AEG T67680IH3 Dryer: Troubleshooting Error E50 & Testing Non-Starting Issue After 2 Minutes
leszekg20 8232 5
  • #1 16244631
    leszekg20
    Please give me a hint on how to test the E50 error, the dryer does not start after about 2 minutes, the E50 error pops up.
  • #2 16244732
    Piotr2608
    Help: 851
    Rate: 4487
    The E50 error series is associated with damage to the engine or its control: relays, triac, tachogenerator, brushes.
    ZimTech Piotr Zimny
  • #3 16245619
    Trull
    Help: 138
    Rate: 600
    Piotr, and in the dryers there is no motor with a compact core? Rather, the excitation capacitor should be checked, it should be 5 uF / 275-400V.
    Secondly, the module. The solder on the R99 - 47? resistor often cracks, which results in the lack of control of the TY1 - T4 triac.
  • #4 16245966
    Piotr2608
    Help: 851
    Rate: 4487
    A condenser in a dryer from 2014-2016? I'm not going to argue ;) but I am concerned about the inverter module, which would indicate that we have a three-phase induction motor installed and in the inverter module I would look for the cause.
    I am asking the author of the topic for the identification number - product code.
    ZimTech Piotr Zimny
  • #5 16256486
    leszekg20
    Type.TC12H6DHP Prod. No.916 097 513 01
  • #6 16257164
    Piotr2608
    Help: 851
    Rate: 4487
    E50 is it really? Maybe it's an E5D error - which would mean an unknown motor inverter error.
    Anyway, the inverter module to be checked and the motor winding. The motor has no brushes, the resistance between the three motor leads must be the same.
    ZimTech Piotr Zimny
