Experiencing Slow Internet Speed on New HP Laptop in Home WiFi Network with Neostrada
mm403 6441 5
  • #1 16239886
    mm403
    at home we have a home network in wifi, which is used by several laptops. The Internet is a neostrada. With orange up to 10 MB per second - despite various periodic difficulties, the internet works regularly at a speed of about 6 MB per second, usually. In addition, we also have a range amplifier.
    Recently, I bought a new HP laptop and regretfully connected to the home network that the internet works at a minimal speed also when I'm alone at home, so it is out of the question to use other computers - the trial version of the anti-virus barely downloaded its updates. I do not know what is the reason and how to solve this case because I do not know too much about the configuration of the network in wifi and even more so on the settings of the computer that has windows 10 which is a completely new system for me. Maybe you need to set or turn something on or off, which I have no idea.
    In speed tests on other devices the internet reaches a speed of about 6 MB while on my laptop which is new this speed is 0.5 MB while sending about one MB. The YouTube videos themselves play at the lowest quality, and the five-minute movie lasts about 50 minutes.
    Best regards and counting on your help.
  • #2 16239964
    nobanmeplease
    Help: 7
    Rate: 20
    Hello!
    Where did you buy this laptop and what model is it?
    It looks like crafted soft, so the device can act as a node that copies cryptocurrency and even worse, so disconnect it from the network!
    I suggest reinstalling the system from another image according to the license sticker code on the housing.
    If it didn't help, let me know :)
    Greetings!
  • #3 16239974
    bogiebog
    Help: 2569
    Rate: 1528
    Start the laptop in safe mode + network support, connect the cable to the router, does it change anything?
  • #4 16239982
    mm403
    Interestingly, after writing the post the internet began to work normally (like a second laptop) by chance? Hmmm, we'll wait until tomorrow and I will answer how is the Internet ;)
  • #5 16240008
    nobanmeplease
    Help: 7
    Rate: 20
    If this is the case, it is a sign that you have a hacker on your neck, you can see that he got scared :D
    Set a new password for wifi, minimum 25 characters long, which will contain numbers and reinstall the system, after which it will be pinned again on the new password.
  • #6 16240074
    mm403
    ? What hacker? What reinstalling windows (anyway, I don't even have the key on the Windows model - bought at mediamarkt)
    The computer is running for the second time, has up-to-date mcafee anti-virus protection, what are you scaring man with? :(
    Maybe this is something wrong with the supplier, because during the day on the second YouTube computer also did not load movies ...
    I thought more that it could be the fault of a new device connected to the home network (the password we have a strong combination of letters and numbers) and I thought that maybe something needs to be set.
