Best Router for 49 m2 Apartment: TP-Link TL-WDR3600 vs Connect Box Compal CH7465LG
Masownik26 3429 14
Which router should I use with UPC’s Compal CH7465LG modem-router in a 49 m² apartment, and will it support Wi-Fi, port forwarding, and 120 Mbps internet?
Use the Compal CH7465LG as the UPC modem and place a separate router behind it; the thread recommends the newer TP-Link TL-WR1043ND v3 or v4 rather than the discontinued TL-WDR3600 [#16248359] [#16248672] Configure the Compal’s DMZ to the WAN IP address of the secondary router, then connect the TV, console, laptop, and other devices to that router [#16248488] Port forwarding is a standard router function, but it will work from the Internet only if UPC provides a public WAN IP [#16248414] Wi-Fi coverage in a 49 m² apartment depends on the building and radio interference, so it cannot be guaranteed from apartment size alone [#16248414] The recommended router should handle a 120 Mbps connection; reaching 250 Mbps over Wi-Fi would require an 802.11ac router and a matching client adapter [#16250535]
  • #1 16248304
    Masownik26
    I will describe the topic. I currently have a TP-Link TL-WDR3600 router at my parents' apartment. Upc is connected to the cisco modem.
    At my apartment I am currently in the phase of mounting UPC and I got from them a modem router that will work like this cisco as a modem, it is the Connect Box vel Compal CH7465LG. From what I've read, it's better your router to flash on wifi and that I could redirect ports (I use torrents and xbox one a lot on the network)
    What would you gentlemen propose for a router to a 49 m2 flat in a large room would be a router and connected to it TV by cable, console by cable and laptop if I would download it also by cable. However, after wifi laptop from time to time and a tablet. Can an identical TP-Link TL-WDR3600 be used?
  • #2 16248359
    jimasek
    Help: 3783
    Rate: 2681
    It is already a router that you have your years and is not developed. I recommend WR1043NDv3 or v4 with 5GHz to C5v2
  • #3 16248400
    Masownik26
    I understand WR1043NDv4 is typing in google but I can't find it anywhere in the stores. Will this router cope with wifi in a 49 m2 apartment? And won't there be problems with port forwarding?
  • #4 16248414
    jimasek
    Help: 3783
    Rate: 2681
    Masownik26 wrote:
    I understand WR1043NDv4 is typing in google but nowhere in the stores
    You can easily take v3
    Unfortunately, I'm not a fairy. It all depends on the building and interference.
    This is one of the basic functions of the router. It all depends on whether on the WAN there will be a public IP from the Internet provider.
  • #5 16248432
    Masownik26
    Well, I can do it now. Do you know what the invention of Compal CH7465LG is? what UPC adds is mzoe to be as a router but i guess i prefer my private plug in though. These tp links what did you provide are some old that so few find them? Because if I can something from another company from Netgar, for example, if it works as it should
  • #6 16248445
    jimasek
    Help: 3783
    Rate: 2681
    Masownik26 wrote:
    These tp links you provided are some old ones that you find so little
    Old??? You probably don't know what you're talking about.
    The modem from UPC must stay in its place and you cannot change or discard it because you will lose access to the Internet.
  • #7 16248470
    Masownik26
    I know that it only needs to be that it can also be a router, so I'm wondering whether to buy your router.
  • #8 16248488
    jimasek
    Help: 3783
    Rate: 2681
    It can even be a router. You do DMZ to the IP address that you set on the WAN router and you have the ability to manage the network from your router. You connect all devices in your home network to the WAN router that's all.
  • #9 16248518
    Masownik26
    oh eee, I think, however, I will decide on this 1 solution this tp link price goes well for v4.0 versions 179 zeta is not much
  • #10 16248541
    jimasek
    Help: 3783
    Rate: 2681
    The choice is yours. I only proposed a solution.
  • #11 16248643
    Masownik26
    ok thanks a lot again for the professional help. Tell me yet, is this TP-Link TL-WR1043ND v4.0 in some sense better TP-Link TL-WDR3600? or just newer? Because this old man I see has 2 bands 2.4 Ghz and 5Ghz. In truth I only use 2.4
  • #12 16248672
    jimasek
    Help: 3783
    Rate: 2681
    A newer hardware solution, WDR3600 is no longer developed.
  • #13 16250526
    Masownik26
    Ok and one more question, will WiFi deal with net 120? And as a precaution, how would I change to 250 in the future or will I be able to change?
  • #14 16250535
    jimasek
    Help: 3783
    Rate: 2681
    At 120Mbps, of course, if you have a 300Mbps network card for 250Mbps internet speed, only a router with "AC" and the same card.
  • #15 16250587
    Masownik26
    ok, that's 120, that's all I was interested in ;)
The discussion revolves around selecting the best router for a 49 m² apartment, comparing the TP-Link TL-WDR3600 and the Connect Box Compal CH7465LG. The user currently has the TL-WDR3600 but is considering the Compal router provided by UPC. Recommendations include the TP-Link TL-WR1043ND (v3 or v4) as a suitable alternative, with discussions on its capabilities for Wi-Fi coverage and port forwarding for torrenting and gaming. The TL-WR1043ND is noted as a newer hardware solution compared to the TL-WDR3600, which is no longer developed. The conversation also touches on internet speed compatibility, suggesting that a router with "AC" capabilities would be necessary for higher speeds in the future.
