Unexpected Power Loss in Toyota Avensis T25 1.8's Radio - Fuse and Wiring Check
doubleube 23940 12
Why did the radio in a Toyota Avensis T25 suddenly lose power even though RAD No.1 and RAD No.2 fuses are OK and there is no voltage at the radio connector?
If the fuses are good but the radio still has no +B/ACC supply, the fault is in the wiring/connector path or inside the radio itself; in this case it was finally fixed by removing the radio, opening it, and resoldering a suspicious joint [#16259448] Before that, the advice was to check the relevant fuses and circuits with a test bulb, not only with a continuity meter, because a meter can miss a bad load-bearing connection [#16247748][#16250143] The wiring diagram points to B+ going directly through the CE-CB connector and RAD 2 fuse to the radio, so that path should be checked carefully if both +B and ACC are missing [#16250154][#16250188] If ground is present but both power feeds are dead, the most likely causes are a broken wire, a bad connector, or a cold solder joint in the unit [#16249527][#16259448]
  • #1 16247516
    doubleube
    Help: 5
    Rate: 27
    As the topic
    safe fuses RAD No.1 and RAD No.2 (with continuity meter), and the radio does not work.
    The radio is removed and there is no tension on the ankle :(
    What's up ??
    Is there a joint on the way?
    I would like to add that everything else works, and it happened so suddenly, just one morning dark / dull.
  • #2 16247568
    krzychu001
    Help: 11
    Rate: 204
    Check other bzp too.
  • #3 16247701
    doubleube
    Help: 5
    Rate: 27
    Rather the other is not, because half the car would not work, and everything works rather.
    The worst thing is that access to fuses is a nightmare, and I will check the meter for fuses today
  • #4 16247748
    CameR
    Moderator of Vehicle Security
    Help: 1141
    Rate: 3277
    Use a standard bulb to check the fuses.
    One pole to ground - the other one applies successively to both fuse pins.
    Of course, the light bulb shines on both fuse leads.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #5 16249231
    doubleube
    Help: 5
    Rate: 27
    the fuse has the correct voltage (so far the meter),
    so there must be a connector along the way or the cord has been damaged, but how?
  • J8 connector location and missing B+ and ACC voltage question
    #7 16249527
    doubleube
    Help: 5
    Rate: 27
    thanks
    I have already had this diagram for a long time and it does not say anything to me anymore, because everything has already been checked out, free. Tips 1 and 2
    I have a question where is the J8 connector located?
    just what makes me wonder
    there are two circuits + B and ACC from different modes and on both there is no voltage
    what is?
    and the car is burning, driving and braking :)
    in the attachment radio connection diagram Radio dia..am.pdf (44.03 kB)You must be logged in to download this attachment.
  • #8 16250143
    krzychu001
    Help: 11
    Rate: 204
    Check the circuits with a light bulb as CameR advised.
  • #9 16250152
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1710
    Or maybe no weight and no + bi acc?
  • #10 16250154
    krzychu001
    Help: 11
    Rate: 204
    According to the scheme, B + should go directly, one cable without connection from the fuse to the radio.
  • #11 16250158
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1710
    Key backlight works?
    Added after 43 [seconds]:
    What radio?
    T25 lift czy przedlift?
  • #12 16250188
    doubleube
    Help: 5
    Rate: 27
    the mass is.
    the backlight does not work because there is no power supply as it is written
    B + goes through the CE-CB connector and two fuses (RAD 2 safe)
    radio before FL (2003) or W53901
  • #13 16259448
    doubleube
    Help: 5
    Rate: 27
    The matter resolved, it's better not to write :( obciach
    The power supply turned out to be, because I was suggesting the colors of the wires, and that the frost and poor weather conditions were approaches were in a hurry and a nervous condition :)
    Radio removed, dismantled, soldered suspicious February and the game.
    For future masters, the plugs are opened Unexpected Power Loss in Toyota Avensis T25 1.8's Radio - Fuse and Wiring CheckIMG_201702...152908.jpg (2.94 MB)You must be logged in to download this attachment.
The discussion revolves around an unexpected power loss in the radio of a Toyota Avensis T25 1.8. The user reports that after checking the fuses (RAD No.1 and RAD No.2) with a continuity meter, the radio remains non-functional despite other car systems working. Suggestions include checking additional circuits, using a light bulb to test fuses, and investigating potential wiring issues or connectors along the power path. The user later identifies that the problem was due to damaged wires caused by adverse weather conditions, which were repaired, restoring functionality to the radio.
