[Solved] Utorrent Auto-Starts on Win 10 System Startup Despite Disabled Settings: Troubleshooting
kolosus708 9606 10
Why does uTorrent start with Windows 10 startup even though autostart is disabled, and how can I find the hidden startup entry?
Check for a hidden startup entry with Autoruns from Microsoft or another autostart manager such as CCleaner, because uTorrent may still be registered outside Task Manager’s Startup tab [#17266862] [#17267424] You can also inspect msconfig’s Run tab, although in this case it was not listed there either [#17266872] [#17266875] FRST logs did not show uTorrent starting with the system, so the advice was to search all Autoruns locations instead of relying only on Task Manager [#17266920] [#17267424] In the thread, the issue later stopped happening on its own without any changes [#17271548]
  • #1 17266747
    kolosus708
    Rate: 9
    Hello, as in the topic utorrent turns on after the system startup, although in the options I turned it off so that it does not start, and the task manager does not have it. The operating system is Win 10.
  • #2 17266862
    ak6
    Help: 156
    Rate: 139
    Try disabling it with some autostart management tool. You will find this option, e.g. in CCleaner.
  • #3 17266872
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    Run "msconfig" and check if it appears in the "Run" tab.
  • #4 17266875
    kolosus708
    Rate: 9
    In win 10 msconfig is in the task manager and is not there
  • #5 17266920
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Include in the attachment logs from FRST, from scanning (addition and frst.txt).
  • #6 17267043
    kolosus708
    Rate: 9
    Computer freshly formatted
  • #7 17267080
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    Well, so what? Perform a scan and attach the logs you were asked to.
  • #8 17267132
    kolosus708
    Rate: 9
    Here they attach the files mentioned above
    • FRST.txt (115.96 KB) You must be logged in to download this attachment.
    • Addition.txt (21.44 KB) You must be logged in to download this attachment.
  • #9 17267424
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    The logs do not see that utorrent started with the system.
    Download autoruns from ms page and check if you have utorrent entries anywhere.
  • #10 17267529
    kolosus708
    Rate: 9
    There is no torrent there and it still starts.
    Added after 8 [hours] 34 [minutes]:
    He hasn't joined today.
  • #11 17271548
    kolosus708
    Rate: 9
    I don't know why, but it stopped switching on at the start, I haven't touched anything since.
The discussion revolves around the issue of uTorrent automatically starting on a Windows 10 system despite the user disabling the setting. Various troubleshooting steps are suggested, including using autostart management tools like CCleaner, checking the "Run" tab in msconfig, and utilizing Autoruns to identify any hidden entries. The user confirms that uTorrent does not appear in the task manager or Autoruns, and after a period of time, the issue resolves itself without any changes made by the user.
