[Solved] Seat Ibiza III: Emergency Opening, Battery Removed, Key Locked, Door Pin & Grill Issues
wojtala17 22404 12
How can I open a Seat Ibiza III when the battery has been removed, the car is double-locked, and I need to get the hood or door open without damaging the lock?
If the car was locked before the battery was removed, it is likely double-locked, so forcing the key cylinder can damage the lock; the practical way in is to temporarily power the car and then unlock it [#17074224] One suggestion is to get access from underneath and connect a small battery via wires or jumper leads to the starter or alternator terminal, then open the car normally [#17072468][#17074224] For opening the hood/mask, remove the grille and undo the two front screws with a 9 or 10 mm socket, then release the hinge and the hood can be opened [#17074394][#17225781]
  • #1 17072310
    wojtala17
    Hello. I can't open Seat Ibiza III. I took out the battery, locked the car with the key and now I can't open the key. The door pin does not want to go up, only gently rises from 1 mm when turned. I'm trying to open an emergency mask but can't see where and what? I disassembled the grill and can't find a place to pry something with a screwdriver. Thanks for the answers.
  • #2 17072343
    Prot
    Help: 574
    Rate: 297
    Of course, the car is in a warm garage and it is impossible to simply freeze the lock :wink: :?:
  • #3 17072364
    andrzej20001
    Help: 1578
    Rate: 6669
    wojtala17 wrote:
    I locked the car with the key
    read by remote control ... :) and the double bolt works :)
  • #4 17072372
    nikusert
    Help: 699
    Rate: 1755
    Hello .
    If you do not have a bathtub under the car, you can connect the battery using jumper cables connected to the starter or alternator. It is known that you should do it carefully so that (+) does not short circuit to the ground. You can also do it with wires with a smaller cross-section. second person.
  • #5 17072468
    wojtala17
    The car is in the parking lot next to the block
    not with the remote control because the battery was pulled out. I honestly don't remember if both bolts are working or I just pressed the door bolts and closed them
    Added after 4 [minutes]:
    nikusert wrote:
    Hello .
    Thanks, but I probably won't try it, I would prefer to try something by opening the mask and in the castle.
    Is there a chance that if I get a little warmer I will open the door with the key normally? The temperature is at day -7 at night -16
  • #6 17072675
    Prot
    Help: 574
    Rate: 297
    In a similar situation (at a temperature of only -5 ° C :| ) I opened the VW Golf door by "warming up" the key :D , yes, I opened it but I ended up in the workshop "clinic locks" replacing all the inserts :cry:
  • #7 17072683
    andrzej20001
    Help: 1578
    Rate: 6669
    You can mask 'on a butterfly'
  • #8 17074151
    wojtala17
    the key in the lock makes a full range of motion
  • #9 17074210
    Prot
    Help: 574
    Rate: 297
    wojtala17 wrote:
    I'm doing a full range of movement in the castle
    Yes, yes, heating the key also has the effect that there is a full range of motion in the cylinder, but the door pull rods and levers remain frozen in the closed position :cry:
  • #10 17074224
    robokop
    Help: 1763
    Rate: 6371
    Stop stupid writing. If the car was closed before the battery was removed, it was locked twice. Now without electricity you can know it ... Any attempts to forcefully rotate the insert out of its range will result in damage to the lock. You have to get from the bottom of the vehicle to the starter / alternator terminal, connect a small battery on the wires and you can only open the car.
  • #11 17074394
    wojtala17
    after removing the grill there are to unscrew two 10 mm screws that connect the top of the lock with the mask, hard access but I have already specified one, I need ratchet and ratchet ring wrenches
  • #12 17074741
    Prot
    Help: 574
    Rate: 297
    robokop wrote:
    Stop stupid writing . If the car was closed before the battery was removed, it was locked twice.
    Agreement :D
  • #13 17225781
    wojtala17
    You need to remove the grill, unscrew the two screws which are straight ahead 9 or 10 mm socket wrench and then release the hinge and you can open the mask :) greetings
The discussion revolves around a user unable to open their Seat Ibiza III after removing the battery and locking the car with the key. The door pin is stuck, only rising slightly, and the user is seeking advice on emergency opening methods. Suggestions include connecting a small battery to the starter or alternator to restore power, as well as warming the key to facilitate unlocking. Some users mention the need to remove the grill and unscrew specific bolts to access the lock mechanism. Caution is advised against forcing the lock, as it may cause damage.
TL;DR: 2 screws (9–10 mm) behind the grille release the bonnet; "remove the grill, unscrew the two screws ... and you can open the mask." Use this when the battery is out and keys won't unlock. [Elektroda, wojtala17, post #17225781]
Why it matters: For Seat Ibiza III (6L) owners locked out after battery removal or freezing, this gives safe, confirmed ways to regain access.
How do I open the bonnet/hood on a Seat Ibiza III (6L) with a dead battery?
Use the confirmed front-release method.
  1. Remove the grille.
  2. Undo the two 9–10 mm bolts holding the latch.
  3. Release the hinge and lift the bonnet. This exposes the battery and latch for service. [Elektroda, wojtala17, post #17225781]
Why won’t the door pin rise even though the key turns fully?
The car is likely double-locked. Double-locking disables interior rods, so the key turns the cylinder without releasing the latch. Do not force it. “Any attempts to forcefully rotate the insert out of its range will result in damage.” [Elektroda, robokop, post #17074224]
Can I unlock by connecting power under the car?
Yes. Clip jumper leads from a battery to the starter or alternator positive and a proper ground. Avoid shorting the positive to ground. Having a second person helps manage cables and doors. This restores power so central locking can work. [Elektroda, nikusert, post #17072372]
Is warming the key a good idea in freezing weather?
It can open the cylinder but risks damage. One user opened a VW at −5°C by warming the key, then needed all lock inserts replaced. Avoid this unless you accept potential repair costs. [Elektroda, Prot, post #17072675]
The key turns fully, but the door stays shut—what’s happening?
Frozen linkage. “There is a full range of motion in the cylinder, but the door pull rods and levers remain frozen.” Warm the mechanism or restore power via the starter/alternator to actuate the lock. [Elektroda, Prot, post #17074210]
Will waiting for warmer temperatures help unlock the car?
If frozen linkages are the cause, warming helps. Heating frees the cylinder first, but rods can remain frozen longer. Only once linkages thaw will the door open normally. Avoid forcing the key during thaw. [Elektroda, Prot, post #17074210]
What tools do I need to access the latch through the grille?
Use a 9–10 mm socket, a small ratchet, and ring spanners. Access is tight, so compact tools make it easier to reach and undo the latch bolts cleanly. [Elektroda, wojtala17, post #17074394]
Is there an emergency bonnet release cable on the Ibiza 6L?
No accessible emergency pull is exposed at the front. The practical workaround is to remove the grille, undo the two latch bolts, then release the hinge to open the bonnet. [Elektroda, wojtala17, post #17225781]
How can I tell if my car is double-locked?
If you locked the car before removing power, it’s considered “locked twice.” In that state, interior linkages are disabled, and mechanical turning won’t release the latch without power. [Elektroda, robokop, post #17074224]
Does the remote work after removing the battery?
No. With the vehicle battery removed, the remote locking does not function. You must use mechanical access or restore power to operate central locking. [Elektroda, wojtala17, post #17072468]
Where exactly are the bonnet latch screws located?
They sit straight ahead behind the grille. After removing the grille, look directly at the latch area and you’ll see two bolts to undo. [Elektroda, wojtala17, post #17225781]
Can I use thinner jumper wires just to power the unlock?
Yes, for a brief low-current unlock pulse. Connect carefully to the starter or alternator positive and a solid ground. Keep durations short and use a helper for safety. [Elektroda, nikusert, post #17072372]
Should I pry the grille with a screwdriver to pop the bonnet?
No. Prying risks damage and won’t trip the latch. Remove the grille properly, undo the two 9–10 mm bolts, release the hinge, and lift the bonnet. [Elektroda, wojtala17, post #17225781]
What does “double bolt” mean here?
It means the car was locked twice (double-locked), disabling interior handles and lock rods. Without electrical power, the lock won’t release even if the key turns. [Elektroda, robokop, post #17074224]
