Which TP-Link router to choose: Archer A8, AX10, AX23, AX53 - fibre 800/160, LAN 100mb, WiFi 6
javelin11 29100 7
  • Comparing AX23 and AX53 processor and overheating
    #1 20551588
    javelin11
    Helloce, I need to change to a more modern router for a flat of about 50m2 (desktop and laptop on LAN, netflix and smartphones on wifi). I've been using a TP-Link WR841N for many years and this oldie can handle it, but the LAN ports output a max of 100mb and I've had an 800mb net for a long time (mainly this LAN is what I'm after). I'm fixated on TP-Link as that's all I've ever used. Initially I was thinking about Archer A8 (about 180zl) because I don't have great requirements, but in total if I buy this router I will probably use it for 10 years, so maybe it's better to use something more modern (with wifi 6) ? For now it looks like this:
    Archer ax10 / ax1500 - 239zł
    Archer ax23 / ax1800 - PLN 289
    Archer ax53 - 289zł (some promo)
    I was decided on the ax23, but I see the ax53 costs the same, which is a bit strange. The wifi throughput is higher (for me the difference doesn't matter), but I don't know how the subject of processor / overheating ? If they cost the same it is better to take the ax53 ?
  • #2 20551591
    kamillus.ch
    It's hard to dig up info anywhere as to what kind of CPUs are in there. The only thing they write is that the AX23 and AX53 have a dual-core processor, and the AX10 has a triple-core.
  • #4 20551879
    hermes-80
    Help: 1177
    Rate: 743
    Here, the problem is not the model, but the bandwidth it is capable of transferring between LAN and WAN via NAT.
  • #5 20552292
    artaa
    Help: 1819
    Rate: 1700
    I will simplify your life ;-) .
    RT-AX55
  • Concern about router overheating and long-term reliability
    #6 20552409
    javelin11
    RT-AX55
    I know there are different brands, but my old TP-Link has been working for years and nothing has ever happened to it :)
    I have looked at some more tests on the internet, the AX10 I reject because the AX23 performs better, although with normal use the difference is probably not noticeable. However, AX23 vs AX53, in both there will be a 2-core processor. Except that in the AX53 it is supposedly the same as in the AX55 V1 (Qualcomm Technologies, Inc. IPQ5018/TB-MP04), whatever that means. AX53 has more powerful WiFi some 160 MHz channel support.
    Basically the only thing on my mind is overheating because supposedly there were problems with this in the AX50. At my place for now connected will be: PC or laptop, Netflix, 2 smartphones. I do not know what influences the temperature, the number of connected devices or maybe the router itself heats up because it has too weak heatsinks?
    I just want to put it in a corner and forget about it, because I probably will not use it for the next 10 years :) .
  • #7 20552500
    KOCUREK1970
    Help: 3860
    Rate: 5488
    javelin11 wrote:
    ax53 has stronger wifi + some 160MHz channel support.
    And wifi cards, these 160MHz support - because if they don't, a fig with a poppy.
    javelin11 wrote:
    I know there are different brands, but this old TP-link of mine has worked for years and nothing has ever happened to it
    This suggestion is not a TPLink but an Asus RT-AX55.
  • Considering future Wi‑Fi 6 and 160 MHz support
    #8 20553157
    javelin11
    well the 160 MHz ones probably don't support it. for wi-fi 6 I only have a laptop on which I have the net via cable. I assume that this router will serve me for years and it may happen that in a few years I will have new equipment which will use these capabilities. If it wasn't for this, I would take Archer A8 for 180zł and it would also manage :) Well, nothing, I will try to choose something today :) .
    PS. but I'll have a look at what Asus offers yet. From routers/switches I always thought there was TP-Link and D-Link and nothing else :) .
The discussion revolves around selecting a suitable TP-Link router for a 50m² flat, focusing on models Archer A8, AX10, AX23, and AX53, considering an 800/160 fibre connection and 100mb LAN. The user currently uses a TP-Link WR841N and seeks a modern router with WiFi 6 capabilities. The AX23 and AX53 are highlighted for their dual-core processors, with the AX53 offering better WiFi throughput and 160 MHz channel support. Concerns about overheating, particularly with the AX50, are raised, alongside the potential for future-proofing with newer technology. The user is also open to exploring alternatives like the Asus RT-AX55.
