recommend considering more expensive options or mechanical calipers for higher accuracy, while others share positive experiences with similar electronic calipers for basic measurements. Concerns about battery life in electronic models are also noted, suggesting that users should remove batteries after use to prolong lifespan.
