Thunderbird Disk Space: Manage Attachments, Limit Space Usage on Laptop, XP System
DecoDominik 12516 11
  • #1 16237217
    DecoDominik
    Rate: 96
    There is a problem with Thunderbird filling up the entire disk on the laptop.
    I suspect that this is caused by downloading attachments to the disk.
    From sent and received messages.
    How to block attachments from being copied to disk when sending messages?
    How to limit the amount of space in TB it can take up on the disk.
    XP system.
  • #2 16237242
    Kasek21
    Help: 4973
    Rate: 3534
    Options -> Attachments.
    How long is TB currently taking? How fast is this place growing?
  • #3 16237259
    DecoDominik
    Rate: 96
    I don't know, not my computer. But the problem was like that before.
    Something has just changed again and now I don't know what because I don't use TB myself.
    This is some old 2008 laptop. I told you to change to a bigger disk but got the statement that they don't need a bigger disk just more space on the current one ....
    So this is what it looks like leading a blind blind.
    Added after 5 [hours] 30 [minutes]:
    I checked the computer with some program to sort folders by size.
    The largest file on the computer is sent 1 20 gb GB from 30 gb GB disk.
    The problem is that in the location given by the program it is invisible.
    How to slim it down?
  • #4 16238170
    Kasek21
    Help: 4973
    Rate: 3534
    1.2GB for TB is not much for POP3 and a lot of attachments.
    Do you need e-mails for something? Can you delete?
    (you can always make a copy somewhere)
    PS. If the disk has 30GB, why are you looking for a problem in TB?
    PS2. What's the system there? Any big apps installed?
  • #5 16238212
    DecoDominik
    Rate: 96
    The Send1 Thunderbird file is 20 gb GB. And the disk is 30 gb GB.
    It is not possible that the text of the message takes that long.
    XP system.
  • #6 16238241
    Kasek21
    Help: 4973
    Rate: 3534
    How can you remove it, delete it, if not, copy it to a disc / USB flash drive.
    How do you want to limit the folder of sent messages then right click on the sent messages (in TB) and select Message storage rules.
    Options -> Attachments. (file storage options)
    PS.
    I assume that videos / photos were sent.
  • #7 16238267
    DecoDominik
    Rate: 96
    Only the company catalog in pdf is sent from us.
    But that would have to be 1000's of messages.
    And the post office was cleaned some time ago.
    Messages from 2016 are left. All previous ones have been deleted.
    Is it possible to remove all attachments from sent?
  • #8 16238309
    Kasek21
    Help: 4973
    Rate: 3534
    You can send messages to yourself (folder) by unchecking attachments, then delete the sent folder.
    DecoDominik wrote:
    News from 2016 is left.
    Are needed? Isn't it easier to archive them?
  • #9 16239137
    DecoDominik
    Rate: 96
    I can archive them.
    But I don't know if it will do anything because despite not using TB for several days.
    And removing temporary files and a few other junk.
    Shoots the entire disk. I don't know if he's downloading old news again or what.
    We don't even have that much space on the server.
    Added after 1 [hours] 15 [minutes]:
    Hell, I don't get it.
    There are 100-200 messages per mailbox on a computer.
    And it still takes up 20GB.
  • #11 16240606
    DecoDominik
    Rate: 96
    Directory from TB.
    But uninstalling and deleting the entire folder helped.
    The problem now is that TB has started downloading old news.
    Although I set the limit for 360 days. I also have one from the beginning of 2015
  • #12 16240672
    Kasek21
    Help: 4973
    Rate: 3534
    Then delete messages from the mailbox or use IMAP instead of the POP3 server.
✨ The discussion revolves around managing disk space issues caused by Thunderbird (TB) on an old Windows XP laptop. The user reports that TB is consuming excessive disk space, primarily due to large attachments in sent messages, with one file reaching 20 GB on a 30 GB disk. Suggestions include checking TB's attachment settings, deleting unnecessary emails, and using archiving methods. Users also recommend switching from POP3 to IMAP to better manage email storage. The user expresses confusion over TB downloading old messages despite setting a limit, indicating a need for further troubleshooting.
