Citroen Jumper III 2.2 HDI: Charging Indicator Issue, Alternator Voltage, Wiring & Fuse Details
slawarek 13317 3
  • #1 16239702
    slawarek
    Rate: 212
    I have a lll jumper as the charging indicator is lit in the topic, I found the same problem on the forum but it is closed.
    The alternator gives 14.44v and the indicator light is on. I know that the purple cable goes to the engine computer, and the green cable is supposed to have 12 volts, only that I have after starting the car (on the meter), and it is not supposed to have 12 volts before lighting it, anyway the connected bulb does not light on this cable. this cable goes from BSI or from fuse no. In addition, it is connected only by injection and a month earlier with everything, the fuses are good, does anyone have a diagram of this circuit?
  • #2 16250656
    szymon198312
    Level 30  
    Help: 126
    Rate: 890
    I have pdf but I don't have how to paste
  • #3 16259295
    dandias
    Rate: 59
    Hello, the purple cable goes through the ankle under the left front lamp, it will most likely be bent - I had an identical case yesterday.
  • #4 16279691
    slawarek
    Rate: 212
    Could you send me a letter? Because I can not come to the end with these cables, I do not know where the second cable should go, be one I have the 75 bulb ringed and the only way to go to the engine controller is, the other is a puzzle for a fuse or BSI?
    Today I figured out the topic and the green cable was broken and worn on the engine, it gets 12v after firing and is supposed to be able to shine the bulb. I just wonder where it goes because the box under the lamp splits and goes to the cabin and probably for support? I'm not sure.
