Connecting 3-Phase Inverter (Liteon Evo 600) to 1-Phase Motor: Connection & Error Solutions
zulwio 7275 17
Can a 1-phase capacitor motor be run from a 3-phase inverter, and how can I stop the inverter from faulting on motor damage?
In general, this is not a reliable setup; a single-phase capacitor motor often makes the inverter see asymmetry or different winding impedances and it throws a motor/cable damage fault, so the safest solution is to use a proper 3-phase 230/400 V motor or a drive explicitly known to tolerate this kind of load [#16238261][#16237552] If you still want to test it, disconnect the capacitor and start circuit, then connect the inverter outputs U/V/W directly to the motor’s three terminals/bridges [#16237569][#16278310] Also try the gentlest inverter settings: low starting frequency, long acceleration ramp, and a current limit around the motor’s rated current; some users reported that certain inverters could run such motors only with tuning, while others still faulted [#16237703][#16237652][#16278310] The thread’s consensus is that this depends heavily on the inverter model and motor construction, but with the Liteon Evo 600 the safest expectation is that it is not suitable for this motor [#16238261][#16237703]
  • Single-phase motor compatibility with two inverter output phases
    #1 16237533
    zulwio
    At the beginning, I apologize for the topic because it was already like that, but it is closed.
    Well, I have a problem and it is possible that they were created in the equipment buying phase.
    I have a Liteon evo 600 1x230AC inverter that outputs ordinary U, V, W 230 V at the output
    I have an engine Connecting 3-Phase Inverter (Liteon Evo 600) to 1-Phase Motor: Connection & Error Solutions
    After connecting the motor to the 230 network everything is fine, I thought that I could connect to the two outputs of the inverter and the slime in the same way, but the engine starts, when starting up to 30Hz, it somehow turns above, the inverter throws an error and stops, man thought that there is a shift in phases and the engine will not work like that?
    Is there an option to fasten it with this hardware configuration?
    I connected in a triangle, but the inverter made an error that the motor was damaged and functional ;)
    Connection to the engine:
  • #2 16237552
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    The capacitor resistance depends on the frequency.
    You made a school mistake. It won't work.
    Replace the motor with a suitable one.
    And measure the windings if it is sometimes not a three-phase motor.
  • #3 16237569
    osiniak75
    Help: 350
    Rate: 544
    Disconnect the capacitor, at the moment you have an incomplete triangle because the bridge on the first terminals Z1 V2 is missing. Then, as standard, from the inverter U, V, W to individual bridges.
  • Full delta without capacitor still triggers inverter fault
    #4 16237614
    zulwio
    I tried this before ;) I disconnected the capacitors, I made a full triangle, and the inverter crashed the error that "the motor or the wire is damaged".
    If I am not mistaken, the motor will not start in such a system because it lacks a capacitor, the system crashes with the capacitor because the condenser.
  • #5 16237652
    Help: 1405
    Rate: 6430
    Start at 50Hz with the smallest acceleration ramp. But why do you need an inverter so offensive?
    Set the inverter to about 10A of rated current.
  • #6 16237685
    osiniak75
    Help: 350
    Rate: 544
    Apparently, the motor, despite the fact that it has three windings, is not adapted to work on three phases, it probably has windings of different impedance and the inverter treats this as damage.
  • Check motor type and capacitor before inverter connection
    #7 16237703
    jack63
    Help: 851
    Rate: 2822
    And he saw the nameplate ... Probably not, let him see it and it does not suggest incompetence of the author of the topic.
    osiniak75 wrote:
    Disconnect the capacitor, ....
    Not a bad idea, although some (!) Single-phase motors were powered by some (!) Inverters without disconnecting the capacitor.
    It is important that it is not a motor with a compact start-up phase, i.e. with THREE terminals. We connect three outputs from the inverter to them and ... sometimes such a system works.
    The choice of the inverter is crucial. No inverter manufacturer provides for such a connection and most even forbid it, but we have 10 LS Ic inverters with 10 fans for several years and it is OK.
    As far as I know, people from LS officially do not confirm this possibility, but they unofficially recommend these inverters in such situations.
    In the case of inverters from other companies, the effect of such a connection may be "different". You have to test, but what for? Isn't it better to use a 3f engine? Sometimes, however, the situation is really difficult and such tying of the shoe with an earthworm is the only acceptable solution.
  • #8 16237710
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    You hit the nail on the head, buddy. This engine never will not work with the inverter. Replace the motor with a normal 220 ? / 400 ?. So much.
  • Single-phase motor wiring may work with suitable inverter settings
    #9 16238261
    jack63
    Help: 851
    Rate: 2822
    Krzysztof Kamienski wrote:
    You hit the nail on the head, buddy. This motor will never work with an inverter. Replace the motor with a normal 220 ? / 400 ?. So much.
    One crap rushes another. Nightmare.
    The motor is SINGLE-PHASE and has TWO windings, not three. If the beginnings and ends of the windings are led into the creamer, the direction of rotation can be changed by appropriate connections. However, the windings are always connected in series giving three connections as in a 3f motor, so they can be connected to an inverter with a 3f output powered from ONE phase. Whether such a system works depends primarily on the internal design and software of the inverter. The inverter settings are also important. Ie lower frequency and ramp.
    Probably the inverter of the author of the topic is not suitable for such an unusual application. You would need to test with an LS inverter. However, this is probably not what the author of the topic meant?
    On the other hand, much simpler and cheaper phase regulators on a triac are used to regulate the RPM of induction motors. Almost like dimmers.
  • #10 16238301
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Sorry, I meant the CLAMPS, not the windings. Here is my mistake. However, as for the rest of my colleague's argument, I have divided opinions. Especially this triac with regard to induction motors.
    jack63 wrote:
    3f powered from ONE phase.
    What does one or two or three things have to do with it? Secondly, hasn't Dear Colleague met a single-phase motor with a THREE winding capacitor? Nightmare.
  • Triac regulation and three-winding motor examples clarified
    #11 16238490
    jack63
    Help: 851
    Rate: 2822
    Well, my friend saw little, read, was interested.
    Before BLDC motors came into widespread use, such regulation was common. For example, low-power fan motors in air conditioners were so controlled.
    And this has to do with the fact that the RMS of the voltage "created" by the inverter is almost the same as the voltage of that phase, i.e. 230V RMS, and there is no fear of damaging the motor.
    I can see that my colleague has "forgotten" how a frequency converter, commonly known as an inverter, works.
    Dear colleague, did not meet a single-phase motor with a working capacitor with THREE windings? Nightmare.
    I saw not one, but they were two-speed motors.
    The nightmare, however, is the colleague's strong pressure on glass, which manifests itself in his statements on topics about which his colleague has a vague idea, such as cooling. Sad...
  • #12 16238500
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Really? And not full-swing sometimes?
  • #13 16278310
    *paweł*
    Automation specialist
    Help: 60
    Rate: 95
    Based on our own and customers' experience, we used EURA DRIVES and DELTA ELECTRONICS inverters to control cutters that had single-phase motors with a capacitor. The capacitor and the starting circuit were blown out, the windings were connected to the inverter (3 taps) and it worked. Of course, it was not what it should have been and you had to combine with the settings, but the clients could work.
    There is no rule as to the manufacturers of inverters, it is important how it reads the asymmetry at the output.
    Automation-Systems
    Domatków 36, Kolbuszowa, 36-100 | Tel.: 17 XXXXXXX (Show) | Company Website: automatyka-sklep.eu
  • #14 20009111
    Rezystor240
    Help: 689
    Rate: 1651
    Hello, I know that the subject is archival, but I have literally one question.
    A single-phase motor with a capacitor is 200W, and when powering two windings from a single-phase inverter, it will also have the same power and torque? It's about increasing the power, not changing the speed.
  • #15 20009134
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @ resistor 240 No. The impedance of the main and auxiliary windings (for the capacitor) is different. The inverter will probably report an error.
  • #16 20009144
    Rezystor240
    Help: 689
    Rate: 1651
    I understand, so even if the inverter would start, I would burn the auxiliary winding, I think right?
  • #17 20009175
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Maybe not so much "burned" as the engine would not work properly. Complete asymmetry of the rotating magnetic field. The capacitor shifts the phase by 90 degrees, the inverter by 120.
  • #18 20009185
    Rezystor240
    Help: 689
    Rate: 1651
    Thank you, it confirms me that this is an abnormal idea ;)
The discussion revolves around connecting a Liteon Evo 600 inverter to a single-phase motor. The user reports issues with the motor starting and the inverter throwing errors, suggesting a potential phase shift problem. Responses indicate that the motor may not be suitable for three-phase operation, as it has two windings and requires a capacitor for proper function. Suggestions include checking the motor's specifications, ensuring correct wiring, and using appropriate settings on the inverter. Some participants mention that certain inverters can work with single-phase motors under specific conditions, but caution against potential damage due to impedance differences. Overall, the consensus is that the current motor configuration is not compatible with the inverter, and a replacement with a suitable three-phase motor is recommended.
