DELL Inspiron 7566 Laptop: Wi-Fi Connectivity Issues, Slow Speeds, Network Change Detected
lipsztajn 3882 16
How can I fix very slow, unstable Wi‑Fi on my Dell Inspiron 7566 when only this laptop has the problem and Chrome shows “Network change detected”?
Set the TP-Link WN841N Wi‑Fi settings manually to channel 1 and 20 MHz channel width; inSSIDer showed the link score jump from about 46 on auto to about 95–98 on channels 1/6, and the connection improved after that change [#16679419][#16680769] If the issue returns, test the laptop with an Ethernet cable and, if possible, in Safe Mode with networking to separate router issues from a laptop-side fault [#16679226] Because all other devices worked normally while only this laptop had drops and speed loss, a damaged Wi‑Fi adapter or antenna is also a plausible cause if the router changes do not hold [#16679109]
  • #1 16678856
    lipsztajn
    Hello everyone, I have a problem with Wi-Fi connected to my Dell Inspiron 7566. I have this laptop for over half a year and it worked reliably all the time, until it began to fail in the internet. All devices in the home use full bandwidth, there is no problem watching movies in 1080p, they load without clipping on androids, iPads, iPhones and other HP laptops, only in my laptop sometimes it is difficult to watch a 360p movie, a file, which weighs 20MB can download for up to 20 minutes. When using Google Chrome, the page does not load from time to time, it only displays the screen with the message "Network change detected". Sometimes also the connection turns off automatically, then I have to click on the wi-fi icon and connect to the network again. I have already tried everything: I changed the password for the router, I made the format of all drives, I thoroughly scanned avast a few times and nothing. Before that, everything would download normally: Steam and Origin games, 1080p movies without plugins, and online games with minimal ping. Well I can't guess what's going on here, that's why I turn to people who know each other. I read about changing the wifi channels in the router settings, but it doesn't work. I have 1.3Mbps score on testmy.net
    I am using the router: tp-link WN841n
    The router is located one floor below
    Windows 10
    Best regards and please help, I will be very grateful.
  • #2 16678872
    bogiebog
    Help: 2569
    Rate: 1530
    Delete all remembered WIFI networks and leave only what you need.
    Two routers on the network?
    Give a network diagram with all WIFI points / routers / repeaters.
  • #4 16679014
    lipsztajn
    I will do what gentlemen recommended to me, I will add that I noticed a few things. The internet connection and speed is not constant, sometimes there is no internet although the icon shows full range, sometimes the internet slows down and after a few minutes it speeds up, it is clearly seen on YouTube videos, where the quality automatically changes to 144p, then returns but above 480p I will watch nothing. I also have a problem with Google Chrome, because sometimes it stutters, it doesn't respond to clicking on the entire screen except the system bar. After a few seconds, the message "program has stopped working" appears. Then I go straight to Mozille, and there I can not load a single page, which is communicated with the text "no network connection" although the wifi icon says otherwise. I would add that during this time no device in the house uses the internet. I deleted all remembered networks but it was only the one I used. I do not know how exactly I should give the network diagram, so I will simply say how it looks at my house: the router of the model given in the first post connected to the internet cable, with this router we connect all devices wirelessly via wifi, with this router via a lan cable is connected TV and there is also a printer and home cinema for wifi.
    It is strange, however, that in all devices the Internet works normally, as always. Only in my laptop something breaks, even if the format did not give any results.
  • #5 16679109
    jimasek
    Help: 3783
    Rate: 2681
    Looks like damage to the network adapter or antenna. Without measurements and diagnostics, this is only a divination on my part.
  • #6 16679123
    bogiebog
    Help: 2569
    Rate: 1530
    Start the computer in safe mode + network support, does it change anything?
  • #7 16679198
    lipsztajn
    In safe mode with networking, I can't connect to wi-fi, there is a "network cable is disconnected" icon.
    Added after 5 [minutes]:
    I checked the laptop in the room where the router is located and did not notice the difference. Can someone send a link to some diagnostic program on windows 10 then I will do the test and post a report.
    bogiebog
    Help: 2569
    Rate: 1530
    - connect laptop _kablem_ to the router, does it change anything?
    no ? run in safe mode + network support and connect _kablem_ to the router, does it change anything?
  • #9 16679415
    lipsztajn
    I connected directly to the ethernet cable, because the only free cable with which I could connect the computer with the router is in the wall and leads to the TV. I did WPS / reset on the router, and it looks like it has improved. See for days how it will work. Do you have any other tips on improving the connection and signal quality? On the testmy.net cable, the result is over 14Mbps and on WiFi ~ 4.5Mbps. Of course, I'm not surprised by this result, but maybe the router is of poor sort. What do you think
    bogiebog
    Help: 2569
    Rate: 1530
    Run inssider 2.x and scan WIFI in low reception areas, show results.
  • #11 16679593
    lipsztajn
    I downloaded inSSIDer Home (http://www.instalki.pl/programy/download/Windows/sieciowe/inSSIDer.html) and made it in accordance with the instructions. On the auto router setting in channel selection, the link score was about 46 in the room where he works, in the salon where the router is located increased by 3 points. When I changed the channel for example to 1 or 6, the link score was 98 in the living room and in room 95. In both cases, the signal in the living room was around -40dbm and in the room around -56dbm. If I did something incorrect, please feel free to write, because I have to deal with such things for the first time. It detects 3 other wi-fi networks with ~ -98dbm signal in the environment.
  • #12 16679606
    bogiebog
    Help: 2569
    Rate: 1530
    lipsztajn wrote:
    If I did something incorrectly, please write boldly
    You talked like a woman
    bogiebog wrote:
    show results.
  • #13 16679646
    lipsztajn
    I gave some numbers which I noticed, I don't know.
  • #15 16680760
    lipsztajn
    Please. Today the internet is down again. There was improvement yesterday evening.
    bogiebog
    Help: 2569
    Rate: 1530
    In tplink
    - set the WIFI channel to 1
    - change the width of the WIFI channel to 20Mhz
  • #17 16680779
    lipsztajn
    Well, it looks like it has improved. Thank you. In that case, I'm closing the topic.
The discussion revolves around Wi-Fi connectivity issues experienced by a Dell Inspiron 7566 laptop, which has been reliable for six months but recently suffers from slow speeds and intermittent disconnections. Users suggest troubleshooting steps such as deleting unnecessary Wi-Fi networks, checking for signal interference, and running diagnostics. The author reports fluctuating internet speeds, issues with Google Chrome, and a "network change detected" message. Recommendations include connecting via Ethernet, adjusting router settings (such as changing the Wi-Fi channel and width), and using diagnostic tools like inSSIDer to analyze signal strength. After implementing some changes, the author notes an improvement in connectivity.
TL;DR: Fix Dell Inspiron 7566 Wi‑Fi drops and slowdowns (14 Mbps wired vs 4.5 Mbps Wi‑Fi) by “set the WIFI channel to 1” and use 20 MHz bandwidth; this addresses Chrome’s “network change detected.” [Elektroda, bogiebog, post #16680769]
Why it matters: This FAQ helps Dell Inspiron 7566 owners diagnose unstable Wi‑Fi and restore consistent speeds without replacing hardware.
How do I fix “Network change detected” on a Dell Inspiron 7566?
Log in to your router and set the 2.4 GHz Wi‑Fi channel to 1. Change channel width to 20 MHz. Reboot the router and laptop. This reduces roaming and interference that can trigger Chrome’s “network change detected” message. As the expert advised: “set the WIFI channel to 1.” [Elektroda, bogiebog, post #16680769]
Why is my Wi‑Fi so much slower than Ethernet on this laptop?
Interference and suboptimal channel width can cap throughput. In this case, Ethernet tested around 14 Mbps while Wi‑Fi was about 4.5 Mbps. After adjusting the Wi‑Fi channel and width, stability improved. Compare your speeds the same way to quantify gains after changes. [Elektroda, lipsztajn, post #16679415]
How can I measure Wi‑Fi signal and neighboring networks?
Use inSSIDer 2.x on Windows to scan channels and signal levels. Check which channels nearby routers occupy and pick a cleaner one. Capture screenshots of the channel graph and signal strength to track improvements after changes. [Elektroda, bogiebog, post #16679419]
What do my readings like −40 dBm and −56 dBm tell me?
They show relative signal strength in different spots. The user saw about −40 dBm near the router and −56 dBm in the room. After choosing a fixed channel, the link score rose to 98, indicating better conditions. Use these readings to guide placement and channel selection. [Elektroda, lipsztajn, post #16679593]
Should I try Safe Mode with Networking for diagnosis?
Yes. Booting into Safe Mode with Networking can isolate software conflicts. If Wi‑Fi drivers don’t load there, use an Ethernet cable to test stability. This checks if problems are OS‑level versus radio‑level. [Elektroda, bogiebog, post #16679123]
Why can’t I connect to Wi‑Fi in Safe Mode on this Dell?
The user reported that Safe Mode showed a “network cable is disconnected” icon and could not join Wi‑Fi. Some Safe Mode environments lack full wireless driver support. Use a wired connection for that test. [Elektroda, lipsztajn, post #16679198]
Could my network adapter or antenna be faulty?
It’s possible when only one device struggles while others are fine. As one expert noted, “Looks like damage to the network adapter or antenna.” Test via Ethernet and close to the router to separate RF issues from hardware faults. [Elektroda, jimasek, post #16679109]
How do I check if two routers or extenders are causing issues?
Chrome’s message can appear when networks overlap or change. Delete saved networks you don’t use. Map your setup and confirm you have one DHCP source. An expert asked, “Two routers on the network?” which is a common root cause. [Elektroda, bogiebog, post #16678872]
I moved next to the router and saw no change. What does that mean?
The user tested in the router’s room and saw no difference. That points to configuration or device‑specific issues, not only distance. Proceed with channel and width changes, and compare wired vs. wireless performance. [Elektroda, lipsztajn, post #16679198]
What quick steps improved stability on the TP‑Link WN841N?
Reset or reboot the router, then fix the Wi‑Fi to channel 1 and 20 MHz width. This reduced drops and improved consistency for the affected laptop. Keep other settings unchanged during testing to isolate the effect. [Elektroda, bogiebog, post #16680769]
How do I set channel 1 and 20 MHz on a TP‑Link router?
  1. Log into the TP‑Link admin page.
  2. Set Wi‑Fi channel to 1 and channel width to 20 MHz.
  3. Save, reboot router and laptop, then retest speed and stability. [Elektroda, bogiebog, post #16680769]
Chrome freezes and Firefox says no network, but Wi‑Fi shows connected. What now?
This pattern suggests the laptop’s network stack is unstable while other devices work. Restart the adapter, clear saved networks, and test with another browser after a router reboot. If issues persist, apply the channel and width fix and retest. [Elektroda, lipsztajn, post #16679014]
How should I compare wired and wireless performance during troubleshooting?
Connect the laptop to the router with an Ethernet cable and run a speed test. Then test on Wi‑Fi from the same position. Note the difference and re‑test after each change to confirm improvement. [Elektroda, lipsztajn, post #16679415]
What should I share when asking for Wi‑Fi help?
Provide a simple network diagram, router model, floor layout, and inSSIDer screenshots. Experts often ask to “show results,” which speeds diagnosis and avoids guesswork. [Elektroda, bogiebog, post #16679606]
