KIA Picanto 1.0 G4HE Engine: Valve Clearance Parameters for 45kW After Sealant Replacement
maciejblaz 26652 3
  • #1 16250100
    maciejblaz
    I warmly welcome.
    I am faced with the fact of adjusting the valves in my car after replacing the sealants.
    My question is what should be the parameters of valve clearances in this engine.
    I found in the instructions, e.g. KIA PICANTO 1.1 0.20 / 0.25 and on cold 0.10 / 0.15. and in instr. picador 1.1 0.10 / 0.17 hot -0.20 / 0.25.
    The information applies to the 1.1 engine, whether in my 1.0 45kw engine it is the same or maybe the values should look different.
    I am asking for help because I have not found any information about 1.0 engine and valve clearance in my G4HE
    Regards Maciej
  • #2 16256221
    diablo23248
    Help: 102
    Rate: 614
    WG Autodata :
  • #3 16256709
    maciejblaz
    many thanks best regards
  • #4 19303107
    DutchGuy
    Hi diablo23248,
    Are the Valve clearance for cold and hot engine?
    Cold Engine
    inlet 0,22mm
    exhaust 0,27mm
    Warm Engine
    inlet 0,28mm
    exhaust 0,33mm
    Greeetz Marc
