ASUS RT-AC1200G+: Port Forwarding for Plex Server (192.168.1.7) and Troubleshooting Guide
lolwat 3930 6
  • Troubleshooting ASUS port forwarding to Plex server
    #1 16243748
    lolwat
    I have a problem with port forwarding on the new router, which despite the settings in all ways (disable hardware acceleration, firewall) does not want to let traffic to the device on the network. In short, I would like to expose the plex server (ip in lan 192.168.1.7) to the world, just like on the old router.
    In netiaspot it looked like this:
    However, in the new asus like this:
    I tested in ASUS on TCP / UDP only - no difference. ASUS does not want to let go of the traffic even if I put ip with plex to DMZ. Configuration from the server side unchanged.
    Do you have any ideas, what else can I check?
  • #2 16243761
    jimasek
    Help: 3783
    Rate: 2682
    Did you change the link too? On Asus's WAN, do you have a public IP for this redirect to work?
  • #3 16243778
    lolwat
    the link is the same all the time, public IP, I can easily connect to FTP / SSH on this ip from the phone
  • #4 16243789
    jimasek
    Help: 3783
    Rate: 2682
    Do you have access to this server in the local network?
  • #5 16243799
    lolwat
    Unfortunately, no, I have access to its management panel (on a different port), but not to the service itself.
    FTP connects to internal and external IP
  • #6 16243867
    jimasek
    Help: 3783
    Rate: 2682
    If you do not have access to the server on the local network, how can you have it over the internet? The service / server is down or misconfigured and that's where you need to start your activities.
  • Firmware downgrade restored Plex port forwarding functionality
    #7 16243883
    lolwat
    plex seems to get the confirmation of the user's account from the net and only releases it, normally there is a link to this server on the above-mentioned port in the lan and I am able to manage this service.
    However, the information in manual to the router:
    "CAUTION:
    After enabling port forwarding from the ASUS router
    blocks unwanted inbound traffic from the Internet and allows only
    to responses to requests coming from the LAN. Network client no
    has direct access to the Internet and vice versa. "
    EDIT:
    I did a firmware downgrade and everything works as it should
The discussion revolves around issues with port forwarding on the ASUS RT-AC1200G+ router for a Plex server located at IP address 192.168.1.7. The user is unable to expose the Plex server to the internet despite disabling hardware acceleration and firewall settings. Responses suggest checking the public IP configuration and server accessibility within the local network. The user confirms they can access the management panel but not the Plex service itself. Ultimately, the user resolves the issue by downgrading the router's firmware, which restored proper functionality.
