Error 17678, 17672, 17675, 17669, unit injector exceeded limit
marewe2 24792 3
  • #1 16235982
    marewe2
    Rate: 18
    Hello, I have a question, can someone advise me.
    Auro vw passat 1.9 2001 74kw 101km
    My brother mentioned in passat b4 1.9 year 2001 74kw 101km pump injectors four pieces because they fell into him.
    After replacement after a few days after firing it has such a problem with the accelerator pedal not responding for a few seconds. Sometimes the reaction is immediate and sometimes it is always. After that, everything ok. I connected him to a Polish vag computer and there mistakes.
    17678, 17672, 17675, 17669, all unit injectors exceeded control limit no accessories / not related to equipment - sporadic error
    After resetting the error returns after driving about 100km
    Someone can advise what are these errors cause or fault it is unit injectors bought used maybe not from this engine up to 101kw
    Or was the mechanic incorrectly set to 180 degrees
    You can ask for your help because, as it is the fault of the pump injectors, it has a two-week warranty on them
    • Error 17678, 17672, 17675, 17669, unit injector exceeded limit IMG_20170128_182658.jpg (3.85 MB) You must be logged in to download this attachment.
  • #2 16236002
    ociz
    Help: 1379
    Rate: 3487
    marewe2 wrote:
    bought used
    He bought another dustbin. Pads and elastics, of course new?
  • #3 16236027
    marewe2
    Rate: 18
    Hello, yes, all erasers are new. We just want to know if the bad mechanic is set to 180 degrees because from what we read it sets to 120 180 220 degrees
    Or maybe these pump injectors are already worn out because if so, the brother has time to give them back :)
  • #4 16238440
    marewe2
    Rate: 18
    Hello, today again after firing, no reaction to the accelerator only after a while everything is OK
    What could it be or the fault of these injections
