no power while driving - Oil leakage from under the valve seal
Mirek16 6948 17
Why does my Fiat Uno 900 lose power while driving uphill, and how should I deal with the oil leak from under the valve cover gasket?
The power loss was caused by a fuel supply problem: there was a little water in the fuel filter, and after replacing the fuel filter the engine regained power [#16258900][#16259223][#16261831] The symptoms also matched a lean mixture, so checking fuel pressure was a correct diagnostic step [#16259123] The oil leak under the valve cover was a separate issue and was handled by replacing/sealing the valve cover gasket with temperature-resistant silicone [#16261831] It is also worth checking the crankcase ventilation/“pneumothorax” because if it is blocked or frozen it can contribute to oil leaks [#16259605]
  • #1 16258768
    Mirek16
    Hello, some time ago I noticed a small leak from under the valve gasket Fiat uno 900 2001, today I was driving and suddenly lost power while driving uphill there is a problem to drive up. the leakage intensified and I add oil because it is running low, I am asking for help in solving my problem.
  • #2 16258787
    ToJestNick
    Help: 150
    Rate: 559
    Yyy ... W 900, oil leakage from under valve cover gasket is normal. A few screws on the hexagon 6, a new gasket and a head for about half a year ;) The oil is running out because ... It's leaking ;)
    For power loss, check the ignition system and spark plugs. When were they replaced? Maybe he doesn't smoke on a cylinder.
  • #3 16258900
    mitra451
    Rate: 52
    Check fuel pressure.
  • #4 16259091
    Mirek16
    I checked the candles are white and burned out.
  • #5 16259123
    andrzej20001
    Help: 1578
    Rate: 6675
    Mixture lean, check fuel pressure and cylinders as a colleague advises.
  • Testing ignition-wire insulation for arcing and fuel pressure
    #6 16259125
    Majsterkowicz5
    Inspection gear, high voltage wires, coil, finger, bubble. If everything was working there, as it was written above, I would check what pressure comes out of the fuel pump (or what it should be). I check the cables in such a way that I take the cable and connect it to the mass (body). Then with the other end of the wire (with a slightly insulated wire) I fly along the ignition wires one after the other (I mean, right next to the ignition wire, I move my wire attached to the car body) If there is a puncture, a spark will appear somewhere between your wire and the ignition wire . This method works best in dusk or low light. Then he quickly observes what and how. Do not forget to protect yourself and do it in some gloves and maybe with pliers so you don't get a "kick" from the spark just in case.
  • #7 16259127
    Mirek16
    Ok how much it should be at 1,2,3,4
  • #8 16259151
    Majsterkowicz5
    I think ok 12 bar but I can be wrong.
  • #9 16259216
    Mirek16
    About 12 bar on the pistons and how to check the fuel pressure?
  • #10 16259223
    andrzej20001
    Help: 1578
    Rate: 6675
    The easiest way to connect the pressure gauge with a tee is to the fuel filter
  • Checking crankcase blow-by and coolant contamination for head-gasket failure
    #11 16259268
    suchejro
    Help: 6
    Rate: 54
    And it blows strongly from the oil filler cap when it is unscrewed? Maybe it blew out the gasket and there is no compression, it goes to the oil chamber and hence a large oil leak under the valve gasket. The fact that it would be interesting that it only goes outside, skipping the water channels, but maybe something is going there, you just haven't checked. See if there is oil in the coolant or liquid in the oil, white coating on the cap, etc.
  • #12 16259349
    Majsterkowicz5
    I am not a mechanic, so I am curious to ask myself. A colleague Mirek16 wrote that he has a compression around 12 bar per cylinder, should the compression not be less with a damaged gasket, which results from a leak between the head and the block?
    Buddy Mirek16, is the car somehow intensely smoking?
  • #13 16259396
    suchejro
    Help: 6
    Rate: 54
    I did not notice that this was a statement after the examination, except perhaps just a confirmation of receipt of this information.
    And after firing up, what is the matter of rubber pipes with coolant? Are they as hard as stone or do they give in to pressure by hand squeezing?
  • #14 16259605
    Staszek49
    Help: 228
    Rate: 1141
    Buddy, check out the so-called pneumothorax (crankcase deaeration), it may have frozen and hence these oil leaks. Are you sure you checked the condition of the oil on a regular basis, maybe you have already rubbed the engine.
  • #15 16259713
    suchejro
    Help: 6
    Rate: 54
    You write "a time ago I watched a small leak from under the Fiat valve gaskets" ... but my doubts are caused by the fact that you did not write whether what you mean is the valve cover gasket or under the head? You see ... the statement sounds unreliable, raises doubts, because if someone does not know their own language, maybe they also do not know mechanics? It's not a nuisance, it just is. Readers always have doubts as to the professionalism in a given topic, since they have gaps in another.
  • #16 16259779
    kjancz
    Rate: 20
    Buddy, if the muffler is smoking white and pushes the oil from the valve cover gasket, you may have a problem with the valve seat leakage on the so-called glass
    Moderated By carrot:
    Before a colleague starts giving advice, I advise you to get to know the engine structure first
  • #17 16259789
    suchejro
    Help: 6
    Rate: 54
    This engine has glasses, not ordinary levers?
  • #18 16261831
    Mirek16
    Hello, the replacement of the gasket under the valve cover I sealed the silicone to the temperature, and with the power of what it turned out that my colleague Andrzej led me on the trail fuel filter fuel with a little water after replacing the fuel filter regained power but by the way I checked the entire spark plug system wires cleaning the basket on the thread injection into the bundle, as they say and I managed, the car ticks as always, thank you and best regards.
The discussion revolves around a Fiat Uno 900 (2001) experiencing oil leakage from the valve cover gasket and a sudden loss of power while driving uphill. Users suggest that oil leakage is common and recommend checking the ignition system, spark plugs, fuel pressure, and compression. The author confirms burnt spark plugs and later resolves the power issue by replacing the fuel filter, which had water contamination. The importance of checking for oil in the coolant and the condition of rubber hoses is also highlighted, along with the potential for a blown gasket affecting compression and causing oil leaks.
