Samsung Galaxy A3 SM-A300FU - Touch doesn't work in some places
131XIII 5958 2
  • Charging-related touch interference suspected
    #1 16767298
    131XIII
    Rate: 48
    I have such an unusual problem with the galaxy a3, namely the touch begins to freak me out (friend's phone)
    According to a friend from the right, the touch does not regulate, e.g. if I want to change the camera on my camera, it can't be done, or if I want to type the letter "k" in the keyboard, I press "jil"
    I entered * # 0 * # in the dialer and gave a screen test and in fact I don't get touch in a few places
    Now I hooked it up to the charger and left it for a while, it stopped for now, everything okay
    Anyone got any idea?
    Could it be a fault of the software?
    The telephone had no fall
    best regards
  • #2 16767376
    jacusix
    Help: 6
    Rate: 118
    If you have the opportunity to check the tape from the digitizer, then I would start but from experience I know that it is usually the fault of the touch itself, i.e. replacement.
  • Fault may be in display or motherboard touch circuit
    #3 16767544
    mahamalak
    Rate: 110
    Sometimes it is the fault of the touch / display itself, where some system fell or other damage occurred on the tape, here is an example of such repair in J3:
    It also happens that this type of error is related to damage to the system on the motherboard, below is an example of repair for the iPhone 5C:
    The easiest way is to connect another display and then be sure.
