SAMSUNG GALAXY S5: Unresponsive Touchscreen After Partial Disassembly Attempt
Cholek7 4917 4
  • #1 16240004
    Cholek7
    Hello! :(
    I had a dirty (inside) front camera and wanting to clean it I tried to disassemble the phone according to all tutorials.
    I did it too, but I didn't pull out the whole screen to the end, only in the corner I gently tilted it to clean it.
    I tried to pull out the whole screen later but it didn't go very well so I gave it up.
    (Now the action begins)
    I turned on the phone (I have a fingerprint lock) and then wanted to enter the password (everything works)
    I click "OK" to confirm the password and here BANG! Does not respond!
    The whole bottom row, i.e. OK /./ Space / next to the settings / SYM button do not respond at all.
    I restarted, changed passwords, pressed the phone in this place, heated it again, etc.
    THREAD. Nothing helps.
    Maybe someone had the same and can help !?
    Please, help you. I have a hard time with cash and I won't be able to buy a new phone and the S5 has been used for 3 years, and now I can't even unlock it :( (
    Best regards and please help! :(
    sylweksylwina
    Help: 1884
    Rate: 2357
    You have probably damaged the touch, and rather the exchange remains. As in S5 I pulled out the screen and pasted it continued to work. You will unlock the phone by means of a mouse and a USB OTG adapter.
  • #3 16240075
    Cholek7
    @sylweksylwina just so stupidly had to damage, because it works everywhere I "touched" it and where I did not move does not work .. But thanks for the advice !! Although I reflect him! ;)
    sylweksylwina
    Help: 1884
    Rate: 2357
    If you removed the screen, you might notice damage. But for now, unblock and pull data from it because when you peel off the display you will see nothing ;)
  • #5 16240105
    Cholek7
    Now, I'll give it a rest, not to make a mess. I just wonder what the reason is. Internal violation (crushing etc.) - NO, because I did not move that place. Tearing some contact? Maybe when I drove around the card to undermine, I moved the glue somehow, and this causes pressure on the point so it doesn't work? I do not know. Maybe what I write has nothing at all, but I am a bit surprised that Shift, z, x, c, v, b, n, m, Delete work, and after a break between them and the buttons below nothing reacts : /
