Tfsi 2.0 bwa 2006 - Crankcase venting can be partially blinded
buchaj1 11313 14
Can I safely install a PCV delete kit on a 2006 Golf Mk5 GTI 2.0 TFSI BWA to stop oil vapors entering the intake, or must the crankcase ventilation remain connected through an oil separator?
Do not completely block the crankcase ventilation, because the vapors must be discharged and trapped pressure can lead to oil leaks and other problems [#16248242][#16248040] The discussed delete kit is not a true solution: it routes the vapors and oil into the intake near the turbo, so contamination of the valves and manifold remains, while also exposing the turbo and intercooler to oil [#16251622] If you want to keep vapors out of the intake, use an external oil separator or catch can connected to the crankcase/valve-cover ventilation and empty it regularly [#16248242][#16252368] The original valve normally allows a small amount of oil into the intake, and if there is no significant oil loss or evidence of boost leakage, replacing or deleting it is unlikely to provide a noticeable improvement [#16247943][#16248273] Intake-valve carbon buildup is not caused solely by the PCV system and remains a known issue on these engines [#16248158]
  • #1 16247928
    buchaj1
    Rate: 20
    Hello, I am thinking of such a thing for my golf mk5 GTI - http://www.forgemotorsport.co.uk/VAG_20TFSI_PCV_Delete_Plate--product-- 1361.html I wonder if this is good for this engine? The original looks like this - https://www.google.com/search?q=pcv+tfsi&clie...=X&ved=0ahUKEwi2kIis6_HRAhWDQJoKHV5UIBQ4CBWUU And what I want to put on like this - https://www.google.pl/search?q=pcv+tfsi&clien...sch&sa=X&ved=0ahUKEwi2kIis6_HRAhWDQJaKH__H&Ap is it safe Because the discharge of vapors to the intake manifold is completely blinded (or maybe I'm wrong and it works on a different principle)! Has anyone used this set or is it better to buy the original PVC valve? If this is not a good solution, I would ask for an explanation for what? And if it is not bad, I would also ask for some explanations. The reason I want to change it is because the original valve withdraws some oil to the intake manifold. thank you in advance for your time.
    szymitsu21
    Help: 343
    Rate: 1300
    In the crankcase, if vapors are not sucked out, oil will start to appear everywhere.
    So it's better to put the original on it should work, by the way, know that every single valve will have a minimum amount of oil flowing into the intake manifold.
    If there is no visible oil loss, I would not look for a problem.
  • #3 16247975
    buchaj1
    Rate: 20
    Well, there is a loss of oil, but this is a problem of these engines. The valve wants to be replaced for one more reason, actually two that I did not write about earlier, namely as we know it is a turbo engine and in various places I have encountered statements that the original PVC valve has supercharging pressure loss because this valve does not hold pressure. The second reason is that this valve probably contributes to heavy contamination of the intake valves - https://www.google.com/search?q=tfsi+intake&c...sa=X&ved=0ahUKEwjdhVYWBQQQQQQQQQQQQQQQQQQQQHQ 1280 & bih = 800 # tbm = isch & q = tfsi + valve + clean & imgrc = 1FlGBWeQDbX5eM: it looked similar to me last year. I wonder how my valves look like after a year of cleaning. I will only add that in these engines there is one more vent from the valve cover for the turbine - https://www.google.pl/search?q=tfsi+breather+...enovo&prmd=isvn&source=lnms&tbm=isch&sa=X&ved 0ahUKEwiZq_nB8fHRAhUFQZoKHUMYBUoQ_AUIBygB & b and = = 1280 & bih = 800 # = imgrc d9mFrHL-_Mt9QM:
    szymitsu21
    Help: 343
    Rate: 1300
    You know the topic better than I do :)
    As for valve heating, will they heat up anyway?
    This is unavoidable, but the fact can be kept to a minimum.
    And as for turbo pressure and leaking pneumatic valve, even a small blow to the crankcase causes oil leaks from the cork, bayonet etc. So if these symptoms are not there is probably nothing to look for.
  • #5 16248051
    buchaj1
    Rate: 20
    I also found such a drawing in the network https://www.google.pl/search?q=pcv+delete+kit...&prmd=isvn&source=lnms&sa=X&ved=0ahUKEwhBQHQQ & isch = q + pVC + valve TFSI & imgrc = -m6fefVfgLQR_M :. I conclude from this that the original "PVC delete kit" will completely blind the exhaust gas from the engine? This is probably not healthy for the engine? I don't know anymore.
    Added after 4 [minutes]:
    As for the crankcase, there is a large negative pressure, as when idle, remove the dipstick or oil plug, the car does not go smoothly and goes out
    leotdipl
    Help: 51
    Rate: 153
    buchaj1 wrote:
    Well, there is a loss of oil, but it is a problem of these engines. The valve wants to be replaced for one more reason, actually two that I did not write about earlier, namely as we know it is a turbo engine and in various places I have encountered statements that the original PVC valve has supercharging pressure loss because this valve does not hold pressure. The second reason is that this valve probably contributes to a heavy pollution of the intake valves ... I wonder what my valves look like one year after cleaning.
    a colleague @szyitsu advises you well.
    1) Oil loss = what oil (brand, class) did you fill and how often do you change?
    2) Dirty valves = it's not just PVC and oil entering the intake manifold.
    It is also a problem of impurities accumulating in the manifold and on the valves resulting
    from oil imperfections in the charging system (hence they must meet the VW 504.00 class,
    and preferably 507.00 - low ash, low sulfur content, etc.). Fuel pollution also does its job.
    Anyway, the problem of carbon deposits in the intake manifold is unavoidable! On average, it is assumed that for 120 tkm it is already certainty.
    Short distances shorten this mileage.
    There are various methods for cleaning deposits of carbon deposits. Both mechanical and chemical. There is no perfect method.
    Below is the topic from the audi forum:
    https://a4-klub.pl/topic/272895-18tfsi-i-20tfsi-problemy-z-klapami-i-dolotem/
    It is worth - as your colleague advises there - to check the static position of the flaps (this is a sign of the problem soon).
    At home I have a VW 2.0 TSI 170kM engine. From the beginning (still under warranty!) The first thing I did was change VW Longlife oil
    on Motul Specific 504-507 5W30 oil (504-507 are classes 504.00 and 507.00 VW). Since then, the oil has ended (and this was the case with Longlife VW)
    and for now (knock) keeps the level from exchange to exchange (every 1 year).
    PS.
    Let it not be - I am not a seller or Motul oil booster.
    It is simply the third car in which oil of this brand is used (2 others
    after tuning). And I've never had problems with them.
  • #7 16248161
    buchaj1
    Rate: 20
    Here I found such explanation in the pictures https://www.hg-motorsport.de/shop/product_inf...7657_PCV-FIX-fuer-VAG-2-0-TFSI-Modelle-mit-E4 -E5.html. So it turns out that the vent from the crankcase is to the valve cover and with this modified PVC gas outlet there is nowhere from the valve cover? What could happen in this case?
    Added after 11 [minutes]:
    oil imperfections (hence they must meet the VW 504.00 class, and preferably 507.00 - low ash,
    PS.
    The oil I use is motul x clen 5w40, changing every year - oil losses are not great from replacing to replacing 1l to 2l I don't know how many kilometers I do, but I care more that there would be no loss on turbo boost than on clean valves (I can always I have already cleaned it once) and the loss of oil is not a big problem so far, I take into account that these engines have it.
    The question was regarding the plugging of the PVC valve what side effects and maybe some improvement? Anyway thanks for your interest in the subject.
    leotdipl
    Help: 51
    Rate: 153
    PVC is the venting of the crankcase ("discharge" of excess pressure from the box) so only blinding it is a bad pseudo-idea ...
    These oil vapors must be discharged somewhere. If you do not want to the collector - as it is factory made - you have other external solutions.
    Even something like this (with a vapor / condensation tank):
    http://www.uspmotorsports.com/BSH-Competition...kswagen-MK5-Jetta-GTI-MK6-Golf-R-2.0TFSI.html
    or
    http://bshspeedshop.com/bsh-fsi-competition-catch-can/
    szymitsu21
    Help: 343
    Rate: 1300
    And pro after the loss of recharging, I'm quite sure that you will not notice the change after blinding PVC.
    So there is no point (this is my opinion)
  • #10 16248276
    buchaj1
    Rate: 20
    Well, I thought that this is not a good solution, this plug (well, unless then everything goes with a second vent to the turbine) but I do not know. I can only see that a lot of people install this pvc delete kit, but most of them are abroad and there is nobody here to ask about experience with this product. I found this set in China for aliexpres below PLN 100 so I will probably order it, but if I mount it yet I don't know, I have to be sure that it will pass the exam without damaging the engine.
    Probably you are right. I will probably give up on this subject as long as the original valve works. I thought that it might not improve the factory at a great cost, but probably not in this case.
  • #11 16248291
    leotdipl
    Help: 51
    Rate: 153
    buchaj1 wrote:
    Well, I thought that this is not a good solution, this plug (well, unless then everything goes with a second vent to the turbine) but I do not know. I can only see that a lot of people assemble this pvc delete kit, but most of them abroad ....
    I supplemented my second post with a link - look for something like this.
  • #12 16248350
    buchaj1
    Rate: 20
    [Quote = "leotdipl"]
    I supplemented my second post with a link - look for something like this. [/ quote
    I have encountered these solutions seem to be ok except for one huge disadvantage - the price.
  • Oil separator needed to prevent intake contamination
    #13 16251622
    buchaj1
    Rate: 20
    Welcome back. I don't know if anyone is interested but I already know what and how with this "pvc delete kit". Namely, the set I asked is not good because it is solved in such a way that all the vapors and oil after installing this set get into the intake system near the turbine which still equates to the siphoning of the valves, the manifold and there is also an intercooler and a turbo . The only right solution is like the colleague mentioned above - a set with an oil separator. The price of such sets knocks, but I think it can be done much cheaper (I have already started to create a similar set) oil separator can be bought for about PLN 100 for this hose of the band and a plate for the valve cover with 3 pieces - I make it from an old pvc valve - cut off from it a pear with a membrane and in this place I pasted 2 connectors for mounting hoses to the oil separator, I think it will pass the exam. Regards.
  • #14 16252368
    leotdipl
    Help: 51
    Rate: 153
    buchaj1 wrote:
    Welcome back. The price of such sets knocks, but I think it can be done much cheaper - I make it from an old pvc valve - I cut off a pear with a membrane from it and in this place I pasted 2 connectors for mounting hoses to the oil separator, I think it will pass the exam. Regards.
    don't forget about the outer tube (catch tank),
    which shows the level of accumulated oil (you need to empty the tank regularly).
    something like that:
    http://www.driftshop.pl/shop/?554,zbiorniczek-odmy-separator-oleju-(oil-catch-tank
  • #15 16290155
    buchaj1
    Rate: 20
    Hello again, I did such a thing
    https://zapodaj.net/eae9e4ed73a19.jpg.html
    noticeable changes are as if the engine worked more evenly. It cost me a bit of work and maybe PLN 150 works well. Best regards and thank you for your help.
The discussion revolves around the potential installation of a PCV delete kit for the 2.0 TFSI engine in a Golf MK5 GTI. The original poster expresses concerns about oil loss and contamination of intake valves due to the factory PCV valve. Responses highlight that while oil loss is common in these engines, completely blocking the PCV system is inadvisable as it can lead to increased pressure in the crankcase and potential engine damage. Alternatives such as oil catch cans and separators are suggested to manage crankcase vapors effectively without compromising engine performance. Users share experiences and emphasize the importance of maintaining proper ventilation to avoid issues with oil accumulation and valve cleanliness.
