Windows 7 Clock Issue: Time Resets or Freezes - Possible Battery, Sync, or Virus Causes
ninik26 6390 16
Why does the Windows 7 clock move back by an hour and stop advancing despite replacing the CMOS battery, scanning for malware, and disabling internet synchronization, and how can the fault be diagnosed?
The thread does not establish a definitive cause; first check the configured time zone and whether the incorrect time also appears in the BIOS, not just in Windows [#16238545] Perform a proper CMOS reset using the motherboard jumper with the computer powered off, removing and reinstalling the battery afterward [#16238575] [#16238712] A successful reset should restore default BIOS settings, including a default time near 00:00 and a default date [#16238681] [#16238719] The replacement battery measured about 3.2 V, so also inspect the battery-holder contacts for poor or tarnished contact [#16238645] [#16238650] Continue monitoring the clock after the reset, while checking that time synchronization is actually disabled because it was later found enabled [#16238675]
  • Clock freezes when idle and resets after 30 minutes
    #1 16238533
    ninik26
    Rate: 9
    Quite a popular topic but I can't get along with the clock.
    When using the computer for a few minutes after setting it is ok, after about 30 minutes the clock goes back by an hour, and without using the time stands still.
    I replaced the battery on the disk, it did not help, I scanned the system with anti-virus twice, nothing helped, I turned off clock synchronization with the net, it still did not help.
    Any suggestions on what to do?
    Regards
  • #2 16238545
    RADU23
    Help: 2428
    Rate: 1732
    What time zone do you have set?
    Does the clock only change in the system or in the BIOS?
  • #3 16238553
    ninik26
    Rate: 9
    +1 Wawa
    in the bios the same as I wrote the post I had an hour around 14:38, I reset the computer to look at the bios, and there 14:07 and in the system also 14:07 ...
    The clock goes back on its own :?: :idea:
  • #4 16238575
    RADU23
    Help: 2428
    Rate: 1732
    So it rejuvenates you ;-)
    Try to perform a CMOS reset through the jumper.
  • #5 16238580
    ninik26
    Rate: 9
    How is this done?
    I turn off the computer, translate the verse to the appropriate pins, start the computer and? what's next ?
    Added after 44 [seconds]:
    About sh * t something happened because suddenly I have the current time and I just looked at my computer :D
  • #6 16238594
    RADU23
    Help: 2428
    Rate: 1732
    So it remains to monitor the situation ;-)
    ninik26 wrote:
    How is this done?
    Please =>
    https://www.elektroda.pl/rtvforum/topic1204376.html
  • #7 16238613
    ninik26
    Rate: 9
    It's funny but I've had balls for four days and it's been ok for a few minutes, funny weird but true.
  • #8 16238645
    RADU23
    Help: 2428
    Rate: 1732
    Did you measure the voltage of a battery with a meter before inserting it into the plate?
    It should be 3V.
    Or maybe the contacts have become dull in the battery socket.
  • #9 16238650
    ninik26
    Rate: 9
    Battery voltage about 3.2V
  • #10 16238659
    RADU23
    Help: 2428
    Rate: 1732
    OK.
    If it happened again, write.
  • #11 16238675
    ninik26
    Rate: 9
    I reset the bios with the jumper as in the link, but I do not know why after the restart I had 23:03 and it was 23:30, because when the bios reset should also reset the system hour?
    By the way, I had synchronization with the net enabled.
  • #12 16238681
    RADU23
    Help: 2428
    Rate: 1732
    So there was no reset.
    The time should reset to the default 00:00 (generally) and default date.
    And the date has probably been correct / present.
  • #13 16238692
    ninik26
    Rate: 9
    Yes
    strange because the verse was left for 3 / 5minutes
    Do I need to remove the battery when resetting the jumper? because the power turned off
    Added after 4 [minutes]:
    I will add that the bios settings have been reset and the time / date has not
  • #14 16238712
    RADU23
    Help: 2428
    Rate: 1732
    Remove.
    After performing the reset, you will insert it again. No problem.
  • #15 16238719
    ninik26
    Rate: 9
    So I did, bios settings have been reset, including time / date (2013year etc.)
    The above date is random or maybe related to the "creation" of the disc (programmed or something similar)?
    We'll see what time it will be in the morning and what will happen tomorrow.
  • #16 16238905
    RADU23
    Help: 2428
    Rate: 1732
    It is usually associated with the creation of the disc, provided that you have not manually updated the BIOS, e.g.
  • #17 16238995
    ninik26
    Rate: 9
    I only updated from the downloaded software from the manufacturer, which is not manual because if it were anyway, I would have had yesterday's date :D
    So far it's calm.
The discussion revolves around a Windows 7 clock issue where the system time resets or freezes after a period of inactivity. The user has already replaced the battery and performed antivirus scans without success. Responses suggest checking the time zone settings, verifying the BIOS clock, and performing a CMOS reset. The user confirmed that the BIOS time was incorrect and attempted a reset, but the system time did not revert to default as expected. Suggestions included measuring the battery voltage and ensuring proper contact in the battery socket. The user noted that after resetting the BIOS, the time was still not accurate, leading to further inquiries about the reset process and its effects on the system clock.
