Windows media player how to disable wmpnscfg.exe from autostart + FRST logs
Zapfod 4776 10
How can I stop wmpnscfg.exe from starting automatically with Windows?
Disable the Windows Media Player Network Sharing Service and turn off media sharing in WMP by going to Library -> Media Sharing and unchecking "Share my media" [#16241456] If the service is already disabled and the process still appears, the FRST logs in this thread did not show anything interesting [#16248639]
  • #1 16241450
    Zapfod
    Rate: 19
    How to disable the wmpnscfg.exe process so that it does not start with the system. It is not visible in Windows options, just like in Ccleaner. The registry in Run / RunOnce is also empty. I have disabled media streaming in Windows media player, but the wmpnscfg process keeps popping up.
  • #2 16241456
    dt1
    Admin of Computers group
    Help: 7318
    Rate: 8296
    Welcome. This process probably runs as a service. Check the services and if you find such a service, disable automatic start for Windows Media Player network sharing service .
    Perhaps you can turn it off too:
    Windows Media Player -> Library -> Media Sharing ... -> uncheck "Share my media".
  • #3 16241459
    Zapfod
    Rate: 19
    I only have such options in the library options
    I also checked in the task schedule and there the "UpdateLibrary" option for which this process is responsible is also turned off.
    • Windows media player how to disable wmpnscfg.exe from autostart + FRST logs wmp.jpg (126.74 KB) You must be logged in to download this attachment.
  • #4 16242275
    dt1
    Help: 7318
    Rate: 8296
    In that case, check that you have the service I mentioned enabled in your services.
  • #5 16244113
    Zapfod
    Rate: 19
    Yes, I have this service disabled
    • Windows media player how to disable wmpnscfg.exe from autostart + FRST logs wmp2.jpg (125.1 KB) You must be logged in to download this attachment.
  • Recommended tools for disabling WMP network sharing
    #6 16244118
    nostromo
    Rate: 23
    He got it m that you have Win10? Download a few tools: 10AppsManager, ProcessExplorer, and preferably a set of tools prepared by Windows programmers: SysinternalsSuite. The only problem is that if you are a regular user of Microsoft's win10 virus, then without someone who knows how to reboot your system and disable its spyware features, you won't be able to do it.
    Added after 11 [minutes]:
    If you have Win 7 here you have the link: http://sasni.eu/archives/504-wylaczanie-udostepienia-w-sieci-wmp.html
  • #7 16244216
    Dra98
    Help: 1321
    Rate: 1076
    Zapfod wrote:
    wmpnscfg.exe
    Zapfod wrote:
    I have this service turned off
    The file can be used to hide malware files [what is the location of this file?], I suggest checking Malwarebytes Anti-Malware and AdwCleaner.
  • #8 16248547
    Zapfod
    Rate: 19
    Scanning Malwarebytes Anti-Malware and Antivirus did not detect anything. On the English-language forum I found information that someone had a problem adding new songs to their library at WMP. As I don't use WMP, I deleted the library from Media Player's memory. After deleting files from appdata> local> Windows> Media Player, this process is only visible in C: Windows> Preftech in the task manager, I did not notice it starting.
    Today, before turning on the computer, I disconnected the router and the process did not get up with the system, but when I connected it, it started. In the attachments I put the FRST logs, if the logs are clean, I will give up this process
    • Addition.txt (21.67 KB) You must be logged in to download this attachment.
    • FRST.txt (14.1 KB) You must be logged in to download this attachment.
  • #9 16248627
    Zapfod
    Rate: 19
    If the Administrator / Moderator could move to the appropriate section I would be grateful.
  • #10 16248639
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    There is nothing interesting in the logs.
  • #11 16248652
    Zapfod
    Rate: 19
    Then I will give up this process and thank you for checking the logo and everyone who tried to help
The discussion revolves around disabling the wmpnscfg.exe process from autostarting with the system. The user has already disabled media streaming in Windows Media Player and checked various settings, including the services and task scheduler, but the process continues to appear. Suggestions include checking the Windows Media Player Network Sharing Service, using tools like 10AppsManager and ProcessExplorer, and scanning for malware with Malwarebytes Anti-Malware and AdwCleaner. Ultimately, the user found that disconnecting the router prevented the process from starting, indicating a potential network-related trigger. After reviewing FRST logs, the user decided to give up on the process as the logs showed no issues.
