dyzio-dyzio wrote:It has to be pretty or accurateWhich electronic caliper should be chosen up to PLN 120 (PLN 80-120), which company do you recommend?
Freddy wrote:Cheaper than what? You don't know what the author found.
dyzio-dyzio wrote:I was looking for and found something like this: ELECTRONIC caliper 150mm Corona C3431 0.01mm:
Characteristic
length 150 mm
accuracy 0.01 mm
LCD display
measurement in mm and inches
has the CE mark
I think that for my hobby applications it will be ok
made of steel
plastic case
Freddy wrote:Not true - Mitutoyo ABsolute Digimatic series.
mariuszp19 wrote:A colleague will learn to read and understand what I have written.I think my colleague did not read something. ... Besides, the measurement uncertainty was mistaken for repeatability
Quote:I, on the other hand, to learn culture(I refer to reading).
mariuszp19 wrote:This is not true and I wrote that too.Generally no calipers does not measure with a measurement uncertainty of 0.01mm.
Freddy wrote:I know what I am writing and I distinguish between terms.
Freddy wrote:This is not true and I wrote that too.
Freddy wrote:Let a friend read what he writes sometimes, but with understanding.
Bieda z nędzą wrote:Two hundred doughs is none. I had such for a hundred (with Hart), I had such for two hundred, I don't remember the company. Either the battery lasted a month, or the guard on the guide rubbed off. When they opened them quickly, I had stupid things on the display.
I bought from Mitutoyo, it really measures, but I don't like it anyway. I prefer the regular one with the vernier.
TL;DR: For hobby work, a PLN 30–120 digital caliper typically holds ±0.3 mm accuracy, "good enough for occasional checks" [Elektroda, mariuszp19, post #16290861]; spend more (PLN 250) only if you need certified ±0.02 mm Mitutoyo precision [Elektroda, rubens, post #16309624] Why it matters: Matching tool accuracy to your project saves money and prevents assembly errors.
• Budget range discussed: PLN 30–120 for hobby metal units [Elektroda, Freddy, post #16284870] • Display resolution on most low-cost models: 0.01 mm [Elektroda, dyzio-dyzio, post #16289794] • Realistic measurement uncertainty: about ±0.3–0.4 mm for cheap units [Elektroda, mariuszp19, post #16290861] • Certified Mitutoyo Absolute Digimatic accuracy: ±0.02 mm; battery life ≈3.5 years [Mitutoyo Cat.]. • Typical coin cell: SR44; many budget calipers drain in <1 month of heavy use [Elektroda, Anonymous, post #16309205]
