- MSI GE70 2PE APACHE PRO Laptop: Win7 System Clock Changing Itself, Inconsistent Timing Issues
Grajek12356 3900 14
Why does my MSI GE70 2PE Apache Pro laptop clock keep changing itself back by 1 hour and show the wrong time after startup?
Updating the BIOS fixed the clock drift problem [#16637272] Before that, changing the BIOS/CMOS battery did nothing, so the battery was not the cause [#16633926] It was also noted that the issue was not just a simple battery fault because the clock was only shifting by one hour [#16632873]
  • #1 16631283
    Grajek12356
    Hello, for some time the system clock has been changing itself 1 hour back, after turning on the computer I also have a bad hour. The weird thing is, sometimes there are days when it works fine and doesn't shift at all ..
    Any idea what it might be?
    MSI GE70 2PE APACHE PRO laptop
  • #2 16631295
  • #3 16631305
    Grajek12356
    yes the time is correct
    UTC + 01: 00
  • #4 16632391
  • #5 16632509
    Kasek21
    Help: 4981
    Rate: 3547
    There is no time synchronization option in bios?
  • #6 16632859
    Grajek12356
    @ zbychok14 2 years some .. I also noticed that, for example, I turn off the computer at 22, the same hour is when the computer starts in the bios
    @ kasek21 I don't know, I didn't notice anything like that
  • #7 16632870
  • #8 16632873
    Kasek21
    Help: 4981
    Rate: 3547
    zbychok14 wrote:
    I would change the batteries on the motherboard
    It is not the fault of the battery if it always only switches to an hour.
  • #9 16632874
    Grajek12356
    What is this battery in laptops? so normal for PC? do you need a special one?
  • #10 16632885
  • #11 16632923
    Grajek12356
    I changed the hour in bios from 12:30 to 12:31 and now it flashes, the hour has not changed since then, maybe it's not the battery? : p
  • #12 16632927
  • #13 16633247
    Kasek21
    Help: 4981
    Rate: 3547
    Grajek12356 wrote:
    maybe it's not a battery?
    It definitely isn't.
  • BIOS battery replacement did not fix clock drift
    #14 16633926
    Grajek12356
    Ok, so everything works fine when I change my bios.
    I turned off the computer at 20:35 and when I turned on the computer again [one hour later] it was an hour in bios 20:35 and I had to synchronize with the Internet and of course it changed in an hour
    I will change the batteries tomorrow for the sake of peace and see how it works, I hope it will help
    Added after 17 [hours] 6 [minutes]:
    changing the battery in the bios did nothing: d it's the same
  • #15 16637272
    Grajek12356
    the bios update helped :D
    Only now there is another problem, because the fps in games are dropping to 30 I don't know why, I installed the latest graphics drivers and it's still the same
The discussion revolves around a timing issue with the MSI GE70 2PE APACHE PRO laptop, where the system clock inconsistently resets itself by one hour. Users suggest checking the BIOS settings and time zone configurations, with one confirming the BIOS time is correct. There are inquiries about the presence of a time synchronization option in the BIOS and the potential need to replace the motherboard battery. The author reports that changing the BIOS time temporarily resolves the issue, but the problem recurs. Ultimately, a BIOS update is noted to have resolved the clock issue, although a new problem with low FPS in games arises afterward.
TL;DR: MSI GE70 2PE clock issues were solved by a BIOS update; afterwards games capped at 30 FPS. “the bios update helped :D”. [Elektroda, Grajek12356, post #16637272]
Why it matters: If your Win7 laptop clock keeps moving, a firmware fix may stop the 1‑hour shifts and save your schedules. This FAQ is for MSI GE70 2PE users troubleshooting self‑changing time and post‑update performance quirks.
Why does my MSI GE70 2PE clock keep changing by 1 hour?
A strict 1-hour shift points to DST/timezone handling or firmware, not a dead CMOS cell. The original poster fixed it by updating the BIOS, which suggests an RTC/EC firmware quirk. Start by confirming timezone settings, then apply the latest stable BIOS from MSI. “the bios update helped :D”. [Elektroda, Grajek12356, post #16637272]
Is the CMOS battery the cause if the time always changes by exactly one hour?
No. A dead CMOS battery causes random resets, not a precise 1-hour offset. As one expert said, “It definitely isn’t.” when the change is always one hour. Prioritize timezone/DST checks and firmware updates over battery swaps. [Elektroda, Kasek21, post #16633247]
How can I tell if it’s Windows or BIOS causing the wrong time?
Check the BIOS clock immediately after power‑on. In the thread, BIOS time was correct while Windows showed an offset. That indicates an OS‑side or sync interpreter issue rather than RTC loss. Validate timezone and internet time settings next. [Elektroda, Grajek12356, post #16632859]
Should I replace the CMOS battery on this laptop?
Not for a strict 1‑hour jump. The OP replaced the battery and the issue persisted. Focus on timezone, DST, and BIOS/EC updates first. If the clock fully resets or loses date, then consider the battery. [Elektroda, Grajek12356, post #16633926]
What fixed the original poster’s MSI GE70 2PE clock problem?
A BIOS update resolved the self‑changing system time. After updating, the OP reported the clock issue was gone. Record your current settings and follow MSI’s flashing guidance to avoid interruptions. [Elektroda, Grajek12356, post #16637272]
How do I update the BIOS safely on the GE70 2PE?
  1. Back up data and note current BIOS version.
  2. Apply the vendor BIOS update on AC power, following on‑screen steps.
  3. After reboot, recheck time, timezone, and Windows sync settings. The OP confirmed this cleared the clock issue. [Elektroda, Grajek12356, post #16637272]
Why did my FPS drop to 30 after the BIOS update, and how can I fix it?
The OP saw games drop to 30 FPS post‑update. Check power plans, GPU selection (Optimus), and V‑Sync or frame limiters. Ensure NVIDIA drivers match the new firmware environment. Disable in‑game caps and re‑test. If needed, reinstall the GPU driver cleanly. [Elektroda, Grajek12356, post #16637272]
What does the BIOS time not advancing while the laptop is off mean?
The OP noted the BIOS time matched the shutdown time at next boot. That points to RTC/firmware behavior and not a classic depleted battery. A BIOS update corrected the overall issue in their case. [Elektroda, Grajek12356, post #16632859]
How should I set timezone and internet time in Windows 7 for this laptop?
Confirm the correct zone (e.g., UTC+01:00 for Central Europe) and enable internet time sync once the BIOS is fixed. The OP had UTC+01:00 yet saw offsets before the update; syncing then corrected Windows time. [Elektroda, Grajek12356, post #16631305]
Does internet time sync help if my BIOS time is wrong?
It can apply an offset that masks root issues. The OP synced and Windows adjusted by one hour while BIOS still showed the old time. Fix firmware first, then rely on NTP for accuracy. [Elektroda, Grajek12356, post #16633926]
What is a CMOS battery in a laptop?
It’s a small coin‑cell that maintains RTC and BIOS settings when the laptop is off. On many laptops it’s the same type used in PCs. The thread confirms this equivalence. [Elektroda, Anonymous, post #16632885]
How long had the GE70 2PE been used before the clock issue appeared?
About two years of ownership were reported when the behavior was noticed. This contextual age can hint at firmware maturity rather than sudden hardware failure. [Elektroda, Grajek12356, post #16632859]
Is there a BIOS option for time synchronization on this model?
A participant asked about a BIOS time sync option, implying it’s worth checking your firmware menu. Look for RTC, NTP, or network time features after updating BIOS. [Elektroda, Kasek21, post #16632509]
Why does an exact 1‑hour change matter diagnostically?
A precise one‑hour step aligns with DST or timezone interpretation errors, not analog drift. As noted, when it always switches by one hour, blame configuration or firmware rather than the battery. [Elektroda, Kasek21, post #16632873]
What quick test confirms the fix?
After updating BIOS, power down for an hour and compare BIOS and Windows times on reboot. The OP reported stable timekeeping after the update. This validates RTC and OS alignment. [Elektroda, Grajek12356, post #16637272]
