Electrolux EIED200QSW Dryer E50 Error After Motor, Blower, Sensor Replacement
service14 1032 2
  • Stops after about 30 minutes with no other symptoms
    #1 21686515
    service14
    Need help with an Electrolux compact condenser dryer Model # EIED200QSW. Dryer runs for a while then stops and displays an E50 error code. We've replaced the motor, blower wheel, and temperature sensor but still having the same issue.
    AI: Besides replacing the motor, blower wheel, and temperature sensor, have you checked the wiring, control board, or any connections for damage or loose contacts?
    Yes
    AI: Does the dryer make any unusual noises, smells, or show any other symptoms before it stops and displays the E50 error, or does it always stop after a certain amount of time?
    No, just stops after approx. 30 minutes.
  • #3 21687101
    service14
    >>21686849 that wasn't it. It was for a different model dryer
