Keyboard and mouse not working - The USB keyboard and mouse do not work
MontyHD1 4419 4
  • #1 16898643
    MontyHD1
    Recently, I changed the operating system from win 7 to win 10
    While everything was fine, today there was a problem, namely
    I had the USB mouse and keyboard connected to the USB on the back panel of the computer
    When I turned on the computer and the model and manufacturer of the motherboard appeared, the keyboard and mouse turned on, but with the appearance of the Windows logo, it stopped shining and working
    When I connected them to the front panel, they started to work normally, but still do not work on the rear panel
    I'm gonna have it hooked up at the back
    I am waiting for proposals.
  • #2 16898652
    Kasek21
    Help: 4981
    Rate: 3547
    What is this motherboard model?
  • #3 16898674
    MontyHD1
    It is:
    Asus P7H55D-M PRO
  • #4 16898684
    Kasek21
    Help: 4981
    Rate: 3547
    Keyboard and mouse not working on all USB connectors on the rear panel?
    Can you get into the BIOS?
    The connected USB flash drive to the rear panel is visible in the BIOS?
  • #5 16898709
    MontyHD1
    I already fixed
    In win 10, the default drivers are downloaded from the device after installation
    As you can see, in my case, they were not enough
    I only downloaded the drivers from the mouse and keyboard manufacturers' website and everything worked as it should
    If the problem comes back, I will write it
    But thanks what thanks for the help -Kasek21 :P
