[Solved] Choosing Between TP-Link Archer AX1500 Wifi6 or Archer C80 AC1900 for FunBox 6 Fiber Optic
ubnt013 24390 19
How can I extend Wi‑Fi from a FunBox 6 upstairs to the lower floor so the whole house uses one network, and should I buy an Archer AX1500, Archer C80, an access point, or a mesh system?
To get one Wi‑Fi network across the whole house, a single router like the Archer AX1500 or Archer C80 is not the best choice; with Ethernet already pulled downstairs, a dedicated access point or a small mesh system is more suitable [#19493529][#19494151] One recommended AP option was a Ubiquiti UAP AC LR or UAP AC LITE [#19493364][#19494532] Another practical option was TP‑Link Deco M4 or a similar 2–3 unit system, preferably with LAN ports on the satellites if you need wired devices [#19494649] The forum also noted that such systems can work in AP mode behind the FunBox, and that you should be clear whether you want AP mode or a router/satellite setup [#19494876][#19494922]
  • Recommend a wired access point for downstairs coverage
    #1 19493320
    ubnt013
    Rate: 42
    Hello and welcome
    They installed a fiber optic cable with a Funbox 6 router (600 Mb / s) in a single-family house in the attic, there the wifi works perfectly, unfortunately on the lower floor it is already very poor with coverage. I went downstairs with lane and now I'm wondering what to buy to make the wifi work perfectly
    AP or router I am thinking about
    TP-Link Archer AX1500 Wifi6 OFDMA MO-MIMO router or Archer C80 AC1900 WiFi Wave2 xDSL 3x3 MIMO router
    Please advise what to buy so that it works efficiently, or what other equipment will be appropriate
    Best regards and thank you in advance for your help in choosing the equipment
    jprzedworski
    Help: 758
    Rate: 828
    ubnt013 wrote:
    so that the wifi works perfectly
    Wi-Fi is not a cable and it is far from ideal. In addition, a complete lack of data. We only know it's the ground floor. Area, number of rooms and walls along the way? At 5 GHz, each successive wall represents a degradation in performance. You may find that one device is not enough.
  • #4 19494139
    ubnt013
    Rate: 42
    As for the ground floor, I have pulled up from the FunBox from the attic 2x lan to 2 separate rooms, but only in one I want to have WiFi in the other via a switch (Netgear 1Gb), splits for computer and TV
    Bridge mode would enable a proper router-and-satellite network
    #5 19494151
    RobeMek
    Help: 111
    Rate: 90
    Wherever you want wifi, you only need a router that meets the requirements you want.
    If this wifi is to cover one room, each router solution you have chosen is good, it is possible that the network will also cover the whole house.
    It is a pity that the funbox cannot be switched to a bridge because then you can make a decent network based on a router and satellites where you need a cable or wifi
  • Need a router for whole-house coverage
    #6 19494519
    ubnt013
    Rate: 42
    Ok thanks for the info
    I am asking for info on what router to buy because I would like there to be one network throughout the house, both in the attic and in the room downstairs
    Sorry for the questions but I am a layman in these topics and I do not want to buy something that will not work.
    Kind regards
    sebap
    Help: 538
    Rate: 1080
    Erbit wrote:
    Something from Ubiquiti, e.g. UAP AC LR / UAP AC LITE.
    Recommend a mesh system with LAN-equipped satellites
    #8 19494649
    RobeMek
    Help: 111
    Rate: 90
    Exactly something like that, but for me it is worth buying a system based on 2-3 satellites.
    Easy and quite cheap TP-Link Deco M4 or NETGEAR Orbi RBK12 + 2-3 satellites.
    I would recommend the more expensive Orbi, but these systems are too expensive because they already reach thousands at home, rather not useful, but working great.
    With such a set, you connect the router to the LAN in the room whatever you want and the satellites are where you need them. The disadvantage usually have one LAN output or not at all and are only WIFi extenders.
    If you are looking for similar ones, always pay attention to whether the satellites have LAN output.
    If you were looking for it, look for systems of the type MESH , you can easily find at a price similar to the router what you planned to buy.
    Simple mesh sets suit few devices better
    #11 19494850
    RobeMek
    Help: 111
    Rate: 90
    Yes, but this is only a proposal because sometimes the sets and configurations are mass to choose from.
    The point is that most satellites sometimes it has one or two LAN outputs or none at all .
    It is easier for him to start looking, knowing what system it is about and choosing according to his requirements, i.e. that there is a LAN.
    @Erbit I know that there are MESH for everyone and for those who can afford to pay a kilo of papers.
    After all, I will not propose Tri-Band sets with beamforming, because probably there will be no more than 3-4 devices using the Internet in use. Simple sets work well as 2-3 devices use each satellite. Moreover, it is easy to configure.
    I used the Orbi RBK20 sets for a while, and then I changed them to the RBK50 and the difference was colossal with 20 devices connected to the net, mainly via wifi.
  • Mesh kit offers whole-house coverage and one network
    #13 19494906
    RobeMek
    Help: 111
    Rate: 90
    In my opinion, the AP can work, but take into account that it already has a cable tucked under which you can connect a simple set of two-piece router and satellite seems to be more practical.
    He will have the choice of using the Funbox network or the other one from the set.
    Alternatively, it will turn off the WiFi in Funbox and use the kits that will be bought, for example, a router + 2 satellites and has literally the entire house coverage, constant access to one network without switching between WiFi networks.
    The sets can be easily connected to the router, although it is known that they would work better on the router in modem mode. Then it has full functionality with its own VPN. ;)
    The Orbi does not differ much from the M4, practically the same, but with better parameters. Exactly what I gave is cheaper.
    Mesh marketing is not a universal recommendation
    #14 19494912
  • AP mode can cause roaming problems with existing Wi‑Fi
    #16 19495015
    RobeMek
    Help: 111
    Rate: 90
    Getting rid of WiFi from FB and using a new router and satellites in AP will provide full MESH.
    The mode does not matter if the M4 acts as a router creating its own wifi network or AP (basically the same as BRIDGE with WIFi extension) using the existing one, the DHCP configuration is just different.
    The AP usually restricts the functionality of operation and disables some of the router's options, which rather ordinary user do not use, but may be useful to improve network performance. Regardless of the connections, I try to always use the normal router mode and use the AP only with compatible equipment, e.g. connecting two or three M4s into one network with high coverage.
    As I noticed, such connection with the AP mode and the existing WiFi of the router without turning it off can sometimes cause problems, e.g. if you catch the signal from the main router, it often does not switch to a new router or satellites while moving between the router and the satellites.
    After all, it is not a problem if you do not want to change the name of the old network and password in devices, which is to enter the old network data into the new router. It has the old network name and a working MESH.
    It's best to just check each option to find out about its functionality.
    @Erbit The gibberish has been and will be, you will not get rid of it. MESH works, but only good devices provide an additional channel for connections between satellites without using the available channels for the user and full control from the satellite router.
    The usual MESHs advertised there act as normal repeaters. I guess that's what you mean, actually, to know how to tell them apart.
    ps gibberish is contagious and as you can see the whole world catches over time like sample 4K 3D satellite converters
  • Second router for 300 m orchard link and cameras
    #17 19504727
    ubnt013
    Rate: 42
    Thank you for the answers I decided to have the Deco M4 already ordered
    I have one more question, I want to send a signal for 300 m to my "house" in the orchard, the signal is sent via 2x NanoStation loco M5
    1-Network Mode: Bridge, Wireless Mode: WDS Access Point
    2- Network Mode: Bridge Wireless Mode: WDS Station, Connected to Router and New WiFi Network Created with Different Ext IP Address
    is the use of a second router in one network OK? or else connect it? I will add that I have monitoring of 2 IP cameras over WiFi there
    Kind regards
  • AP mode and LAN uplink to avoid double NAT
    #18 19505093
  • #19 19510626
    ubnt013
    Rate: 42
    Hello, I have just received 2 Deco M4 pieces, please let me know how to configure them so that there is one network throughout the house in conjunction with Funbox 6
    Regards
  • #20 19513606
    ubnt013
    Rate: 42
    problem solved with forum help
The discussion revolves around improving Wi-Fi coverage in a single-family house with a FunBox 6 router installed in the attic, which provides good performance but poor coverage on the lower floor. The user is considering two routers: the TP-Link Archer AX1500 Wifi6 and the Archer C80 AC1900. Various responses suggest alternatives, including Ubiquiti access points and mesh systems like TP-Link Deco M4 and NETGEAR Orbi. Recommendations emphasize the importance of a unified network throughout the house, with considerations for using access points (AP) or mesh systems to enhance coverage. The user ultimately decides to purchase the Deco M4 and seeks advice on configuring it with the FunBox for seamless network integration.
TL;DR: For FunBox 6, plan on 2–3 satellites; "most satellites sometimes have one or two LAN outputs or none at all." A mesh/AP kit (e.g., Deco M4 or Orbi) wired to your LAN gives whole‑home Wi‑Fi across floors. [Elektroda, RobeMek, post #19494649]
Why it matters: This FAQ is for FunBox 6 fiber users in multi‑floor homes who want one stable Wi‑Fi network without dead zones or guesswork.
Which is better with FunBox 6: TP‑Link Archer AX1500 (Wi‑Fi 6) or Archer C80 (AC1900)?
Both will cover a single room well. For whole‑home coverage, add more APs or use a mesh kit. “If this WiFi is to cover one room, each router solution you have chosen is good.” For one network across floors, multi‑AP or mesh is the safer plan. [Elektroda, RobeMek, post #19494151]
Can I switch FunBox 6 to bridge mode?
No. The forum notes FunBox 6 cannot be switched to bridge in standard ISP firmware. Build around it by running your add‑on gear in AP mode, or disable the FunBox Wi‑Fi and let your system handle wireless. [Elektroda, RobeMek, post #19494151]
Will one device cover my ground floor?
It depends on area and walls. “At 5 GHz, each successive wall represents a degradation in performance.” Expect to add another AP or mesh node if rooms and walls block line‑of‑sight. A single router often won’t cover a whole floor well. [Elektroda, jprzedworski, post #19493529]
Are Ubiquiti UAP AC LR or UAP AC Lite good options here?
Yes. A respondent recommended Ubiquiti UAP AC LR/Lite for reliable AP coverage. They are strong picks when you can run Ethernet to the AP location for stable backhaul and roaming. [Elektroda, Anonymous, post #19493364]
How do I set up TP‑Link Deco M4 with FunBox 6 for one SSID?
Use Deco in AP mode under the FunBox. 1. Connect the main Deco by Ethernet to a FunBox LAN port. 2. In the Deco app, switch operating mode to Access Point. 3. Add the second Deco via the app and place it downstairs. This avoids cascading routers. [Elektroda, Anonymous, post #19494876]
Is “mesh” always better, or is it mostly marketing?
Mesh helps, but features differ. As one expert warned, “MESH is not a quality indicator.” Check for solid backhaul options, good roaming behavior, and enough LAN ports on nodes. Avoid simple repeaters marketed as mesh. [Elektroda, Anonymous, post #19494755]
Do I need tri‑band mesh if I have many devices?
Possibly. A user reported a big jump moving from Orbi RBK20 to RBK50 with 20 devices: “the difference was colossal with 20 devices connected.” Tri‑band models often scale better thanks to extra backhaul capacity. [Elektroda, RobeMek, post #19494850]
Where should I place satellites, and do they have LAN ports?
Place satellites where you need coverage and a decent upstream signal. Many nodes offer limited Ethernet, so plan wired devices accordingly. “Most satellites sometimes have one or two LAN outputs or none at all.” Check port counts before buying. [Elektroda, RobeMek, post #19494649]
How do I link a second building ~300 m away with NanoStation loco M5 without double NAT?
Put the remote router in AP mode. Disable its DHCP and connect the loco M5 to a LAN port on that router. Devices then get IPs from the home router and stay in one subnet. “In your current solution, devices ‘at the house’ are not available from the home network.” [Elektroda, Anonymous, post #19505093]
Will devices roam smoothly if I keep both FunBox Wi‑Fi and my mesh on?
Roaming can suffer. With two unrelated APs, clients may stick to a weaker signal. “It often does not switch to a new router or satellites while moving.” Turn off FunBox Wi‑Fi or match capabilities carefully. [Elektroda, RobeMek, post #19495015]
Should I disable FunBox 6 Wi‑Fi when I add mesh/AP gear?
Yes, if you want one consistent SSID and roaming. A responder suggested turning off FunBox Wi‑Fi and using the new kit (router + satellites) for full‑home coverage and seamless access. This simplifies client behavior. [Elektroda, RobeMek, post #19494906]
Can Deco M4 still give “mesh” roaming in AP mode under FunBox 6?
Yes. “Getting rid of WiFi from FB and using a new router and satellites in AP will provide full MESH.” You keep seamless roaming and central control while avoiding double NAT. [Elektroda, RobeMek, post #19495015]
How many Deco units or satellites do I need for a two‑floor house?
Start with two units and test coverage. Many homes need 2–3 satellites for consistent performance across floors and rooms. This aligns with guidance provided in the thread. [Elektroda, RobeMek, post #19494649]
