Samsung Xcover 3: Touch Screen Only Works for 2 Minutes Post-Replacement and Restart
wojtala01 3099 5
  • #1 16247157
    wojtala01
    Hello, I am writing because I have encountered such a problem for the first time. Well, a client brought me a Xcover who had a meeting with a screwdriver. After replacing the screen and fast. The touch works 2 minutes after turning on the phone. And it does so every time you restart it. And I don't know what it depends on. Touch fault? Or the screen? Although I ordered everything original.
    best regards
  • #2 16247171
    KamGr
    Help: 77
    Rate: 203
    I had a similar problem recently, only that I only replaced the digitizer and the touch did not respond at all. I was helped by washing the contacts from the LCD and IPA touch and full wipe. After that, everything started to work normally.
  • #3 16252776
    siudziu
    Help: 57
    Rate: 113
    I recently bought a crap touch on the allegro and it didn't work after filling the ribbon all the way. I just had to slide it in a little, not to the end and in this position it worked, you can try it.
  • #4 16252834
    wojtala01
    The thing is that I do not order from Allegro. I already have my own warehouse, but for the first time in a long time I had such a case.
  • #5 16252905
    KamGr
    Help: 77
    Rate: 203
    If so, advertise it. If nothing else helps, there is no way out.
  • #6 16252917
    wojtala01
    The second is due on Monday, then we'll see what it will be like. But it should probably not be the case if the original equipment. But you know, sometimes there are
