Phone AX LTE: Charging Only When Off - Micro-USB Connector Repair/Replacement Issues
przemotco 4974 4
  • #1 16244955
    przemotco
    Rate: 10
    A colleague came to me with a phone with a rather strange problem, namely the phone only charges when it is turned off. When it is turned on and the charger is connected, there is no reaction in the phone. Checked on two chargers, nothing happens when connected to a computer.
    The phone was just picked up from the service where the Micro-USB connector was repaired / replaced.
    What could be the reason ?
    Best regards.
  • #2 16244987
    actin
    Help: 187
    Rate: 799
    It looks more like a system error than a socket.
    After connecting the power supply, there is no reaction?
  • #3 16245035
    przemotco
    Rate: 10
    No reaction whatsoever, as if the phone was not connected at all
  • #4 16245498
    actin
    Help: 187
    Rate: 799
    Have you tried to restore the factory settings?
  • #5 16245598
    przemotco
    Rate: 10
    Unfortunately, no, it is a business phone, it would have to make copies of data first.
